Question about The Office Equipment & Supplies
My maytag commercial washer is stuck at 7minute rinse cycle
Have unplugged and replugged still same. Have put new quarters in still the same please help
  • Whirlpool
    Whirlpool Jun 16, 2017
    Hi Anonymous, we're sorry to learn of your concerns. Please contact our specialty team for further assistance at call 800-662-3587.
    Top Expert:
  • The Master
  • 80,637 Answers
Sounds like the timer is defective.
Posted on Apr 25, 2017
WHY ON MY MAYTAG EPIC WHEN IT GETS TO SPIN IT JUST MAKES DRAINING NOISE AND WATER WONT DRAIN?
Sounds like your drain line is clogged. You may also have stuff clogging a water filter just before the pump, or the water outlet coming from the drum.
It could also be a problem with the pump, but until the drain line is opened up, you still won't be able to empty the water from the washer.
Aug 11, 2014 | Maytag EPIC MFW9700S Front Load Washer
Commercial maytag front loader starts high spin when money is put in
It's A You Drain Pump is bad. What a guy! He did not know that!? Replace the drain Pump and it will a Happy washer again!
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Jan 19, 2014 | Maytag Washing Machines
Error code ''suds'' on maytag front loading washer
Press Chime and Extra rinse keys for three seconds or until the control beeps. You are now in service mode and your machine should say a new error code. Depending on what that code is, you might be able to reset your machine by unplugging it, and replugging it in. if your codes are now clear, try running machine on spin only or rinse cycle. DO NOT add more soap!!! If this corrects your problem, try running a load with out soap. You may have a lot of extra soap in your machine.
Mar 20, 2010 | Maytag MAH8700A Front Load Washer
Maytag commercial front load washer MAF18MC3AS has 3 rinse cycles. can this be changed to 2 rinse
No. unfortunately, this is a preset situation. this is programmed into the main logic sector on the control. It is preset during manufacturing, and cannot be changed.
Nov 13, 2009 | Washing Machines
Kenmore HE3 stuck in rinse cycle
my wife was doing laudry with he3 and when it quite the door would not open.tried to restart a new cycle and it would not start.I unplugged the washer and let sit for 2 min.replugged it in and it started to work.I hope this helps you.
Apr 22, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Whirlpool calypso model GVW9959K-0 leaking during rinse cycle
hi my name is joyce
Sounds like your pump is leaking. if it is leaking when you are on a spin cycle.
now if it is stuck on f1 cycle and wont drain unplug and let stay unpluged for 60 seconds and replug and see if you can restart on drain and spin cycle. let me know if I can help with any other problems.
thanks
joyce
Feb 06, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Door won't open
you can take the 4 phillips screws out of the corners of your soap dispensor, the lid of the dispenser willlift up and youll see wrapped around in there eitehr a floresent green or orange plastic wire. that is a manual release cord for the latch assy. this will allow you to get your clothes from the machine, form there look into why the latch never released
Nov 17, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washer wont rinse
you have a pump problem, need to lean washer back ageist wall go under washer. front left take off both hoses stick finger in pump remove all items from pump &hoses should work now
Aug 04, 2008 | Maytag MAH2400A Front Load Washer
Washer wont rinse
we had the same problem with ours....nd means not draining and that means that there is something, probably coins stuck in your drain hose. pull the drain hose out and check it for change and make sure something isn't stuck.
Jul 21, 2008 | Maytag Neptune MAH9700 Front Load Washer
50 people viewed this question
Top The Office Equipment & Supplies Experts
Jerry Greenberg
Jerry Greenberg
old marine
old marine
Mitch Vass
Mitch Vass
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
