My top loader machine starts to spin and then switches off with a message power cut restarting in 10 seconds and keeps doing the same thing? What does this mean ! Thank you
SOURCE: washing machine lid switch
used my noggin and saved $20-00
Posted on Dec 29, 2008
  • 144 Answers
SOURCE: The machine does not work
Ok this fault is telling me you have a faulty RPS(Rotor Positioning Sensor) in this machine. The RPS sensor is located in the motor Stator. To replace you need to remove the motor rotor then the motor Stator. you want to be careful with this part when fitting it as they can break.
Please rate my advice.
Posted on Mar 25, 2009
  • 10 Answers
SOURCE: pressure washer keeps cutting out
Carb problems: needle seat is sticking!
Posted on Dec 11, 2009
  • 33 Answers
SOURCE: Treadmill cuts out after 10 seconds and gives an E1 message.
Your problem might be that a magnet has fallen out of place. Here's an illustrated guide that should make fixing it easy:
Good luck.
Posted on Oct 09, 2010
  • 15 Answers
SOURCE: Washer agitates, drains OK, but spin doesn't start
Posted on Jan 18, 2013
All lights flash display reads "power out self reset in 10 seconds".
Display reads power cut restart in 10 seconds
The motor controller board has a switch mode power supply problem.
Best to get a new motor controller board Or a technician to look at it.
Look at the 6 digit part number under the bar code to get the right part for your machine.
Nov 22, 2013 | Fisher Paykel Eco IWL16
Fisher & Paykel IWL 16 shuts off during all cycles.
I says power cut restarting in 10 seconds
I'm sorry, it is the board, the switch mode power supply is dying.
Every time it starts to do something it power cuts.
Best to get a new motor controller board,
Quote the 6 digit part number under the bar code to get the right part.
Mar 25, 2013 | Fisher Paykel Eco IWL16
Whirlpool top loader washer will not spin
Could be one of several different things depending on the age and model. If its less than 10 years old and is a top load washer its probably a motor coupling (connects the motor to the transmission kinda like a belt) or lid switch. If the water is draining out but the washer is not spinning its probably the motor coupling. If it still has water in it and won't spin, its probably the lid switch. If your washer is a front loader there could be several things going on. Hope that helps.
Aug 29, 2011 | Whirlpool Washing Machines
Simpson ezi sensor 8.0 kg won't spin lid lock flashes and alarms
To solve the beeping and lid lock light flashing and the machine not doing a spin dry. Do the following.
I have a SIMPSON EZI SENSOR 8Kg top loader. This is what I did.
WARNING HIGH VOLTAGE. switch the power off and unplug the machine.
DO NOT do this if you are not familiar with working with high voltages.
To get access to the lid lock switch,
1. Remove 2 screws at the rear of the washer.
2. Remove 2 screws at the front of the machine located under the lid and covered by small round plastic plugs.
The top cover can now be raised gently from the front.
3. Remove the 2 screws that hold the lid switch.
4. Remove the clear plastic cover from the lid switch.
5. DANGER HIGH VOLTAGE ( Verify that power is off)
6. Find 2 blue wires these go to a magnetic reed switch (25mm long 3mm Diameter).
Cut the blue wires and discard the reed switch. insulate the ends of the blue wires and push them back into the track in different directions so there is no possibility that they can make contact with each other.
7. Find 2 white wires these go to a set of contacts that are mechanically closed by the solenoid.
8. Pull out the contacts and the 2 white wires.
9. Cut the white wires at the contacts, strip 5mm of plastic off the wires and twist them together, The wires will have corrosion, clean them with sand paper, they must make good contact. I recommend that you solder them together.
10. Insulate them and push them back into the track.
11.Reassemble starting with fitting the clear plastic cover.
Your good to go BUT BUT BUT,
The Lid safety protecting during the spin dry cycle will no longer function,
So don't do this if you need the safety of the lid closed during the spin cycle.
Remove 2 screws at the back of the machine
Jul 30, 2010 | Fisher and Paykel IWL12 Top Load Washer
GE profile top loader, agitator and spin start and stop
Is this a newer model washer? I have one of the newer models and it does the same thing. It is supposed to do that.
May 23, 2017 | GE Profile Prodigy WPSE4200A
Machine won't spin... Machine gets water,
only be one thing, the wig-wags are not shifting transmission into spin if everything else seems ok in operation
Aug 23, 2009 | Washing Machines
Lenvo blue screen error message when computer starts up
Please try to unplug the laptop from power and remove the battery for over 10 seconds. Then start it up again. There are other things we can try if this does not work.
Mar 19, 2009 | Lenovo 3000 N200 Notebook
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Feb 09, 2009 | Kenmore 23822 Top Load Washer
Kenmore top loader
Hi I see your having the washing machine won't spin problem. The first thing I would sugest is to disconect the AC power from the machine. The next step is to remove the front panel from the machine. Look at the top lid for a plastic tip that fits into a keyhole in frame. Underneath there there's a safty switch. This switch is designed to stop the machine from spinning if the lid is open. Sometimes the switch gets corroded over the years. It may have to be replaced or adjusted to align with the plastic tip whin the lid is closed. The black thing hanging down from the motor you described could just be some electrical tape the manufacture uses the bundle the wires from the motor. Some manufactures use a spring to keep the wires from the motor from interfering with any moving parts. Hope this helps.
Sep 06, 2007 | Washing Machines
My old Hoover top loader Washer is noisy & doesn't spin out properly - how can I fix it?
Sounds like the switch which cuts the machine off when the load is unbalanced. My guess is that: This switch is being triggered too easily The springs holding the bowl up are either stretched or one is broken; The machine may not be level.
Mar 30, 2007 | Hoover HTC243 Top Load Washer
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
