No search button? - Televison & Video
I just bought a 32bv701b. When doing auto scan no digital channels appear. My previous TV received them all fine. Help!
Do a retune to this TV.
Press MENU button on the remote control and select
Install and Retune by using Left or Right button.
Press OK button and the following menu screen
will be displayed
Select Automatic Channel Scan (Retune) by using
Up or Down button and press OK button. Automatic
Channel Scan options will be displayed. You can select
options by using Up or Down and OK buttons.
Auto Channel Scan Menu Operation
Digital: Searches and stores aerial DVB stations.
Analogue: Searches and stores analogue stations.
Full: Searches and stores both analogue and aerial
DVB stations.
Whenever you select an automatic search type and
press OK button, a confi rmation screen will appear
on the screen. To start installation process, select
Yes, to cancel select No by using Left or Right
and OK button.
After auto channel scan type is set and selected
and confi rmed, installation process will start and
progress bar will move along. Press MENU button
to cancel process. In such a case, located channels
are not stored. The television will start to search for
all available stations. You must allow the television
to complete the search.
Jun 13, 2012 | Panasonic Televison & Video
How can i tune channels on my thorn ct512t without the remote control
There is a button on the television, You check at the lower end of the television or on the side of the television. There You have the menu button, then You will see the channel and volume button, those are to navigate through the main menu after pressing the menu button.
When You press the menu button, You will see the main menu page, then You navigate with either the volume buttons or the channel button to channel settings, then You go to search, then You select either the auto search or the manual search, then You search and save Your channel using the buttons as earlier used.
Hope this helped.
Thank You for using fixYa
Jun 10, 2011 | Televison & Video
Is there a universal remote that will work on hisense model HYDF-EP209C1
Hello
Just buy one [ PHILIPS CL 034 ] model universal remote control. Your Hisnse TV is listed in its codes. Codes and proceedings are given below:
0908 0819 0223
Direct Code Entry
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
Code Search (by Brand)
Lets you search for a code for a specific
Brand within the Code Library for a
particular manufacturer.
1. Turn on the device (TV, VCR, etc.) to
be controlled.
2. Press and hold the CODE SEARCH
button until the red indicator remains
button.
3. Press and release the desired Mode
indicator blinks off once.
4. Press and release the numeric button
(0-9) corresponding to desired
Manufacturer (see table below).
Note, pressing "0" performs a full
library search same as Device Library
Code Search Method.
5. Press the CHANNEL UP button ((or
POWER or PLAY (VCR only))
repeatedly until the device to be
controlled changes channel.
6. Press and release MUTE to install
the code
Note, when all codes under a Brand
have been searched the red indicator
flashes rapidly for 3 seconds
OK.
Jan 24, 2011 | Hisense TA42P40M 42 in. Plasma Television
Remote control for konka K2979
Hello
You just buy one Philips Universal Remote Control model number [CL 034]. Your TV, Konka is listed in its codes. The codes and entering procedure are given:-
Codes For Konka:-
0906 0702 0203 0306
................. 0208 0911 0842 0942 0504
Direct Code Entry
button.
flashes.
be controlled.
button.
Code Search Method.
the code.
OK.
Dec 15, 2010 | Konka Televison & Video
I NEED A CODE FOR THE REMOTE AND TO KNOW WHAT KIND OF REMOTE WILL WORK FOR MY TV. PLEASE
Hello
Your Konka TV can be programmed with Philips Universal Remote control MODEL [CL 034]
The codes are
0906 0702 0203 0306
Direct Code Entry
button.
flashes.
be controlled.
button.
Code Search Method.
the code.
OK
Nov 22, 2010 | Konka A2781U 27" TV
How do I program the giant universal remote?
Code Search (HARD)
1.Hold Code Search button Down
2.Press and release Device button TV,Vcr,ext....
