My remote the power button works but nothing else..
My harbor breeze ceiling wont turn on.
  • Disconnect power at the source, not at the fan
  • Remove battery from remote. Press all buttons, then reinstall battery
  • Restore power. Using ONLY the remote, test operation
  • If the fan still does not work, disconnect power again and try every known combination of remote buttons and switch settings until the fan works or you give up in frustration.
Mar 13, 2017 | Dryers
Sony s master digital amplifier 5.1 ch
Do the other functions on your remote work? It's possible that the power switch is faulty. That's the most frequently used button and so the first to wear out.
Dec 15, 2013 | Audio Players & Recorders
I can't power my TV on or off with the remote control
If you can turn it on with the power button on the set;
either the remote control is not working,
or the TV is not receiving the signal (light) from the remote,
or the circuitry inside the TV is not processing the remote signal.
If the power button on the TV works.
1. replace the batteries in the remote (again)
2. make sure there is nothing in front of the TV
Apr 01, 2013 | Symphonic ST413C 13" TV
Remote control work very slowly and sometime do not work
Please follow the troubleshooting steps:
  1. Remove the batteries from the remote control.
  2. Press each button on the remote control twice.
  3. Make sure none of the buttons on the remote control are jammed.
  4. Install fresh batteries into the remote control.
  5. Make sure nothing is blocking the Infrared (IR) sensor on the TV.
  6. On the remote control, press the TV FUNCTION button.
  7. Press the POWER button and other buttons to test the operation.
  8. Try using the remote control at varying distances from the TV.
  9. Power reset the TV by follow the steps:
  • Unplug the television power cord from the electrical outlet.
  • Let the television remain without power for 60 seconds.
  • Plug the power cord back into the electrical outlet.
Jan 09, 2011 | Philips 32PF9964 32 in. Television
My samsung remote for my blu ray player stopped working for my samsung TV today. i have never had this problem before. it still works on the blu ray player which then turns on the TV like it is supposed...
On blu ray remote control hold down TV Power+01 at the same time. If the TV turns off the controller is programmed. If not, try TV Power+02, +03, +04, +05, +06, +07, +08, +09. Different TV BRAND??? ...TRY
Sep 16, 2010 | Samsung TV Remote Control
Bn59 00463 volume works nothing else cant turn on
Step 1: Remove the batteries
Step 2: Press the power button (red button) on the remote control 5 times.
Step 3: Replace the batteries and your remote should work fine.
Oct 20, 2009 | Samsung Televison & Video
Power button stopped working and no remote
you can get a programable remote to get around that.
Feb 12, 2009 | Philips Magnavox 27MS343S 27" TV
My LG remote control is not working
Make sure you push the TV button on the top of the remote before you push the power on button.
Dec 17, 2008 | Televison & Video
How to set codes on my px-rc1 remote
Hey finally I found myself how to set the code... I have a PX-RC1 kind a noname remote at XScargo anyway...
Press SET BUTTON and at the same time, the appliance you want to set( TV, VCR,Aux...etc). The LED shoould stay on.. then press on the SET BUTTON again ... the led will blink fast... then press ( in front of TV, of else).. the POWER BUTTON to see what happens, if nothing happens, then press the +CHANNEL BUTTON once, and press power again. Repeat this until it turn off. THen press the appliance button (VCR,TV,AUX, etc...), this will stop the LED to blink and your appliance will be set.. I guess if it doesn't work good, go further onto the code with the +CHANNEL BUTTON (better count it in case you go too far, for myself I went too far and tried to use the -BUTTON and didn't work)
May 18, 2008 | Universal Remote Control MX-500 LCD Remote...
Programming the remote
1. Hold on TV and POWER simultaneously (light comes on), let go
2. Press POWER then CH+ back and forth (light comes on), when TV turns off
3. press STOP, code is saved!
Oct 22, 2007 | RCA RCR412C Remote Control
Televison & Video Logo
Top Televison & Video Experts
