Question about Irons
My steam station is surging steam from the base not from the bottom of the iron I'm wondering why
It's a Russell Hobbs revolution
smilemaker
  • 790 Answers
SOURCE: Faulty Russell Hobbs Steam Iron
http://www.ehow.com/how_2067318_fix-nonelectric-steam-iron.html
Posted on Jan 01, 2008
SOURCE: Russell Hobbs Steam Glide 2200 won't produce steam.
I had a problem and tracked it down to the pump. If you take the iron apart, the pump sits towards the front of the iron and has 3 tubes connected to it. Remove the srew-down bracket and free the pump from the plastic clasps on the base. Disconnect tubes and wires (remembering where they go.
Remove the circular securing spring from the front of the pump and drop the metal barrel from the housing. Unscrew the rear plastic assembly and set aside. there is a joint inside where the plastic assembly was - this is has an o-ring and is simply a pull-apart. It deos not need screwing. Pull the metal barrel apart, taking care to note the sequence for reassembly. Inside the barel is a larger rubber washer. Pull on the metal tube that goes through the centre of the washer using a pair of pliers - it will come free.
You will then see the problem - the spring inside the metal barrel will have broken. Take care, because at the other end of the spring is a small plastic washer that must be retained. Find a pen that has a short spring inside and use this as a replacement. If necessary, you can trim the spring to make it the right lenght. Ensure you have removed all broken pieces of spring, and reassemble. Try it out before finally attaching the pump inside the iron. It took me 2-3 attempts to get the spring tension right. If you can find a 'PENAC RB-085B BA1002' pen, the spring is perfect.
Once you have got it right, reassemble.
I have to replace the spring approx every 6 months as the replacement is obviously not meant for the job and wears or rusts or breaks. However, I am getting extended use from my otherwise broken iron.
Take care - things inside get HOT!!
Hope this helps.
Posted on Dec 17, 2008
  • 378 Answers
SOURCE: no steam
its due to not getting appropriate required current to the main board of the unit.also check out any thing got loose on the board .first off all try doing dry /cold solder to whole board it should work if not then check out for the proper current flowing through the resistors mostly 1 of them may be definately faulty and needs replacement. thanks.
Posted on Jan 04, 2009
brnspncr
  • 67 Answers
SOURCE: digital revolution iron squirts brown water onto my clothes
Try an iron cleaning fluid or crystals. you can get the stuff at wallmart or similar stores. It usually works. Try using distilled water in the iron.
Posted on Aug 04, 2009
bozcro
  • 867 Answers
SOURCE: Russell Hobbs Steamglide 2200.Iron and steam
is the water in your area heavy? it may have clogged your iron with stone. soak plate in something like clr .
Posted on Aug 10, 2009
My Iron heats up but no steam comes out and no noise please help !! Russell Hobbs steam 2200
If the water used is hard it will build up with shale, and block the steam vents, best to flush with clean water after every second use . Best to take to the dealer and have it serviced .
Jul 10, 2015 | Russell Hobbs Irons
Lights come on when plugged in, doesn't heat up and has a beeping sound , colour panel is red thankyou
Read the operator's instructions. They are available of the Russell Hobbs site or by contacting Russell Hobbs UK on-line through the "Contact" link. In most cases, steam irons tend to clog with hard water deposits and need to be de-scaled from time to time. If that doesn't help you, buy a new iron. Rowenta's seem to perform best.
Apr 09, 2015 | Russell Hobbs Irons
I have so far seen 3 other people with the problem i have with my russell hobbs steam glide iron 13153. I have tried what was suggested to me but nothing has worked. the iron gets hot but no steam coming...
I would write to russell hobbs and complain, my friend bought one of these 18 months ago and hers got hot but no steam through. She sent it back to them and they sent her a new one as a gesture of goodwill.
Aug 04, 2011 | Russell Hobbs 13153 Iron
I am trying to find a replacement filter for the russell hobbs steam station Model RHTC102ST
where can i purchase a filter for Russell Hobbs steam station model rhtc102st
Mar 19, 2010 | Irons
Russell Hobbs Steamglide 2200.Iron and steam station seem to be heating correctly, but will not dispense steam when trigger on iron pressed.
Aug 10, 2009 | Irons
Irons Logo
60 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
