Question about The Office Equipment & Supplies
Which graph represents the function mc018-1.jpg?
How are factorials represented and calculated?
Factorial Calculator "A factorial is a function that multiplies a number by every number below it. For example 5!= 5*4*3*2*1=120. The function is used, among other things, to find the number of way "N" objects can be arranged."
Oct 13, 2015 | Casio FX-9750GII Graphing Calculator
How can you graph a spherical shape when z axis is predeined as z(x,y) ?
You need to set the graphing mode to 3D. In 3D graphing the function is represented as z(x,y)=function of the variables x and y.
Here are a few screen capture to show you how to set the thing up.
Read the calculator manual.
On the last screen are the parameters to change the point of view.
Aug 29, 2014 | Texas Instruments TI-92 Plus Calculator
How can i solve tree equations with fx 4500p
Do you mean three (3) linear equations in 3 unknowns, or tree allometric equations? Thank you Al Gore for inventing the Internet.
For the second case, we really need to know the form of the functions in view of their graphical representation:
Since this calculator cannot do graphs, you can generate a table of values and then represent the variation on graphing paper (linear or logarithmique) depending on the form of the dependence.
Here is a link to the user's manual for this calculator.
Casio fx 4500P silrun Systems
Jan 11, 2014 | Office Equipment & Supplies
I try to graph an absolute value on my Ti 89 and I put the inequality in right but when I go to graph it my calculator says undefined variable.
If you want to graph the absolute value of a function, feed the function to the absolute value ie graph y= abs(f(x)). The calculator will take care of it. See screen captures where I draw the function y1=x^3-5x^2-3 and y2='x^3-5x^2-3'. On the first graph the function is represented and on the second the function and its absolute value.
The calculator knows how to calculate the absolute value of an expression. The name of the command is abs(
May 08, 2011 | Texas Instruments TI-89 Calculator
Polynomial function
Say you have an equation x = 2y.
On a graph, you plot the points representing the values that fit into the equation.
X Y
2 1
4 2
6 3
etc.
And to throw a curve in there:
X Y
-2 -1
-4 -2
-6 -3
If have further questions repost, I'll be around for a while.
Hope it helps
Mike
Nov 24, 2009 | The Learning Company Achieve! Math &...
Y= screen
This calculator has 6 or 7 graph styles. The shading is one of them. To change graph style for one function, use arrows to highlight the function. Use left arrow to move the cursor on the segment or image that represent the style (to the left of the Y). Press [ENTER] repeatedly. Each time you press [Enter] the style changes to another one.
Select the style you want and press [GRAPH] to draw the graph.
Hope it helps.
Oct 10, 2009 | Texas Instruments TI-84 Plus Calculator
I can't graph more than one equation in the y= area of my Ti 84+
The marking that so puzzle you define the type of line (or dots) to represent the graphs. Enter as many functions as there are Y variables.
After entering a function press [ENTER] to jump to the next one.
When finished entering all functions press GRAPH. If you want graphs drawn one after the other, in MODE highlight Sequential (6th line) and press ENTER. If you want graphs drawn simultaneously, in MODE (6th line) highlight Simul and press ENTER. Press 2ND QUIT to return to previous screen . Execute graph again.
Hope itr helps.
Sep 23, 2009 | Texas Instruments TI-83 Plus Silver...
How to graph an equation on a t1-83?
how to fix window to graph Pythagorean property
Sep 01, 2009 | Texas Instruments TI-83 Plus Calculator
Functions?
I am afraid I am missing something here. You can start with the expression of a function and have it graphed on a graphing calculator.
Or you can enter the experimental data, represent them on a graphing calculator and ask the calculator to find the curve that fits the data best, and once that curve is found to give you the equation.
However your calculator does not have the graphing capabilities. All you can do is enter the data and ask the calculator to perform a regression to obtain the expression of the function that fits best.
The available options for the calculator are accessible by pressing [MODE][3:Stat] and
2. A+BX linear
3: _+cX^2 quadratic
4: ln X logarithmic
5: e^X exponential
6:A*B^X power
7: A*X^B Polynomial
8: 1/X
Hope it helps.
Apr 14, 2009 | Casio fx-300ES Calculator
816 people viewed this question
Top The Office Equipment & Supplies Experts
thetraveler
Level 1 Expert
Folusho Adeyanju
Folusho Adeyanju
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
