Question about Kenmore Dishwashers
Old kenmore free standing dish washer. But when i push star nothing happens.... any idea?
It is plugged in, hooked up to water, the door is shut, and the lights come on when i push start. when i push cancel it tries to purge water like normal.
Lumpy816
  • 246 Answers
SOURCE: Kemore HE3 front load washer won't start
Check you door latch. When you open the door, there should be a black square hole on the frame and a black round hole above it with a pin sticking out. The pin is probably broken off and the door latch assembly needs to be replaced.
Posted on Jun 16, 2008
ngfam1
  • 639 Answers
SOURCE: kenmore dishwasher blinking lights
Dear friend,
ngfam at you service! happy to assist!
The blinking lights are called codes and this is warning you that there is a technical problem. Probably an electronic failure some where. This can only be diagnosed by a trained service tech!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 29, 2008
  • 1214 Answers
SOURCE: Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Posted on Jan 24, 2009
SOURCE: Kenmore dish washer lights up but will not start wash cycle.
turn off your dishwasher then try it again ok
Posted on Feb 27, 2009
  • 126 Answers
SOURCE: Kenmore Elite oven door locked and won't open.
did you try unplugging it for 30min.?
Posted on Nov 15, 2009
HOW DO YOU TURN IT ON TO WASH THE DISHES
look for the manual of your new DWF612SS Free-standing Dishwasher.... and find the tutorial how to turn it on...
Apr 27, 2011 | Smeg 24 in. DWF612SS Free-standing...
How do you reset the spring on the door? the door falls down when opened.
just need to on do the unit from the two screws that hold the top of the dish washer in,,,make sure you have enough hose and power cord to pull the unit out just a little ways,,,but it is always best to unplug the dish washer,,,but the unit needs to be pulled out and the springs just need to be hook back on towards the bottom of the dish washer,,,always work safe,,unplug the dish washer. water and electrical never works together
Feb 19, 2011 | KitchenAid 24 in. KUDI01IL - Multiple...
Ariston dish washer door will not shut properly.
Check that something has not got wedged behind the top basket stopping it closing fully.If that is ok what can happen is that if there is something causing the door not closing fully ,when you try to close door to do a wash instead of the little hook actuator in the door switch fully engaging with the clasp on the body of unit,it closes down before it engages.It is like a finger hooking over say the top of your trousers.If you turn power off and get 2 small screwdrivers and carefully put them either side of the hook on door then try to bring it back to its open position.
Hope this helps.
May 17, 2010 | Ariston Technologies L63 Free-Standing...
It will not begin to fill
MAKE SURE THERE IS NOTHING BLOCKING THE SWITH ON THE DOOR, IT WON'T COME ON TILL THE DOOR IS CLOSED AND THERE SHOULD BE A LITTLE PIN ON THE DOOR THAT OPERATES THE SWITCH, IT PUSHES IT IN TO LET IT KNOW THE DOOR IS SHUT
May 29, 2009 | Kenmore 17252 Free-standing Dishwasher
Which dishwashere auto resume wash cycle when door is closed?
All the tall tub dishwashers made by Whirlpool (inc. Kenmore and Kithcenaid) must have the start button pressed after adding a dish. If the start button control light is blinking, you must press start. On those models with buttons on the top of the door you must, in addition, close the door within aprox 5 seconds after pushing start. Hope this helps. Ken
May 01, 2009 | KitchenAid Dishwashers
Washer won't start a cycle
Try some WD40 on the machine door mechanism, not on the door; & open/close the door while the machine switch is off, for the mech to become free.
May 11, 2008 | Kenmore Energy Star 44092 Front Load...
Indesit IDL40 Slim line
Pull the machine out and tip it carefully to one side, if water comes out from the base then the problem is the union on the upper feed pipe. Remove the top inner dish rack and twist the star shaped nut clockwise gently! Make sure you have got as much of the water out as possible, stand the unit back up and turn put it into cycle.
Apr 12, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Kenmore dishwasher "sensing" light
the sensing light and buzzing are normal let it do that on its on then let me know what happens its a soil sensing light and is supposed to run a cycle on its own to clear it but lets see .we will go from there ok
Jan 17, 2008 | Kenmore Elite 45986 Front Load Washer
Dishwashers Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
