Ihave anRCA 46 inch flat screen tv. Model 46la45rq. I-amexperiencin After image with closed captions. Is this possibles.
SOURCE: Sony 46" XBR2 Cannot turn off closed caption
With TV on, turn off DVR and hit menu on DVR remote - you can disable CC from there.  Worked for us - got the idea from another fixya post.
Posted on Aug 28, 2008
crlee3
SOURCE: Closed Caption
Yeah, I'm now believing it's the tv. The captions on the other tv in the house work great. My samsung is only 2 yrs old. This model was 1080 i...Kinda of costly. Still no solution???? CR. LEE
Posted on Sep 08, 2008
  • 85 Answers
SOURCE: Unable to remove the closed caption through the
I dont know what model you have i see two on there website. i read manual for one of the 42 inch lcd tvs and i do see where you confirmed you said off to closed caption mode am i correct? Ok try this turn the closed caption on and exit menu. now shut off tv and turn it back on. now go into menu and turn closed caption mode to off now and exit menu and see if that helps. ok i hope this helps ....oh i forgot to mention make sure that you didnt enable the closed captioning on your cable box remote. Just might want to check with that. It might not be your tv at all it could be the cable boxes closed captioning service. I hope some of this helps if not see if there is a factory reset in the menu.
Posted on Feb 20, 2009
  • 4 Answers
SOURCE: LG flat screen TV speakers make a vibrating noise
I have this problem with my 37LG30.
They all seem to have the same factory flaw.
The plastic bezel and rear is vibrating against itself I have found.
Tonight, just now, I just took all the front bezel screws out,(from the back) loosened the other 4 big screws in the rear center(I don't recommend removing them)and loosened the stand screws also and tried separating the bezel from the back as I went around the set. This did not really help much except around the bottom where the noise/vibrating comes from-the speaker area.
The two plastic pieces are vibrating against one another.
The vibrating was coming from the speaker area without doubt.
The next thing was to try separating at the bottom where the speakers are with my fingers and a stiff metal nail file carefully..fingers seemed to work best for me.
As I separated the front bezel from the rear housing (at the speaker location)most if not all the buzzing/vibrating /distortion went away.
I then inserted small pieces of cotton (you can use felt, or similar I suppose) and buttoned it all back up;put the screws in
Almost all the distortion and speaker buzz/vibratingis gone except on very low frequencies.
good luck!
Posted on Apr 16, 2009
  • 8457 Answers
SOURCE: IHave a 32 inch flat screen Westinghouse TV that c...
Ur tv the LCD inverter board it dead.The LCD inverter is the board that help the LCD screen panel to get a backlight to produce a picture,the LCD inverter board is dead and it not working anymore that why u only get 8 sec.of the picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long board in shape.
Posted on May 23, 2010
Rca 46la45rq has backlight and power but no sound or picture replaced main and inverter boards
Was this the original problem before replacing the main board?
Maybe you have to set the new main board from maintenance menu. Sound and image comes from the main board, so i believe it has to be something about it...
good luck
Aug 31, 2014 | RCA 46 46LA45RQ LCD TV
MY 46 INCH TV WHEN IS ON THE IMAGEN GET LINES
Sounds like a defective T-con board. Worst case is your Panel, but I don't think so.
Mar 20, 2013 | RCA 46 46LA45RQ LCD TV
46 rca model 46la45rq comes on for just a second then the screen goes black and it only plays sound! what needs to be replaced
Sounds like you have a backlight problem. To verify this, turn on the set and dim the lights in the room. Take a bright flashlight and shine it on the screen. Do you see a faint picture?
Jan 14, 2013 | RCA 46 46LA45RQ LCD TV
My rca 46 lcd has different color lines on the screen, what can i do?
Get a diagnoses done on the set. It is possible you could have one of the following problems;
bad LCD panel
bad t-con board
bad ribbon cable connection
Nov 27, 2012 | RCA 46 46LA45RQ LCD TV
46LA45RQ
The T'Con board to your TV is faulty. If you have some knowledge in electronics, you can replace it. Instructions to replace it can be seen the site named Electro-help. Check this link and select it.
Jul 04, 2012 | RCA 46 46LA45RQ LCD TV
Unable to remove the closed caption through the remote control (Haier) 42 inch flat screen tv. Went through the function and selected 'No' to Closed Caption, but it does not remove it. Thanks, Sandy
Feb 20, 2009 | Haier Televison & Video
46' sony flat screen lcd
it must be on the menus
sony.com call tech support -- tthey value customer relations
Ron
Aug 15, 2008 | Sony QUALIA 005 46 in. LCD Television
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
