Question about Kenmore Dryers
My Kenmore dryer just died on me! Nothing showing won't start. Model #796.40272900, serial #104KWVQCG983 purchased 6/30/11. Help!
    Top Expert:
  • Kenmore Master
  • 78,267 Answers
There is a fuse device called a thermal limiter, it is most likely open due to dust and dirt inside the cabinet of the dryer causing an overheat, remove the front of the dryer and locate the thermal limiter and replace it. You can get exact help and the part from this website, I use them myself. Appliance Parts Accessories Repair Help
Posted on Apr 20, 2017
  • 156 Answers
SOURCE: Purchasing a stackable dryer that fits on Kenmore/Frigidaire 417.44102300 washer
there still models out there from sears that go on the same way as the old one trust me i know 4 a fact
Posted on Mar 06, 2008
  • 20 Answers
SOURCE: Kenmore Electric Dryer
check your fuses.one runs the dryer and other heat the dryer.
check to see if belt is broke or wire is burned off of motor.
Posted on Mar 12, 2008
bozcro
  • 867 Answers
SOURCE: Kenmore dryer will not heat
only 2 things can be wrong, the heater element is toast or one of the safety thermostats is fried, most likely it is the heating element. make sure its well connected(while unplugged!!!)
Posted on Jun 14, 2009
pride applia
  • 232 Answers
SOURCE: Push the start button and nothing happens - no noise nothing.
check both thermal fueses, door switch, power relay, timer contacts if good, replace motor, do you have 220 volts at plug
Posted on Jul 01, 2009
heatman101
  • 43501 Answers
SOURCE: My series 80 Kenmore dryer won't start
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Aug 05, 2011
Kenmore he2 dryer, model: 110.c87561602 beeps twice, wont start and is not showing any error messages
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=MhVUEhngZMg
https://www.youtube.com/watch?v=9xD7lCXJ0ZM
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
What to Test When Whirlpool or Kenmore Dryer Won Start or Run Troubleshooting Why Your Dryer Won Start PartSelect com Kenmore Whirlpool Dryer Won Start Easy Fix
Jan 03, 2017 | Kenmore Dryers
Kenmore elite sensor smart electric dryer Model 110 65066500 I have power but won't start
Jun 24, 2014 | Kenmore Dryers
How can I fix my HE4 Gas dyer it will not start
Kenmore Whirlpool Dryer Won Start Easy Fix What to Test When Whirlpool or Kenmore Dryer Won Start or Run Kenmore Whirlpool Dryer Won Start Easy Fix
Jun 21, 2014 | Kenmore 659 Electric Dryer
try jumping the start button out on top if thats it ,replace it
Jan 15, 2013 | Kenmore Dryers
Gas dryer will not start. Model MGDB850WR0 maytag bravo gas dryer serial MY3101043 purchased 2009. lights and display come on, push buttons give tones, but nothing happens when you push start. Display...
heatman101
Aug 08, 2011 | Maytag Dryers
My Kenmore Dryer model # 110.65942401 will not start. The door switch seems fine. When I hold the start button in I can here the timer clicking, that's it. Any suggestions? Thanks!
Kenmore Whirlpool Dryer Won Start Easy Fix Troubleshooting Why Your Dryer Won Start PartSelect com What to Test When Whirlpool or Kenmore Dryer Won Start or Run
Apr 29, 2011 | Kenmore 659 Electric Dryer
Jun 26, 2009 | Kenmore 62602 Electric Dryer
Dryer won't start due to delay button lights up and won't go off
1. No power to the dryerMake sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
Nov 09, 2008 | Kenmore 659 Electric Dryer
Dryers Logo
27 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
