Question about The Audio Players & Recorders
With regard to my Tesco CR106R Clock Radio. Is there an undocumented instruction for turning down the display brightness.
    Top Expert:
  • The Master
  • 77,499 Answers
None that I can find.
Posted on Apr 20, 2017
Display not bright enough on Bose AWR1-1W clock radio
Yes...within a range. The display will automatically lighten and darken depending on the amount of light in the room. During the day or when there are bright lights in the room, the display will go to full brightness. When the lights go off or the room is otherwise darkened, the display will shift down to a lower brightness. You can make the "lower brightness" a bit brighter by holding down the CLOCK SET button and pressing the 'volume up' button.
Dec 26, 2013 | Bose Wave Am Fm Radio Awr1-1w Not Working...
Need instructions for tesco clock radio CR-106
Need instructions for settings my alarm clock tesco cr106r
Dec 13, 2011 | Audio Players & Recorders
Radio display is not bright
Press and hold alarm time for about a second, then press your tune/playlist button until your bright hi or bright lo choices display, once you chose which lighting you want, do not press anything else. It will set to your last selection.
Oct 31, 2010 | Bose Wave Radio
How do i set clock on pioneer deh 1800
here is the link to your manuals:
http://www.pioneer.co.uk/uk/support/manuals/DEH-1800R/index.html
no instruction in there for setting clock!
usually is the same here are the usual instructions:
Setting the clock
Use these instructions to set the clock.
1 Use MULTI-CONTROL to select Clock.
Clock appears in the display.
2 Push MULTI-CONTROL left or right to
select the segment of the clock display you
wish to set.
Pushing MULTI-CONTROL left or right will select
one segment of the clock display:
Hour—Minute
As you select segments of the clock display
the segment selected will blink.
3 Push MULTI-CONTROL up or down to
set the clock.
Pushing MULTI-CONTROL up will increase
the selected hour or minute. Pushing
MULTI-CONTROL down will decrease the selected
hour or minute.
Notes
! You can match the clock to a time signal by
pressing MULTI-CONTROL.
— If the minute is 00 to 29, the minutes are
rounded down. (e.g., 10:18 becomes
10:00.)
— If the minute is 30 to 59, the minutes are
rounded up. (e.g., 10:36 becomes 11:00.)
! Even when the sources are off, the clock display
appears on the display. Pressing CLOCK
when the sources and feature demo are off,
turns the clock display on or off.
Turning the clock display
on or off
You can turn the clock display on or off.
% Press CLOCK to turn the clock display
on or off.
Each press of CLOCK turns the clock display
on or off.
Note
appears on the display. Pressing CLOCK when
Note: on some models you can only set the clock with the clock on display and power off on radio.
Cheers!
Nov 10, 2009 | Pioneer DEH-1800 CD Player
Blue LED display too bright
TRY........with radio on and set on "AM", hold "Clock" button about 7 seconds and let up - bringing a setup menu. Using tuning knob,scroll to "Hardware". Press tuning knob in, bringing up contrast menu. Press tuning knob in, bringing up "contrast level". Turn tuning knob counter-clockwise to "00". Brightness, dimming level should be "170". Turn radio off to exit, then adjust "Dim" button to your liking.
Nov 02, 2008 | Boston Acoustics Recepter Clock Radio
Bose wave does'nt display light ' can't see the time, Help
Hi
I read that if you hold down the Clock Set button and use the volume adjust you can change the display brightness.
Hope this helps with your rpoblem
Aug 09, 2008 | Bose Wave Radio
Wave Radio-dial face,display very dim.
Our Bose did the same thing after a power outage. This one doesn't have a CD button, so we tried holding down the Clock button and used the volume control and that seems to have fixed it.
Mar 23, 2008 | Bose Wave Radio
Alarm clock won't change time with daylight savings
unless it is an automatic , atomic clock none I have ever owned do the change automatically
Feb 27, 2017 | RCA Audio Players & Recorders
Bose wave radio/cd
Found this in the manual:
To adjust the display brightness -
The display dims automatically to medium or low brightness, as appropriate for low light room conditions. You can adjust the brightness setting of the display for both strong light and lowest light environments, but not for the medium light setting. Turn the system off before setting brightness levels.
• In a strongly lit room, hold down CD Mode and press Volume up or down to adjust the setting between 5 and 9 (it is preset to 8).
• In a barely lit room, hold down CD Mode and press Volume up or down to adjust the setting between 1 and 5 (it is preset to 2).
• If you do not want the system to dim automatically, set both levels to 5.
Feb 25, 2007 | Bose Wave Radio
35 people viewed this question
Top The Audio Players & Recorders Experts
isojim
Level 1 Expert
 Sam R
Sam R
Level 1 Expert
obsteiner
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
