Question about Boating
Hooking up r21xx raster scan radar to 4 array found wiring diagrams but my unit has a tb101 side and the other is tb102 all sites show tb101 with other being J101
Also proper on function..wich button and does 4 ft. array have to be hooked up to turn unit on? thanks any help wowuld help thanks
SOURCE: Trying to hook up cable to a raytheon r10 radar scanner.Needs wiring diagram to show where each wire goes.
Large Blk and Large Wht goes to 2a
Large Red goes to 1a
Grn goes to 1b
Blu goes to Bz
Coax goes to Vd
Wht (shielded) goes to Gs
yel goes to 33
Red Shielded goes to Bp
Brn (small) goes to pl
black shielded goes to tI
Large brown not used tape end fold back and secure to harness.
Posted on May 04, 2009
  • 1114 Answers
SOURCE: What is the orange wire for on the pioneer DEH-2800MP?
If you have a blue with white on it or a solid blue lead, I'm at a loss, however the manual even states that colors may change w/o notice. Best way to tell is to use a meter, black probe to ground and red probe to the orange. Put it on DC voltage then turn the ignition to acc. then turn on the deck, my hunch is that it's your amp remote turn on wire for an external amp or it can be used for a power antenna. Voltage should be 12.2-13.8dcv. Hope this helps
Posted on Jun 24, 2009
  • 617 Answers
SOURCE: spark plug wiring on 2001 Toyota 4 Runner
1st coil goes to 2nd plug on lh side
2nd coil goes to 3rd plug on lh side
3rd coil goes to 1st plug on lh side
Posted on Feb 07, 2010
Testimonial: "Exactly what I needed, thanks"
  • 239 Answers
Radio Constant 12V+ Wire: White/Green
Radio Switched 12V+ Wire: Yellow/Red
Radio Ground Wire: Black
Radio Illumination Wire: Red/Black
Radio Dimmer Wire: n/a
Radio Antenna Trigger Wire: Yellow/Green
Left Front Speaker Wire (+): Green/Black
Left Front Speaker Wire (-): Light Green
Right Front Speaker Wire (+): Green/Yellow
Right Front Speaker Wire (-): Gray/Red
Left Rear Speaker Wire (+): Blue/White
Left Rear Speaker Wire (-): Blue/Black
Right Rear Speaker Wire (+): Pink
Right Rear Speaker Wire (-): Blue/Yellow
pls rate
Posted on Aug 18, 2010
  • 1554 Answers
SOURCE: Kenmore Electric Dryer Model 110.69902890
The dryer operates both on 120VAC and 240VAC. The motor and the controls are hooked up on 120VAC whereas the heating circuit is on 240VAC.
The problem here is likely with the thermal cut-off and the high-limit thermostat located on the heater housing. Disconnect power then pry the lower access panel off with a flat-head screwdriver as shown.
Remove the hex-head screw from the heater shield and remove the shield.
Disconnect the red wire from the thermal cut-off and the red/white stripe wire from the heater. Connect the red wire disconnected from the thermal cut-off to the heater terminal where the red/white stripe wire is disconnected from.
Reconnect power then start the dryer. The problem is indeed with the two bypassed components if the dryer heats up. Replace both the thermal cut-off and the high-limit thermostat and it should solve the heating problem. Do not use the dryer with those parts bypassed due to high risk of fire hazards.
Let us know if you need further advice. Please make sure you accept the solution should you find it helpful or informative. Accepting a solution will not stop you from communicating with the expert. You can still communicate with the expert as long as you need assistance regarding the issue stated herein.
Posted on Feb 01, 2011
Horicantal line ic7840,tb1226
Vertical scan output failure. Check and repalce the vertical scan output IC. Horizontal scan is OK. That's why you see a horizontal line instead of raster. Refer its circuit diagram [Schematic] to know more about the IC number. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Feb 20, 2015 | Televison & Video
Raytheon R21XX/R41XX Radar home use or testing ? boat,ship radar
That model is meant for marine (boat) use. You can pre-test it anywhere as long as you are providing the proper power source. It's meant for 12vdc. If you have a marine battery, or a car battery handy, just power it up from that. You do not want to plug it in to household current, you would fry it in a matter of seconds. I would suggest hooking it up to the power 12v outlet in your car of truck to test it.
Jun 08, 2014 | Raytheon Radio Communications
Recently installed... "comm error" with
need to make sure that the radar antenna is plugged into the correct port on the display unit. Also make sure that the plugs are FULLY inserted, the water tightness of the plug can make it feel that its fully inserted but it may not be. For more info contact Whistler at 800-531-0004.
Jun 09, 2011 | Cruisader Radar Detector
My CTV Philips model 21PT3885/94R shows raster OK but with theband from top to down i.e on vertical but the picture is shifted at right hand side .What could be the pfault or else please let me see the...
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts. Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. The search result might display about 20 Nos of related posts. Press the "All posts" at the bottom of the list, then you can select them one by one.
Apr 02, 2017 | Philips Televison & Video
Furuno 1715 gives "no heading pulse" error. Image normal, but clocked due to no reference. Pulled heading sensor (4X6X1mm black box, two wires, labeled NRS-101) and checked continuity across leads. Open...
Heading pulse is a reed switch sensor built inside the dome. upon each rotation of the array the reed switch is activated. Do a visual inspection of your array (inside) to make sure it is spinning (verify from a distance). Don't get eye level with the rotating array it can cause great harm to your eyes. Normally I have seen the belt slip off and also the lanyard attachment get caught in the array. Check those two things as well.
Mar 06, 2010 | Furuno 1715 LCD Radar System GPS Receiver
Im using a 3728 radar open array..the scanning seems to be find but there's a solid circle right at the center that is blocking the display so i can't anything near my ship..
You will need to adjust the timing on the radar antenna which is in the setup menu. You will need to refer to the installation instructions on exactly how to access the installation menu. There should be a small circle in the center of the screen, but not like you are mentioning.
Mar 01, 2010 | JRC Jma-2343 4kw Crt Radar
Furuno 1942 MK2 : The radar don't show any echos on the screen.
The gain truned up and filling the screen with dots tells me the M.I.C. is Ok. Since you array fills with water, there is a very very good chance that the wave guide has given up. A good tell tale sign is that there is white powder laying on rectangular aperture located in the center when you raise the lid on the chassis. A new Array will probably be needed and that will cost you anywhere from $800.00 to 1200.00 just for the part. The water is probably getting in from the array from a bad install as well. normally the chasiss does not leak unless you did something wrong.
Oct 22, 2009 | Furuno 1942 Mk2 Radar
Grn goes to 1b
Blu goes to Bz
Coax goes to Vd
yel goes to 33
Apr 19, 2009 | GPS
Raymarine 41xx - Message "bearing pulse error"
More than likely your motor is going bad. Inside the motor is your bearing pulse generator. Replace the motor and you should be ok.
Apr 28, 2008 | JRC 1500 MKII Radar
Boating Logo
Top Boating Experts
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
