Question about Furniture
Chambrer WC 601 wine cooler. Unit on and set to 55 F Cooled to 57 then began to rise to 70 Unit ware on to. Fan is running.
bobotfel
  • 236 Answers
SOURCE: Wine cooler gets too cold (freezes)
Check your thermostat setting, if the setting is ok then something wrong with your thermostat control.
Posted on Jan 21, 2008
aborcass
  • 2651 Answers
SOURCE: Marvel 61WC Wine Cooler
sorry for the delay in response time you definatly have a bad thermistor, not able to stabilze temp so it contionues run never shutting doen freezing everything, who ever repairs it (if they haven already,)make sure they put all 3 new peices in, thermistor, potentiometer, and contol box. all 3 come in one kit, 20 min to install
Posted on Mar 01, 2008
SOURCE: oster 12 bottle wine cooler
I have the same problem. my oster 12 bottle wine cooler was only six months old. the temp of the cooler won't drop. stay at least 80 F and up. Bestbuy don't even carry this product anymore.
Posted on Sep 07, 2008
SOURCE: OSTER WINE COOLER
I followed the advice of Ancient Bob and located the heat shrinked fuse as he described. I removed it from the circuit board using a very small tipped soldering iron and repaced it with an inline fuse holder with about 1" leads(Radio Shack or Auto Parts store) and carefully soldered it in place on the circuit board. This makes a fuse replacement a snap if necessary later..I used a 5A 250V fuse as original. It has been running fine for two weeks now, I think the fuse in question blows if the ambient temperature gets too high in the room-a design defect (my opinion). As Ancient Bob said, the total cost was about six dollars icluding 3 extra fuses. Care must be taken when removing the solder, or resoldering the circuit board. It's not complicated but must not be sloppy. After removing the original fuse I drilled out the circuit board fuse holes (they may fill with solder as a byproduct of removing the fuse) with a tiny drill bit to make the installation of the inline fuse neat and easy. Good Luck
Posted on Oct 03, 2008
SOURCE: U-Line 15WC Wine Cooler Problem
I just had the same problem. Also, I was getting a burning smell. The coil on the unit was blanketed with dust and dog hair. First, I cleaned it all out and tried it. It really didn't do much and I still had the burning smell. I then opened the back and recognized that the fan was not working. Turned out to be really dirty. Cleaned it and no it is working fine.
Posted on Oct 18, 2008
I have a wine enthusiast wine cooler model 272 03 27. Not cooling,compressor kicks on. The fans are running.The temperature never gets below 64.Is it the temp sensor or Control board? Thanks Randy
It sounds like it is in the correct temperature range. You may ned to adjust the temperature to a lower setting.
°C °F Wine Style 19 66 Armagnac, Brandy, Cognac 18 64 Full Bodied Red Wines, Shiraz 17 62 Tawny Port 15 59 Medium Bodied Red Wines 14 57 Amontillado Sherry 13 55 Light Bodied Red Wines 12 54 Full Bodied White Wines 11 52 Medium Bodied White Wines 10 50 Ros?, Light Bodied White Wines 9 48 Vintage Sparkling 8 46 Fino Sherry 7 45 Non-Vintage Sparkling
Dec 01, 2016 | Furniture
Viking Wine Cellar Temperature Near-Freezing
Viking wine coolers are made by Marvel.They all had issues with freezing the contents. If you replace the electronic cold control system it will be fine.If you don't, it will freeze the wine popping the corks and leaking in the unit.If you get the parts from Marvell they are much cheaper.
Jun 01, 2010 | Viking VUWC141 Wine Cooler
On two recent occasions, my unit has chilled the wines down to about 36 deg.F. It has otherwise run fine for about two years, maintaining about 57 deg. F, consistently. Any idea what would cause such...
wine coolers are usually installed in cabinets or in a bar type situation where the airflow to them becomes more critical. the cooler has two sets of coils that can collect dust and dirt. once the coils clog with dirt, the fans cannot do there jobs by passing air over the coils. This is how the heat transfer takes place. One coil absorbs the heat from the inside of the cooler and the other rejects the heat into your home or outside of the unit. They should be cleaned once a month just like your refrigerator. This will make it run more effeciently. If this is not the problem, check to see if there is a supply register from your central heating and air system close to it. you may be able to get a diverter to push the air away from the cooler
Dec 05, 2009 | Transtherm Ermitage Wine Cooler
Chamber wc902 wine cooler which wont set temp
I have the same issue especially when there is a power outage. To reset it, press the preset until "1" appears, then adjust the temperature as low as it will go by repeatedly pressing the temperature "-" button. Usually works.
Oct 08, 2009 | Tower Chambrer WC601B 7 Bottle (6+1)...
I set the thermostat to 70 degrees but it doesnt cool down to 70, it seems that the temp in the house only rises, instead of cools down.
Setting Unit at 70* ? and not cooler ( dropping temp in the house ) Question ? does temp dop at all, if so the Unit maybe unsized, if the temps are going up then the unit is not working at all - maybe just the fan is running. If this is a split unit ( outside unit / furance). A number of things could cause the same problem - call a sevice company. it could be anything -from a Breaker to an electrical part, split Units have to different breakers ( fuse) . Check that first
EM
Apr 26, 2009 | Heating & Cooling
Motor very hot; not cooling
If the compressor is hot it is possible that it is short cycling. Make sure the compressor is running and that the condenser fan motor is running if air cooled.
Mar 07, 2009 | Magic Chef MCWC30MCG Compact Wine Cooler
Haier Wine Refrig runs to cold
change your temperature sensor, it's broken and it's going to down temperature
Aug 22, 2008 | Haier HVF042 Wine Cooler
Fridge not running well
Not sure of what type of fridge you are refering to.. However you can try a few obvious things. Try turning the thermostat to a lower number (warmer setting) to see if that makes a difference. If you have an ice build up starting to form on the fridge plate or only a partially cold plate then you could have either a loss of refrigerant or compressor fault. Is the compressor noisey in comparisson to its normal noise. Is there heat being produced all over the condenser (black finned section on back of cabinet or underneath cabinet)..If not possible gas leak. Hope this is of some help.
Sep 07, 2007 | Haier BC112G Wine Cooler
Dose not get cold enough?
Does the compressor run or shut off when it gets to 55 &57? Leave unplugged over night and try again.. Let me know.
May 30, 2007 | Danby DWC283BLS Wine Cooler
Furniture Logo
66 people viewed this question
Top Furniture Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Furniture Expert? Answer questions, earn points and help others
