Question about Kyocera Computers & Internet
How do I get my data to work on my Kyocera with life wireless network?
2 Suggested Answers
inovagent
  • 111 Answers
SOURCE: i need mu kyocera km 22300 installed on my
I can help you with this if you are in the Washington DC area. You must connect the printer to the network, then set up the server, then set up the clients. By the way, it's a KM-2230. Contact me through my website, www.inovagent.com
Posted on Nov 04, 2009
Life wireless apn settings for at&t kyocera duraforce e6560
The best place to get these settings is from your service provider. Call up on their customer care hotline and ask. They'll send an SMS containing the settings.
Jun 20, 2017 | AT&T Cell Phones
Unable to get wi-fi to kick in and hold for a call. although it works just fine in store.
Troubleshoot issues related to data connectivity and your ...
support.sprint.com/...Kyocera.../WTroubleshootingGu...
Sprint CorporationThis article helps you troubleshoot data connectivity issues on your Kyocera Rise. You may have data connectivity issues if you're unable to: ... Some features and applications require a data connection to work properly. ... Note: Most Wi-Fi networkshave a range of less than 100 feet indoors and up to 300 feet ... Contact us ...
Troubleshoot issues related to your Kyocera Hydro Edge ...
support.sprint.com/...Kyocera.../WTrendTroubleshoot...
Sprint CorporationThis article helps troubleshoot your Kyocera Hydro Edge slowing, freezing, ... You mayhave performance issues if your device: ... back on; Displays error messages; Isunable to install or update applications ... Press and hold the Power key, tap Power off, and then tap OK to turn your Kyocera Hydro Edge™ off. ... Contact us ...
Brigadier by Kyocera Support ' Verizon Wireless
www.verizonwireless.com/support/brigadier/
Verizon Wireless
Dec 13, 2015 | Kyocera Cell Phones
What is the unlocking code for a Kyocera Hydro Life..model #6035?
Resetting the phone If the phone does not respond to taps or key presses with the flip either
open or closed, you may need to perform a reset.
There are two types of resets-soft resets and hard resets. In a soft reset,
all records and entries are saved. In a hard reset, all records and entries
are erased. If you must do a hard reset, you can restore any data that you
previously synchronized using a HotSync operation.
To perform a soft reset
May be either on or off
Open
1. Turn the Kyocera smartphone over. Open
the battery door on the back of the phone.
2. Press the reset button with the stylus.
3. Replace the battery door. Turn the phone
back over and verify that it has restarted.
Feb 02, 2015 | Kyocera Cell Phones
How can i networked my kyocera taskalfa 180
You only have a usb 2 connection.
You can hook it to one p.c and share out the printer to other p.c.s.
You could invest in a router that has provision for sharing out a usb printer connected to it.
You could invest in a USB printer server. see http://www.dlink.com/us/en/home-solutions/connect/print-servers/dp-301u-10-100-ethernet-usb-print-server. However you need a ethernet network already in place with your other computers. You can connect your other p.c's via ethernet and use a network switch device to connect all devices to one another if you do not have a network or use a wireless Router and wireless adpaters or p.c's but no more than 4 p.cs on wireless.
Aug 31, 2014 | Kyocera Office Equipment & Supplies
How to save battery power on kyocera hydro
Cell phones are drained by running background apps, LCD brightness etc. Here are a few tips to help you. Most importantly, batteries do loose their strength (even when fully charged). I would possibly replace the battery every 2-3 years with a name brand battery, not a generic. Also keep in mind, when your phone is charged at 100%..unplug it. Tips to save battery life To save and extend battery life, follow these steps:
Lower screen brightness and timeout duration
  1. From any home screen, tap the All Appsall+apps.pngicon.
  2. Tap Settings.
  3. Scroll to 'DEVICE,' and then tap Battery.
  4. Tap Brightness.
  5. Touch and slide the Brightness slider left to decrease the brightness setting.
  6. Tap OK.
  7. Tap Screen timeout.
  8. Select one of the following options:
  9. 15 seconds
  10. 30 seconds
Turn off Wi-Fi, Bluetooth, GPS, Portable Wi-Fi Hotspot
  2. Tap Settings.
  3. Tap Tethering & Networks.
  4. Tap Mobile HotSpot.
  5. Clear the Mobile HotSpot check box.
  6. Tap the Back key.
  7. Tap the Back key again to return to the 'Settings' menu.
  8. Scroll down to 'PERSONAL,' and then tap Location access.
  9. Clear the GPS satellites check box.
  10. Touch the Status bar and slide it down.
  11. Tap Wi-Fi to turn off.
  12. Tap Bluetoothto turn off.
Change application sync settings
  1. From any Home screen, tap the All Appsall+apps.pngicon.
  2. Tap Settings.
  3. Scroll to 'PERSONAL,' and then tap Accounts & sync.
  4. Clear the Auto-sync data check box.
  5. To reduce sync settings for individual applications, select the desired application.
Turn off background data
  2. Tap Settings.
  3. Tap Mobile data.
  4. Tap the Menu key.
  5. Select the Restrict background data check box.
Minimize use of third party applications
  2. Tap Settings.
  3. Scroll to 'DEVICE,' and then tap Apps.
  4. Select the application you want to edit.
  5. Tap Disable to turn off the application.
    Note: You can tap Uninstall instead to completely remove the application.
Toggle from 4G to 2G
  2. Tap Settings.
  4. Under 'NETWORK SETTINGS,' tap Mobile networks.
  5. Select or clear the Use only 2G networks check box.
Update to the latest software
  2. Tap Settings.
  3. Scroll down to 'SYSTEM,' and then tap About phone.
  4. Tap System updates.
  5. Tap Check now.
  6. Follow any additional prompts.
Set device to sleep when unused
  1. Press and then quickly release the Power key to set the screen to sleep mode.
  2. To activate the screen, press and then quickly release the Power key again.
Apr 24, 2014 | Boost Mobile Kyocera Hydro Smartphone
How can I connect my kn 4035 printer to my laptop through a wireless network?
This printer has a lan connection built-in, you can connect this printer to a LAN port on your wireless router. You need to configure the IP address of the printer to work in the same IP address range that the wireless router uses so the printer can communicate with your network.
May 04, 2011 | Kyocera Mita KM-4035 Printer
I need mu kyocera km 22300 installed on my network. was working before lost ip data
Nov 04, 2009 | Kyocera Mita KM-2530 Laser Printer
Wireless connection doesn't work (ip not in subnet)
I had fits getting it setup myself for wireless. Despite any efforts to use the wired connection to change the wireless settings, I just couldn't get it to work. I ended up printing the configuration page to learn the expected SSID and then changing the SSID on my wireless router to match the SSID the printer was polling for. At that point it acquired a wireless address properly. Because I was several hours into making it work, I never tried changing anything else after I got it working.
Jul 25, 2009 | Brother HL-2170W Laser Printer
Computers & Internet Logo
27 people viewed this question
Top Kyocera Computers & Internet Experts
NOEL
NOEL
drbobb
Level 1 Expert
Are you a Kyocera Computer and Internet Expert? Answer questions, earn points and help others
