Question about Pool & Spa
How much Sand goes into my SF15110 Snad Filter
    Top Expert:
  • Pool & Spa Master
  • 5,673 Answers
Bad laterals replace or replace filter
Posted on Sep 13, 2017
3 Suggested Answers
john224
  • 1378 Answers
SOURCE: Since day 1 I have has sand in my filter Have
Sand in your filter or sand in your pool? A common mistake when installing these is not to fill them half way with water prior to filling the tank with sand. Failure to do so often leads to cracks in the lateral assembly and sand in the pool. If that is the case you'll need a new lateral assembly, part #SX210DA. Depending on how long ago it was installed and who installed it you may be able to get the part under warranty. If not it runs about $45.
The filter takes 200# of sand. Your product tag should confirm this with a statement of something like "media required: 200#" or something similar.
John
Posted on Mar 23, 2011
Geekman
  • 32281 Answers
SOURCE: why is the sand going back into the water Intex Sf15110
Your sand filter has developed a fault.
Normally water is filtered from the top of the sand filter through the sand to the bottom of the sand filter into the spoke pipes. The filtered water is collected by a pattern of spoke pipes that is connected to the collection box. These pipes only allow water to pass through to the return riser pipe to return the water to the pool via the selector valve.
This problem happened to me too, the fault was at the bottom of the sand filter, at the connection box, it had collapsed/cracked and allowed the sand entered the riser pipe to the selector valve that controls the backwashing, rinse, and filtering etc. and the sand and water is returned to the pool via this valve.
The can be repaired, it requires removing the control valve, removing the sand to get access to the riser pipe, and the collection box and spoke pipes. the the damaged collection box can be repaired.
Put back together in reverse order.
Posted on May 26, 2012
Testimonial: "thank u....your a big help...:)"
How much Sand goes into my SF15110 Sand Filter
Not familiar with this model number but there should always be about 11" of freeboard give or take 1" . Freeboard is space between top of sand bed and bottom of valve.
Apr 20, 2017 | Pool & Spa
How can I get my impeller to work when I plug it in it does nothing?
The impeller shaft could be binding. Also, the pump could be unable to spin the impeller at all, in which case you may need to replace it.
Jul 13, 2014 | Intex Krystal Clear 1600 GPH Model SF15110...
How do you wire electrical line into filter?
Does the filter not have a power cord coming from the motor housing?
Jun 04, 2014 | Intex Krystal Clear 1600 GPH Model SF15110...
I have a Intex Sand Filter Pump SF15110. Can I upgrade the from the 1/2 hP to 1 HP motor
I have the same problem and put a 1HP pump on my system and too much flow. So you can not increase by that much. Need to stay at 1/2 HP and they are impossible to find. End up buying whole new intex system.
May 24, 2014 | Intex Krystal Clear 1600 GPH Model SF15110...
Intex sf15110 filter motor will not reset fromreset on cord. does the motor have a reset
It sounds like your GFCI was knocked out. You can put a new plug on the end if you are sure to get the Common, Line, and Ground wires lined up correctly. A trip to a good hardware store should do the trick. If they don't have GFCI plugs then make sure that the receptacle is GFCI protected. (Ground Fault Circuit Interrupter).
Jul 21, 2013 | Pool & Spa
Why is the sand going back into the water Intex Sf15110
May 26, 2012 | Computers & Internet
Received this sand pump. However there were no instructions on how to put it together. Shows it already together but it was sent apart in two boxes! HELP
They're all about the same. Skimmer outlet goes to pump inlet. Pump outlet goes to filter inlet. Filter outlet returns back to the pool. You will have to fill it with sand. Look at link: http://www.propools.com/instructions_index.php Most any of these instructions will work. Pay attention on how to add sand so you don't break the "spider" piping in bottom of filter. I usually have water in first to absorb the shock of adding sand. Don't let sand enter the stand pipe in center of filter. Cover with plastic cup or something.
Jun 30, 2010 | Sta Rite 21" Sand Filter 15HP Pump
How I Change My Mobail password with out old password
Try these .. at ur own risk
  • *2767*3855# = Full Reset (Caution every stored data will be deleted.)
  • *2767*2878# = Custom Reset
  • *2767*927# = Wap Reset
May 16, 2009 | Samsung SGH-C166 Cellular Phone
Pool & Spa Logo
42 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
