Question about Refrigerators
Where can I get a new front handle for a Gold Star mini frig model GR1310W?
    Top Expert:
  • Refrigerators Master
  • 74,945 Answers
Nexgrill gasgrill model 270-0665 the mini frig
Vincent, NexGrill reportedly had some issues with the frig. So your best bet is to contact them directly.800.913.8999 for ways to troubleshoot & solve this problem.
Happy Grilling!!
Jun 24, 2011 | Grilling
My hotpoint washing machine (model wma50) will not start due to the door lock light flashing yet the door is closed
common problem on these machine's, you need a new door handle which comes as a full assembley with spring and all attached.
open the door, using star screw driver remove top and bottom screws along with two near the catch.
the doo wil split enough to remove old handle and fit new 1.
Oct 16, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
I can't get the water filter out of my Whirlpool gold side by side. Help
The water filter should be at the bottom of the refrigerator. You don't even have to open the doors.
You will either have a push button filter or a twist filter. I will walk you through the twist filter first.
At the bottom of the front of the frig, you will see a turn handle. This is the filter. What you need to do is turn the handle a quarter turn (90 degrees) counter clockwise. This will release the filter. Simply pull it out. the handle will slide off the front (this is what you were using to turn the filter). You must keep this and put it on the new filter in the same fashion.
The push button filter is in the same spot, only instead of turning it you push the button and it should pop out. Pull it out and save the cap! The cap goes on the new filter you install.
If you have located the filter but are having actual difficulties removing it because it is stuck, the only advice i have is be careful not to hurt your fingers! Applying slow pressure in a pulling fashion will generally relieve it. If I can be of further assistance let me know!
These filter generally cost between $35 and $40 at your local retailer.
May 29, 2010 | Whirlpool Refrigerators
How do you change the water filter?
It looks like the water filter is at the bottom of the refrigerator. You don't even have to open the doors.
These filter generally cost between $35 and $40 at your local retailer. Ask for a filter number 4396508.
May 28, 2010 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Need a part number
The part number for the door handle on this model dishwasher is either:
W10142998 (STAINLESS)
W10142999 (BLACK)
W10143000 (WHITE)
The handle is listed as item 14 under the "Door and Panel Parts" section at searspartsdirect.com. The part numbers are based on the color, so make sure you use the correct number to get the matching handle for your dishwasher. The kit inlcudes all the mounting hardware as well.
You can check these others sites as well to compare prices:
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
If you have any questions, please let me know. I hope this helps you.
Dec 29, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool Refrigerator water leak through Ice dispenser
You need to remove the ice maker and open the front carefully. It has small micro switches inside it and it sounds like one that opens the water control valve is stuck in the on position. Be careful not to loose the arm spring and how that goes back together as you take it apart. Sea Breeze
Sep 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Frig handles have yellowed
Hey there, check out the link, it brings up a list of parts including the handles. All the parts are for your fridge. Good Luck
seth
http://www.repairclinic.com/Appliance-Parts?s=t-gss25jfmdww+-%3d%3dc226
Jun 26, 2009 | GE GSS25JFM Side by Side Refrigerator
Uneven doors on a new whirlpool gold frigerator
You need to adjust the rollers on the front of the unit. This will even up your doors.
Apr 11, 2009 | Whirlpool GS5SHGXKQ 25.3 Cu. Ft. Gold Side...
Loose door handle GE two door freezer/frig model TFG 22JADAWW
Called and watched mechanic who clipped of top and bottom covers with a screw driver then tightened both screws and replaced covers. Cost was $100 but I could have wrecked the door. Needs a special little star shaped screw driver head with ratchet fitting. Now equipped for next time.
Jun 22, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
