Question about Minka Aire (Ceiling Fan)
How do I make a Minka Aire MR36T-10605B 6+5UF Ceiling fan respond to command?
We have a Minka Aire fan and the receiver model is MR36T-10605B 6+5UF. Due to a number of reasons we did not install our fan until well after the warranty period. Once it was installed and the AC was switched on, the fan is on Max speed. The remote does not change the speed or light. I tried changing the frequency switches on the remote and followed the procedure. [Within 60 seconds of turning the Receivers AC power ON. Press the transmitter's Stop button for more than 3 seconds.] However, the light never flashes and the remote does not control speed or light. Anyone have any suggestions on how to fix it? Is it possible?
  • Anonymous Apr 20, 2017
    I have the system that says to update the receiver frequency, turn the AC on and with in 60 seconds push the stop button for a minimum of 3 seconds. The receiver does not have any switches.
2 Suggested Answers
SOURCE: Minka Aire remote controlled ceiling fan
I have a newer Minka w/ wall controller. The books says to make sure both the wall control and the receiver(up in the fan) are both programmed the same. My receiver has no little switches but has a sticker stating that you need to hold the 'fan off' button down for 3 seconds after turning on the power so the receiver can memorize the program in the wall switch. You have 60 sec to do this after power is turned on. Good luck !
Posted on Feb 25, 2009
Hardwired ceiling fan turned off by itself and stopped responding to remote control, but the light turns on/off.
I've had problems with Minka Aire also. You might need a new receiver. Call Minka @ 1-800-307-3267 and talk to someone in tech dept.. Should be a one year warranty on the receiver.
Aug 17, 2015 | Minka Lavery Minka Aire F888-BNW...
My CFR-3T receiver got wet when ceiling pipe burst. can this unit MR36T-10605B)6+5UF be replaced using the same remote
Yes you can replace the receiver only. Just be sure you set the new one to the same frequency as your existing remote and all will be well!
Feb 13, 2015 | Minka Aire Ceiling Fan
Minka Aire model f603 reverse switch?
Not sure what model of fan or manufacture you have. Says Hunter 52" & Minka aire F603. If it's the Minka , Then push the button on the lower part of the remote (6 o'clock). If that doesn't work then you might need a new receiver.
Jul 23, 2014 | Hunter 52" Ceiling Fan With Light And...
My fan works but the lights do not on my bolo f620 fan
I would make sure the wire connections from the receiver to the fan light wire are secure. Otherwise call 1-800-307-3267 ( Minka aire )
May 04, 2014 | Minka Lavery Minka Aire F620-DBB Bolo 5...
Our Minka Aire ceiling fan turns off all by itself (both the fan and light)
You either need a new receiver or you need to change the dip switches in the receiver & transmitter.
Aug 27, 2013 | Minka Aire Ceiling Fan
Minka Aire Ceiling Fan light wont come on
Probably needs a new remote receiver.Contact Minka Aire @ 1-800-307-3267
Apr 30, 2013 | Minka Aire Ceiling Fan
Minka Aire Ceiling fan turns on by its self
Try changing the frequency in the receiver & transmitter.
Mar 19, 2013 | Minka Aire Ceiling Fan
Minka Aire remote control ceiling fan problem with dimmer.
Did you ever find a solution to your issue? I have the EXACT same problem and have been looking for an answer for about a year.
Sep 20, 2009 | Minka Aire Ceiling Fan
Light dims up and down repeatedly
PROBABLY THE WALL CONTROL SWITCH IS BAD.
ASK YOUR LOCAL DEALER TO BORROW ONE HE HAS IN STOCK. AND OR BUY BOTH THE RECEIVER AND THE SENDER. MY WALL SWITCH MALFUNCTIONED.
Apr 05, 2008 | Minka Aire Ceiling Fan
Minka Aire (Ceiling Fan) Logo
Top Minka Dryers Experts
Joseph Coppeto
Joseph Coppeto
Are you a Minka Dryer Expert? Answer questions, earn points and help others
