Question about Fahrenheat Built-In Baseboard Thermostat Heater
Broken control knob
The control knob broke on one of my baseboard heaters. I have been trying to find one by unable. The baseboard heater is tan in color. I only see white ones now and nobody seems to sell just the know. I don't want to buy a whole thermostat just for a knob that is the wrong color anyway. Do you know where I can find one?
Thanks
  • 867 Answers
Go to a used appliance store, they have tons of those things!
Posted on Jul 24, 2009
On/off swith knob broken
Is it the actual knob that is broken or the little tab the knob holds onto that is broken. You either need a replacement knob or a replacement switch assuming the know is also the thermostat for the unit. Does that same knob control the fan speed? Temprature or timer?
Mar 31, 2014 | Pelonis Heating & Cooling
Knob broken
You might try a heating wholesaler in your area If you have the make and model # some supply houses might be able to get them or are placement got you. If not If you have the make you can sometimes contact the manufacture and they might be able to send then to you.
Nov 03, 2013 | Fahrenheat Built-In Baseboard Thermostat...
Marley heater control knobs
can't find a contrl knob for my marley wall heater model # fzl3004b
Jan 17, 2013 | Marley Electric Hydronic Baseboard Heater,...
How do i wire a 240volt hydronic base board heater and thermastat
I need a control knob for my Marley electric wall heater model#fzl3004b
Dec 17, 2012 | Marley Electric Hydronic Baseboard Heater,...
Pilot light goes out every time heater reaches & missing knob
the thermo couple thing that pilot heats up is not staying in flame if knob is broke you may be able to heatup manualy to get gas valve to open some will wome wont
Jun 10, 2009 | Heating & Cooling
Baseboard heater running all the time
since they have indivial twist knobs that regulat temp, the thermostat is bad on one in hall either replace knob which should have thermostat built in or whole unit
May 03, 2009 | Electric TPI CORP TBS BASEBOARD HEATER...
Missing control knob help....
Here is the customer service website to contact them about ordering another knob for your unit.
http://www.fahrenheatpro.com/products/FN_AboutUs.htm
Jan 02, 2009 | Fahrenheat Electric Convector Baseboard...
Fahrenheat baseboard heater knobs
go to a radio shack to find replacement knobs. get something called a "bar knob." this has a set screw which holds the knob on the thermo shaft. use a marker and print lo med high and off on the unit or use a brother p touch label maker.
Jan 10, 2008 | Fahrenheat Electric Convector Baseboard...
Honeywell HZ517 Baseboard Heater
You can try to disassemble the heater and look for something wrong like a loose wire: in order to do so: Unplug the heater and let it cool completely before disassembling it. Remove the rear grille and the control knobs. Remove the front grille by unscrewing the fasteners on the back of the housing. Remove the front grille by lifting the control housing and pulling the front grille toward you. The motor, fan, and heating element are now accessible for testing and repair. Remove the thermostat from the control housing and disconnect the wires. Remove the heat control's mounting screws and clips to access and disconnect wires. Good luck
Nov 28, 2005 | Honeywell HZ517 Baseboard Heater
Fahrenheat Built-In Baseboard Thermostat Heater Logo
768 people viewed this question
Top Fahrenheat Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
