Question about Garden
Have hush arena model gth2448t blade clutch will come on after 10 -15 min mowing it will shut off no power at clutch . Does it have a relay can not find one. Wondering about if it is in pop switch?
  • yadayada
    yadayada Apr 20, 2017
    Is this a cordless electric?
  • 3 Answers
SOURCE: Mower runs for 10-15 mins. then shuts off.
I would agree with the gas cap being the problem. There should be a insert inside the cap which helps with the tap pressure. If this is lost then the engine will run for a few min. and shut off.
There is one other thing and that is the float in the carb bowl. It may be allowing in just enough gas to fill the bowl and then it is sticking. This would account for just enough fuel to run for a brief period and then shut down.
Posted on Mar 10, 2009
SOURCE: My Cub Cadet 2135 PTO won't engage.
i had the same thing happen
found that the on/off switch had come unplugged from the wire harness just below the switch
had to attach the wires to something underneath so the weight did not pull the wires down and taped the two switches together to prevent it from pulling apart
it needs some kind of clip to hold them together
hope that this works for you
Posted on May 24, 2009
SOURCE: LTX1000 42" 18HP Kohler - Blowing fuse after 2-4 min mowing.
i hav a 18hp ohv eng. back fires and gas is coming out of muffler.
Posted on Jul 18, 2009
  • 43501 Answers
SOURCE: PTO problem on a model
I would be looking at the ignition switch....but before replacing it I would be looking for a friend with an electrical meter and checking the wiring for power coming out of the switch to the cluthch, this way you can narrow it down positively before buying parts.
Posted on Jun 18, 2011
  • 425 Answers
SOURCE: electric blade clutch won't work and battery went dead
If you have a new battery and it went dead that quickly I would check the charging system on the mower engine. Many of them use a voltage regulator and if it goes bad it will not properly charge the battery. Get the engine running (do not engage the PTO) and use a multimeter set on DC voltage. Place the multimeter leads on the battery and you should see approximately 13-14 volts DC at the battery terminals when it is running. If less then that then it's a problem with the charging system and further tests would be needed to figure out if it is a bad regulator or charging coil.
Posted on Aug 24, 2012
Testimonial: "I think that's it, the clutch was just a symptom of low voltage maybe. checked two leads from the alternator and got 31 volts ac from each. Hoping then it is the regulator."
Ok so the problem,on my gravely zt 2250 is was mowing went to shut blades off and they kept on spinning and there also spinning when trying start engine replaced clutch twice still same problem
Sound like either the PTO relay is struck in run position or the PTO switch has failed and applying 12v to the PTO relay even in the off position.
IPLs for the Gravely ZT2250
Nov 24, 2014 | Garden
Why would blades just stop when mowing with ex mark lazer Z (model lz25kc604) I had beeing mowing for about 6 hours. Then it just stopped
It sound like the PTO clutch has died.
Test your PTO clutch. It should have a resistance of 1.7 to 2.5 ohms.
Jul 27, 2014 | Garden
Mower blades will not engage when hot
overheating safetybsprings are wore out. they either got over heated or reached their limits
Jul 24, 2014 | Cub Cadet Garden
John deere l120 mower deck just quits after 20 min mowing or may work ok for 4 hrs?
The blades only turn when the electric clutch is engaged. Sounds like you may have a short in the wiring possibly at a terminal that is shutting down the clutch. Or it might be in the "reverse button" you have to push to keep the blades turning when you back up. Try holding in on the button when it stops and see if they start back up. I think it's definitely in the wiring somewhere.
May 16, 2014 | Garden
Blades wont engage
Check for power to the clutch from the switch or could be a bad relay
Jun 16, 2013 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Tractor quits when engaging the blades
unhook clutch and see if blades stop turnig and then try engage clutch with the switch if motor stays running bad clutch
Jun 01, 2013 | Mtd Garden
Dies when try to engage blade
there is a switch underneath seat that shuts blades off if not pushed down or there is another one on the reverse that shuts off blades off when mowing one could have went bad hope it helps
Apr 16, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
JD STX38 PTO disengages and melts the PTO switch? As I'm mowing along the blades disengage and then I push the PTO switch down and back up and the yellow button comes out and shows the bottom of it...
Electric Blade Clutch is shorted or if you are lucky the wiring to the clutch is grounded. Many times the wiring to the clutch is caught in debris or twigs etc. and pulls the wiring out and cuts and grounds it.
Aug 25, 2017 | Garden
sounds as though you are on the right track
but be sure to check the wiring directly from the electric clutch on the front of the motor back to the switch
a wire could be pinched in the frame and shorting out intermittingly
look around and find those wires and move them around and look for chaffing and tightness
and what you could also do is to unhook the clutch at the connection to it at the front of the motor and engage switch and ride around and see if fuse blows and if not you may have an electric clutch issue
Jun 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
