Question about Braun Health & Beauty
I have braun thermoscanIRT 4520 using for 4 yrs after its default battery weak.I changed many batteries but first its showing low battery with first after that completely off...kindly help me out
SOURCE: Braun 6520 shaver stops working after one use on batteries
dear sir, i have one like yours,your shaver need to change the battery.
Posted on Aug 12, 2007
SOURCE: Braun Synchro 7680 - "Oil" message
Had the same problem on my shaver too. Bought this product:
http://www.onlineshavers.com/pd_braun_8000_activator_foil_cutter_pack31.cfm
(I know the link says foil cutter, but it takes you to Braun lubricating oil!)
I apply the lubricating oil to the foil etc, then the word "oil" disappears. Then after a while the word "oil" comes back and I apply the oil again and so on, my shaver still performs normally.
Hope this helps.
Posted on Jun 07, 2008
TomSolomon
  • 50 Answers
SOURCE: Low Battery Light Even with Brand New Lithium Batteries
If indeed the batteries are brand new and without a doubt charged,
then you definitely have a hardware problem in the camera.
You're probably going to have to give it in to be serviced.
Hope I helped!
Tom
Posted on Jun 20, 2009
SmartAviator
  • 449 Answers
SOURCE: CMOS battery low. I changed the battery but the message keep reapearing
Pull out the battery and clean the contact and try again. It may solve your problem. (ehteshamhusain@gmail.com)
Posted on Jul 19, 2009
  • 4 Answers
SOURCE: Canon Powershot A570 keeps showing change the batteries
I had the same problem. Here's the solution. Go into menu settings, then over to tools, select reset all at the bottom of options list. You may have to re-enter the date and time. This solved the low battery problem for me. I hope this helps.
Posted on Aug 15, 2010
Why won't it turn on?
Inspect the battery contacts for a little oxydation sometimes if its on the battery-spring contact it can happens OKS 1110 or Molykote 111 are very good protectors on battery contacts everywhere it will give long lasting protection also on the both contacts of the battery self.
In rooms with moisture it gives long lasting protection for energy-efficient appliances where batteries longer than average to be placed.
Nov 16, 2015 | Braun Irt 4520 Thermoscan Ear Thermometer
Why have I got a red light on the bottom of my shaver when I am using it
It is common for many Braun shavers, that if the indicator light flashes red while the shaver is being used (switched on and running), it means the battery is low and needs to be charged soon.
Below is an example from a manual for a Braun model 7526 shaver. You can search that site for other manuals if this is not the correct one.
This model shaver has 3 indicator lights:
1) Green (Charging)
2) Red (Low battery)
3) Blue (Power cord attached and plugged into the wall)
Download the manual for the model 7526 here: http://www.manualslib.com/manual/20281/Braun-5301.html#manual
"The green charging light shows that the
shaver is being charged. When the rechargeable
battery is fully charged, the charging light
flashes or goes off.
If later on, the charging light comes on
again, this indicates that the shaver is
being recharged to maintain its full
capacity.
The red low-charge light flashes when the
battery capacity has dropped below 20%,
provided the shaver is switched on. The
remaining capacity will then be sufficient
for 2 to 3 shaves."
Nov 09, 2015 | Braun Health & Beauty
4 year old braun thermoscan IRT4520 having some problems
is the drawer that its stored in, in the bathroom? the humidity or moisture could affect it. I have had mine for 8 yrs and works perfectly. Are you placing the probe covers on correctly and waiting for it to click or a pop before inserting into ur ear.?
Jul 03, 2012 | Braun IRT3020 Thermoscan Ear Thermometer
Computer will not boot past POST and it shows "CMOS checksum error - defaults loaded" on the screen...
good day,
your cmos battery is weak(low voltage) it does not save your bios settings every time you configure it or set it to default settings, it will always display cmos error every time you shutdown your PC, try replacing it with a new one, check the old battery model and buy it in your nearest computer shop, commonly used battery in Motherboards is CR2032 Lithium battery..
Hope this helps.
Sir MArkus
Feb 01, 2011 | Computers & Internet
Braun shaver won't charge
Batteries have an expiry date, Even if you're not using them they are still discharging. Even the regular AA type you buy at the shops.
Batteries can die even if there is a lack of use. And even regular rechargeable shavers that are used all the time have only a limited life a little shorter that=n what you've had.
Should you get new batteries or a new shaver? probably not, you're using 2-3 times a year. I'd recommend buying a cheap Braun or Remington that can take AA's.
Apr 07, 2009 | Braun Health & Beauty
Laptop battery won't charge - Acer Aspire 4520
Since is shows it as charging then your power cable should be working. So it looks like a battery issue but batteries just don't die unless a cell inside dies then they will stop working. Try taking the battery off and making sure that the connections are clean then put it back in. If that doesn't work give the battery a good full charge then bring the battery and laptop back to where you bought it and get them to test the battery to see if a cell died.
Jul 29, 2008 | Acer Aspire 4520-5582 Notebook
Health & Beauty Logo
22 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
