Question about Cameras
Nd5 will not focus down to a point.
The focus function works but will not allow the laser to focus to a point anymore.
2 Suggested Answers
  • 9472 Answers
SOURCE: laser genetics nd3 and nd5 subzero act up in cold weather?
Could you please describe the problem you are having a little better?
Posted on Nov 22, 2012
My samsung es80 does not make sharp pictures anymore
Difficult to go on only does not make sharp pictures anymore.
Seeing one picture says more than 1000 words. Still I give it a try.
When you are sure you did not change the focus settings and don't switch over to macro settings, while shooting normal, I can't help. But I do advice to look in the manual on page 41 and put the camera in Auto focus. (Not one of the macro modes) then when shooting, wait till the camera has focused, while you pressed the shutter realise button half. When the camera is in focus, the square in the middle of the screen becomes green, press the button down. (without moving the camera)
Also select a high resolution (big photo size) because small photo size is easy seen as a blurred picture.
Feb 17, 2014 | Cameras
The Magic Focus does not work anymore.
The convergence has failed on your TV and will need to be repaired. You can call a shop or do it your self with a convergence repair kit from sites such as . This is a failry common problem that all projection TV sets will have at some point.
Apr 21, 2013 | Hitachi 51F500 51" Rear Projection...
Laser genetics nd3 and nd5 subzero act up in cold weather?
Nov 21, 2012 | Refrigerators
The heater dont work on my 2004 gmc sierra 1500, engine(4.8) only the AC works in it... but the heater not anymore.... please help... and also the temperature gauge not working, it's only pointing...
it sounds like a heater door actuator is not allowing the door to swing into the heat for the temp gauge there is a recall for a bad insterment cluster for that truck...a circuit board is cracked in the dash not allowing the gauge to a GM dealer to get more info on this recall...the heat problem can be easliy fixed at any qualified service station
Jul 16, 2011 | 2004 GMC Sierra 1500 Crew Cab
We have a Bush DVD Player DVD2041 which has been working with existing discs (not new). Now when we place the disc in the disc tray if acknowledges by 'Loading' but then says 'Wrong disc' and does not...
I dare say the laser assembly is out of allignment or low power and cannot focus correctly anymore.
Replacement is the answer. They are so cheap to buy that a repair will cost more than replacement, unless still under warranty of course.
Dec 23, 2010 | Televison & Video
Is this the one i need to buy RCA Discwasher 1-Brush Dry CD/DVD Laser Lens Cleaner
NOT RECOMMENDED! The laser lens is designed to NOT touch anything while it is functioning - moving up and down to focus on light reflection from the CD or DVD disc. These gimmicks can knock the lens off the laser.
Dec 15, 2010 | Nintendo Wii Console
My camera won't focus anymore. Any thing i can do?
Inside the lens assembly is the focusing ring. When dirt, dust, lint, or sand work their way inside it can jam the circular geared movement necessary to focus the camera. The ring has two electromagnets on it, controlled by signals and feedback from the main board, to achieve focusing. To try to fix this, try to spray some compressed air into the lens assembly, holding the camera upside down. If that doesn't help, try different points around the lens. After trying that, you can try to bump the camera slightly, to try and dislodge a stubborn jam. sometimes the ring has sprung off its track, and you can reseat it by gently knocking it back into place. Hold the camera with the lens facing up when you do this. Otherwise, it's not a cheap fix, so get an estimate before you have it serviced. You can do it yourself, if you're inclined, and there are a lot of videos and information on YouTube. Good luck, and hope this helps.
Jul 26, 2010 | Canon PowerShot SD600 Digital Camera
You need to change the drum on your printer. Part # DR-350.
Thanks and please take a moment to rate as fixya.
Nov 06, 2008 | Brother MFC-7220 All-In-One Laser Printer
Autofocus jumps around and often will not settle on the correct setting
what i do is usually put it onto manual focus then back to auto focus, what it may be is that you are using the wrong lens for your subject :/
Feb 27, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Cameras Logo
29 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
