Question about Vacuums
How to remove tangled thread from the roller brush
    Top Expert:
  • Vacuums Master
  • 77,499 Answers
Cut it and remove it in pieces.
Posted on Apr 20, 2017
How can I remove the roller brush to clean it?
While not removing rollers, my method of cleaning them involves regular attention to prevent build up. Sometimes long hair or threads get wound so thickly & tightly the roller gets stuck & won't turn. If I can't unwind enough by pulling a few threads at a time, I'll cut a bit & pull it away a bit at a time until the mess pulls free. This is especially tedious if it gets caught at the edges in the rotation mechanism. That can be one piece of thread at a time, tugging gently & cutting away the jam until you can free it. As for the brushes themselves, sometimes a wide toothed comb will clear clumps of pet fur & rug lint from each strip of brush on the rollers, making it easier to see & remove long, wound tightly tangles.
Jan 17, 2016 | Vacuums
How do I fix my vacuum the brush will not spin
Lubricate each end of the roller brush with motor oil. Bearings inside the roller brush need lubrication for the brush to turn easily. Remove any pieces of thread that have wrapped around the roller brush. If it does not spin after doing the above steps, then either the belt is slipping or the bearings are severely damaged in the roller brush. Then you need either a smaller belt or a new roller brush.
Apr 26, 2015 | Dirt Devil UD40270RM Quick Power Compact...
How do I replace the drive belt
Hi, it's Allie from Crucial Vacuum!
Changing your belt is crucial in keeping your unit running efficiently. It is recommended for belts to be replaced every 6 months.
To get access to your unit's belt, your floor base should have two plastic screws that will allow you to remove the roller brush casing. After removing the casing, you will be able to see your roller brush, now it's a good chance to, with a pair of scissors, cut any tangled hair strands or left over debris that is tangled in your roller brush. There are also four more screws that need to be removed to get access to the belt and the clutch assembly.
The roller brush clips in onto the floor base with one clip on each side, you can gently but easily unclip it. Remove the cover on top of the belt and the bearings with a screwdriver, remove the bearing end caps to reveal your unit's belt to be replaced.
You can purchase direct your replacement bags and filters from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=S7260
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Alejandra (Allie) Sepulveda-Rivera
Crucial Vacuum Customer Care
Sep 23, 2014 | Miele Vacuums
Hoover vacuum cleaner - have suction in the hose, brush roller spins, but no suction when vacuuming carpet.
There is a clog or blockage in the channel near the roller or where the vacuum hinges at.
Unplug and turn it so that the bottom faces upward and use a screwdriver to open the bottom as you would to change belts. On most upright vacuums, it should only be two to four screws to remove the cover.
While the cover is removed, see if you can spot any noticable obstructions from there. While it is opened, it may also be a good idea to use a pick, screwdriver, or whatever may be handy to pull out any threads, strings or hair that could get tangled around the roller and brushes, to improve performance and last longer. In some cases or on some models, you may need to use a piece of wire or something, bent like a small hook, to reach up into the suction channels a bit to pull out any possible obstructions.
Also check along the path to see if there are other parts that you feel would be easy enough to open and clean out, but only so far as you feel confident in doing yourself, and be sure to not lose any screws and remember where they all go.
Oct 15, 2013 | Vacuums
Beater bar belt install
  • 1
    Unplug the vacuum cleaner and turn it upside down, flat on the floor, with the roller brush facing up.
  • 2
    Remove the the bottom cover plate from the vacuum by prying it off gently with a screwdriver blade. Set aside the cover plate.
  • 3
    If the old belt is broke, remove it by pulling the belt from underneath the roller bush. If the belt is not broken but simply worn out, and is still attached, cut it off with scissors.
  • 4
    Remove the roller brush by lifting both ends from the grooved slots in the housing of the vacuum cleaner.
  • 5
    Cut away hair, thread, string and other debris wound around the roller, using the scissors. Tangles on the roller brush are a common reason for belt wear and breakdowns due to the added weight and stress on the roller brush.
  • 6
    Slip the replacement belt over the roller brush and seat the belt in the groove in the center of the roller.
  • 7
    Slide the roller brush back into the grooved mounts on either side of the housing and snap into place.
  • 8
    Pull back on the new belt and slip the loop over the pulley attached to the vacuum motor.
  • 9
    Replace the bottom cover by snapping it back on the housing until it clicks into place.
  • Feb 16, 2011 | Hoover UH70015 Bagless Upright Cyclonic...
    I ran over a big floor rug with my vacuum and some of the strings from the rug got tangled in the roller on the vacuum. It makes a terribly loud noise even now after I have cleared the strings from the...
    You will need to pull the roller out and clean it. I think some of the strings are tangle up at the end of this roller. (Most rollers will come apart at the end for cleaning.) Make sure that the strings are not tangle up on the belt pulley as well. I hope this will help you.
    Jan 25, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
    Just purchased this Dyson dc24 today. brush doesn't spin after gettin tangled in a cord. removed the cord from the brush OK. I have several times: removed the brush and replaced it OK. pushed the red...
    When you removed the brush roller dod you examine the end of the actual roller that is opposite from the removal opening. There is a gear that the roller fits over that may have gotten stripped when it became tangled. Check that the gear has not rounded off and look inside the roller bar to see if the area where the gear fits into may have gotten stripped as well. You might try to operate the vacuum without the roller brush installed for a few seconds just to see if the gear turns. When I say gear, it is actually a somall "post" about 1-2" long that the roller brush fits over. Hope this helps!
    Dec 17, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
    The brush roller is not rotating on my Kenmore Whispertone. It will pick up on floor surfaces. Help!
    Be sure that there are no fibers wound around the roller or lodged in the wheel well of the brush roller. That is usually the cause of a brush roller not rotating. You might need to use scissors to clip the fibers and then pull them from the roller. The fibers might range from human and pet hair to carpet fibers, threads, string, yarn, embroidery floss. They wind around the roller and eventually "tighten up" so that the rotator will not move. I have found that, depending on my current craft project, I may have quilting thread, knitting yarn, embroidery floss, or other such goodies wrapped around the roller. When our daughters were at home we would have long, beautiful blonde hair tangled in the roller. I hope this helps.
    Nov 10, 2010 | Kenmore 23313 Whispertone Bagged Canister...
    Bissell lift off, brush won't move smell burning rubber belt fine
    OK - so your brush roller is jammed. And yes, the belt is melting! Unplug the machine, remove the belt (you will need another new one anyway) then see if you can turn the roller by hand. If it turns freely without you doing anything else, then you may have put the new belt in incorrectly. However, you will probably find you can't turn it, or it's hard work (it should rotate freely). Remove the roller and check the bearings - there may well be something tangled up at one end of the roller. If you can get the roller rotating freely, all should be well.
    Good luck
    Mar 08, 2009 | Bissell 6595 Lift Off Bagless Upright...
    Bissel Healthy Home vac brush/roller is jammed, cannot be rotated
    You'll need to take the bottom plate off, remove the roller, remove the belt, and pull out whatever may be clogging the rollers on the side of the brush/roller.
    Can you give us a model name for your vacuum? I can give you more details on how to remove the roller.
    Usually a pair of needle nose pliers can help with this.
    It happens when hair, carpet fibers, and other fun things get tied up and tangled around the sides.
    Best Wishes
    Nov 03, 2008 | Bissell Vacuums
    Vacuums Logo
    Top Vacuums Experts
    AskDyson
    AskDyson
    D. Floyd Kolb
    D. Floyd Kolb
    Are you a Vacuum Expert? Answer questions, earn points and help others
