Question about Brother Office Equipment & Supplies
Brother MFC490cw Printer shows offline. No options to print in driver.
  • 1,959 Answers
Right-click on the printer in the folder and uncheck the "Use Printer Offline" option to place your printer online and available.
Posted on Jul 25, 2009
  • Greg Margossian
    Greg Margossian Jul 27, 2009
    A printer may also appear "offline" if for some reason it was unable to complete the last print job. Double click on the printer in the printer folder (make sure it is listed as the default printer) and click on properties. If for some reason the printer is not listed as default, click on default. If there's a job in the print queue, you should see an option to resume printing or you can "cancel all documents". Either way, if somehow the printer has been paused, you will need ot resume printing to put your printer back online.
Double images
1.From the menu bar of an application, clickFile=>Print.
Check your printer name is chosen and clickProperties.
ClickAdvancedtab and thenOther Print Options.
ClickImprove Print Outputand check theReduce Ghostingbox.
  1. ClickOKto close theOther Print Optionsdialogue.
  2. ClickOKto close thePropertiesdialogue.
  3. ClickOK. The document will be printed.
  1. Choose "Print" from theFilemenu and open thePrint dialogue.
  2. Choose "Print Settings" from the print options pop-up menu.
  3. Click Advancedand thenImprove Print Output....
Check theReduce Ghostingbox.
  • ClickOK.
  • ClickPrint.
  • Still having Problem Then follow Us For Brother Printer Support
  • Nov 18, 2013 | Brother 1 Magenta Mfc490cw Mfc-490cw...
    Brother HL-2270DW printer shows offline and won't print
    I had this problem today with my wireless Brother MFC-990CW using Windows 7, and when I went to see what s printing, then printer, it wasn t showing that I had checked the use printer off-line
    So, on my pc I went to the start button then chose:
    - Computer
    - Network
    - Double click your printer
    - New print drivers will start to install
    - Right click the icon that is a copy made of your printer setup
    - Set this as your default printer
    I was then able to print and my printer didn t show as being off-line anymore. This is a lot easier than having to uninstall and install the printer again using the disc.
    Source(s):
    https://answers.yahoo.com/question/index?qid=20140422184955AA0dJ7F
    Jun 27, 2012 | Brother HL-2040 Laser Printer
    Print driver (2228C PCL 5C) shows printer queue offline. How can I bring it back online? I have rebooted the printer. There dosen't appear to be an option on the print queue when going in as admin on...
    Remove the data cable from the back or size of the printer. Turn the printer on and let it cycle. Then plug back in the data cable. It should show a green light by the cable if you are reconnected.
    May 12, 2011 | Ricoh Aficio 2228C Copier
    Keeps showing offline even though I put in new cartridges and it cleans. When I test print, I have to do it manually and the paper comes out blank. When I check the ink status for some reason it shows...
    First unplug your printer from the computer then uninstall you installed driver . After that plug it to the computer and install driver again. Then restrat your computer after successfully instalation. If still now ggive the problem then install driver from the below link and install it.
    http://download.cnet.com/Brother-MFC-240C-USB/3000-2110_4-99329.html
    hopefully it will be work. Other wise go to the servicing center.
    May 04, 2011 | Computers & Internet
    Brother MFC-7340 Status monitor offline
    Is it giving any errors when you try to print?
    Sep 22, 2017 | Brother MFC 7420 All-In-One Laser Printer
    I have a inspiron 1525 hooked wirelesly to my broter mfc490cw the comuter recognizes the printer and says ready and the printer is connected to the network but when i print it flashes recieving data and...
    HI,
    The following thing to be checked for not printing are as follows:
    • Check that the correct printer driver has been installed and chosen
    • Make sure that the machine is online. Click Start and then Printers and Faxes.Right-click and choose Brother MFC-465 ,and make sure that Use Printer Offline is unchecked
    • One or more ink cartridges can be emptied, so you dont get printed, check for that and if found replace the catridge
    If all the above said is found correct, the drivers may be corrupted, uninstal the existing driver and reinatll it once again, it should solve your issue..
    Please leave me comment, if you need further assistance
    Rnj VINODKUMAR
    Oct 31, 2009 | Brother MFC-465CN InkJet Printer
    Brother mfc490cw printer show offline and erro
    Hello there:
    for the document you want to print click on print and your printer should show up now just click on the printer and look down where it says use printer offline and click on it again and than it will say use printer online and just print from there ok please dont forget to rate this solution for me
    best regards mike
    Aug 06, 2009 | Office Equipment & Supplies
    My brother laser printer 2170w is saying it's offline and I have no idea how to get it back online
    just right click your printer icon in printer properties.it will pop out some options.in that options it will also pop out the offline option just click that offline option it will turn in to online option.if u find it hard just uninstall the printer drivers and reinstall it again from the printer driver installation cd.it will work properly.
    thanks.
    Dec 15, 2008 | Brother HL-2170W Laser Printer
    Printer online then offline
    My first solotution was to reinstall the printer as a new printer. But that is uncessary. The fix is as easy as changing the IP address the in Port.
    The problem is the the IP address for your wirelss is not static. and when it changes, the printer does not recognize the new IP address. When this occurs. go the the printer folder ( in the control panel) and click on 'add new priter'. Then select 'add a network wirless printer . NO NEED TO INSTALL THE PRINTER...you just want to see the IP address.
    Note the IP address.
    GO to the printer, click on the right mouse and select 'properties'
    Click on Port
    You will see the current port already highlighted.
    Click on ' configure port' and change the IP address under "printer name or IP address.
    Click OK.
    Problem solved
    Good luck.
    DeniseA
    Mar 01, 2008 | Brother MFC 420CN All-In-One InkJet...
    381 people viewed this question
    James Cagle
    James Cagle
    Samyfam
    Samyfam
    Victorman
    Victorman