3.Press on and off button repedatley until device turns on/off
(You may have to do this up to 1,000 times)
Manual Entering (EASY)
1.Look in instruction booklett or on back of box for a list of device codes
2.Find your device model code
3.Hold Code search button
4.Enter code with # keys
5.Release Code search button
Nov 08, 2009 | Televison & Video
I lost my codes
USING THE RMC10 REMOTE WITH AN UNLISTED DEVICE.
MANUAL CODE SEARCH:
If your product does not respond after you have tried all the codes for your brand, or if
your brand is not listed, try searching for your code by following these steps:
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold the CODE SEARCH button until the red indicator stays on, then
release the CODE SEARCH button.
3. Press and quickly release the desired mode button (TV, VCR, etc.). The red Indicator
blinks off once.
4. Face the remote control directly to the device you want to control (TV, VCR etc).
5. Press the ON/OFF button repeatedly (up to 300 times) until the device to be
controlled changes channel. The red indicator blinks off with each button press.
6. Press and release ENTER to install the code.
Most users will store VCR codes under the VCR button, Cable codes under CABLE,
etc. If (for example) you want to store a VCR code under CABLE, first follow the
procedure for Direct Code Entry (previous page) and press CABLE in step 2 of Direct
Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the
steps above for Code Search (or Brand Search, below). Note: If the device does not
have a CHANNEL UP button, use PLAY (VCR only) or POWER instead. Code Search
starts from the currently stored three digit number under that mode.
AUTO CODE SEARCH:
your brand is not listed, try searching for your code by following these steps.
2 Press and hold the CODE SEARCH button until the red indicator stays on, then
3. Press and quickly release the desired mode button (TV, VCR, etc.). The red indicator
blinks off once.
5. Press the ON/OFF button down till the Red Indicator Light stays on.
6. The red led indicator will keep on flashing till your device (TV, VCR etc) turns off.
7. Press and release enter to Install the code.
CODE RETRIEVAL:
1. Manually turn on the device (TV, VCR etc) to be controlled.
2. Press and hold the CODE SEARCH button until the red Indicator stays on, then
release the CODE SEARCH.
3. Press the device control (TV, VCR etc) you want to control.
4. Press the CODE SEARCH button again and the red indicator should blink once.
5. Follow the sequence of (0-9)and press once for each number button until the
Indicator flashes one time.
6. Repeat the procedure 5 till 3 correct codes are confirmed.
7. If the red indicator light flashes, than you have entered an incorrect number, and
please follow the sequence (0-9).
also here is your manual. For your remote.
http://www.sentryindustries.com/pdf/instructions/RMC10_Instructions.pdf
please rate me, or recommend me it will be most helpful in letting me and other know how im doing.
Oct 03, 2009 | Sentry SE-RMC10 Remote Control
How do i search for an unlisted code for my universal remote?
This is the web site where I found the codes for mine, http://www.remote-codes.com/universalcodes.htm
Hope this helps, if not, let me knoe the model # and I can assist further...
Sep 17, 2009 | Philips Universal PH301S Remote Control
Need code for a dynex tv
The code for the dynex is not listed you will have to do a search:
be controlled.
button.
Note, pressing “0” performs a full
Code Search Method.
the code.
flashes rapidly for 3 seconds.
Code Search (by Device)
If after trying “Direct Code Entry” or
“Code Search (by Brand)” your device
does not respond, or if your brand is not
listed, try doing a device search of the
code library for your code by following
the steps below.
button.
4. Press the CHANNEL UP button
the device to be controlled changes
channel. The red indicator blinks,
then stays lit.
5. Press and release MUTE to install
the code.
Most users will want to store VCR
codes under Cable, etc. If you want to
store a VCR code under Cable, etc., first
follow the procedure for Direct Code
Entry and press Cable in step 2 of
Direct Code Entry, then enter ANY
Entry. Then follow the steps above for
Brand Search or Complete Search.
Jan 12, 2009 | Philips PM3S Remote Control
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
