Question about Sears Garden
I have a Sears mower with a 190cc B & S engine. It will not stay running. It starts and then surges up and down like you were controlling a throttle and then finally just slows down and quits.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sears Master
  • 903 Answers
There is a blockage in the carburetor. you will need to take it off and clean it real good with carburetor cleaner. go ahead and put a new needle and seat in it while you are in there it should run like a new one.
Posted on Apr 22, 2017
ccrozier_agr
  • 36 Answers
SOURCE: 2 1/2 Briggs......doesn't run smoothly....surges at all speeds.
Hi, Check that you have the correct spark plug fitted or fit a new one as it sounds like your plug is getting hot then shorting out.
Sometimes the magnito can do this as well. but I would start with the plug.
Posted on Nov 29, 2008
  • 376 Answers
SOURCE: Toro 6.5 hp 9 year old mower. Starts Ok; surges
Sounds like your carburetor needs to be cleaned out. The surging is usually a sign of running to lean (not getting enough gas) because of possible water, rust, gum, varnish or trash in your carb. Hope that helps.....
Posted on May 17, 2009
panilling9
  • 284 Answers
SOURCE: Mower petrol engine runs much too fast
check your governer and spring to make sure it isnt in a bind or being hindered by something
make sure it moves freely
Posted on May 26, 2009
carlsbiz
  • 1124 Answers
SOURCE: My Sears riding mower chokes itself out after warmed up,
Careful with the high octane.. That can burn a hole in the piston..
It might be fludding.. At the bottom of the carb should be a bowl.. One bolt at the bottom.. Take it off and clean it.. Spray some carb cleaner up in there where the float is..
If that dont do it --
Maybe the float is bad & taking in fluid..
If it has sat for long piriods of time - the carb might need to be cleaned & rebuilt..
When gass sits in there for a long time it shalacks and wont work correctly..
Pop off the carb & take to your local small eng shop. Shouldnt cost to much..
Posted on Jul 09, 2009
  • 3 Answers
SOURCE: Lawn-Boy Insight Series 21-Inch 190cc 650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower: my engine will only stay running for about 3 secon...
Maybe the engine is running with the fuel from the primer bulb (about few seconds), the carburator is not working and need to be removed checked and cleaned, the most common fail is a jet clogged.
Posted on Dec 16, 2010
Briggs and straten...875...190cc will not stay running,it`s surging the whole time and then just stops
It sounds like you may have a cracked float in the carburetor. It surges and when the float is saturated, it stops. If you don't feel comfortable putting in a rebuild kit, you may need to to take it to a small engine repair place.
Feb 22, 2015 | Briggs & Stratton Briggs Stratton...
How can i fix my slow running lawnmower
Sounds like the air/fuel mix is off.. there should be a adjustment screw on the side of the carburator use a screw driver and turn it slowly one way or the other till it starts running right
Jun 22, 2014 | Craftsman 675 Torque 190cc 21" Briggs ...
Craftsman lawnmower wont stay running
Michael it sounds like there may be a blokage on you air filter. Check it and clean it then make sure there is not too much oil in the mower.
Jul 18, 2013 | Garden
My Toro GTS LV195EA 362003C is starting, but not staying running. I cleaned the carb, replaced the spark plug and filter, and have tried to adjust the govenor and bowl nut on carb, but the throttle and...
Engine surge is usually caused by one of two things...
1) a lean condition. Not getting enough fuel.
2) throttle plate shaft in carb is worn. usually clears up when engine is put under a load. You can live with it or replace the carb
Nov 06, 2012 | Toro Lawn Mower With Toro Power Tools
Mower surging.
did you leave gas in it for the winter gas is only good for 30 days in small engines drain it and try fresh gas
May 14, 2012 | Garden
Craftsman Mower - 625 Briggs and Stratton Engine. The mower starts after I prime it 3 times. Starts up and runs at only half speed. I have taken the whole thing apart, changed the gas, cleaned the carb,...
Check the governer, its a lever that pulls the throttle plate from the engine side. Try manually overriding it (twist it open as the engine's running) and see if that does it.
May 09, 2011 | Craftsman 675 Torque 190cc 21" Briggs ...
Briggs and Stratton Troy Built 21inch 190cc 650 series Gas Powered self propelled Lawn Mower. I moved to new house and the movers lost the manual. I bought it last year so only one seasons use. How do I...
If how you described you unit is true you do not have an electric mower you have a gas powered mower, you DO NOT have a battery!!!??? Place the throttle lever to choke position and prime carb with primer bulb 3-5 times then pull cord. Wala!!!! It's running rite. That guy at Loews must have been smokin somthin. Good Luck...
Apr 22, 2011 | Briggs & Stratton Lawn-Boy Insight Series...
Hello, I am using the Craftsman 675 Brigs & Station 190 cc lawnmower, and I'm trying to turn up the throttle. It apparently does not have a throttle adjuster, and I was wondering if there is any way...
After researching the engine application, I see that this 675 is NOT an OHV engine. It appears it is the L (flathead) engine with the standard features. The 775-875 Platinum series mowers have OHV engine applications. That being said, many mowers have the carburetors with the governed throttles set to run at the the OEM mandated maximum speed. Some (like the Briggs Quantum series engines) have the throttle plate still attatched. You would need to bend it back up and install an aftermarket throttle cable assembley (like Murray makes). You would connect the carburetor end of the throttle cable to the hole in the plate assembly that has the governor spring attatched. Some even remove the governor entirely (internal governor has to stay in) and connect a throttle cable on the plate controlling the butterfly in the carb. Your unit may have this feature with the plate having a few different holes in it in which you could install the end of an add on throttle cable.
Apr 09, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
May 17, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Garden Logo
27 people viewed this question
Top Sears Garden Experts
Tim Whalen
John M Grubb Sr
Matt Olenzek
Matt Olenzek
Are you a Sears Garden Expert? Answer questions, earn points and help others
