Question about Robinair Measuring Tools & Sensors
Robinair machine will no do anything just shows high pressure disabled message
mhkamran
  • 180 Answers
SOURCE: high presure rest on robinair 34788
It's seems to be problem with your unit relay board,vacuum pump or pressure transducer.Most of Robinair 34788 machine having same problem.You can try the following 1# Open vacuum pump oil filling cap to release extra pressure from pump.2# Replace new relay board & follow the on screen message(do not skip any option).3# Check pressure transducer is working properly.I hope this will help you.
Posted on Aug 09, 2009
mhkamran
  • 180 Answers
SOURCE: when unit is turned on a message appears that says
This is a common problrm of Robinair 34700Z / 347002k & 347112k series machine.so don't worry just do the following :- 1# Verify the ISV tank is not overfilled.if full,remove refrigerant manually from tank. 2# Verify if there is high pressure in the tank.Purge excess air from the tank manually.( Open air purge hose from the tank,then press tank valve as needed) 3#Check the high pressure switch for proper operation,if not then replace high pressure switch.Hope this will solve your problem
Posted on Aug 18, 2009
mhkamran
  • 180 Answers
SOURCE: Robinair 34700 recovery problem
It sound like one of the pressure trunsducer is not working or disconnected from the manifold assy.or from ISV tank.Please check Low,High and ISV tank pressure transducer
Posted on Jul 10, 2010
mhkamran
  • 180 Answers
SOURCE: The high pressure unit is disabled in my Robinair
This is a common problrm of Robinair 34700Z / 347002k & 347112k series machine.so don't worry just do the following :- 1# Verify the ISV tank is not overfilled.if full,remove refrigerant manually from tank. 2# Verify if there is high pressure in the tank.Purge excess air from the tank manually.( Open air purge hose from the tank,then press tank valve as needed) 3#Check the high pressure switch for proper operation,if not then replace high pressure switch.Hope this will solve your problem, if so please vot for it
Posted on Jan 04, 2011
mhkamran
  • 180 Answers
SOURCE: I'm Archie i've a Robinair
This is a common problem of Model: 34788, 34788-I, 34988, AC34788, GE48800 etc.
You need to replace air purge solenoid (Air purge solenoid located on top of the ISV tank, if you open front panel cover then you can see it on top of the tank).
After doing above stapes and your problem still exist then you have to replace PCB relay board. Just claim for warranty (Air purge solenoid and PCB relay board) from where you bought the machine.
Hope this will help to solve your problem, if so please vote for it for farther help! Good luck
Posted on May 17, 2011
The high pressure unit is disabled in my Robinair Cooltech 34700z wat could be the problem?
Jan 04, 2011 | Robinair Cool Tech 34700Z Recovery,...
High pressure unit disable
This is a common problem of Robinair 34700Z / 347002k
Aug 31, 2010 | Robinair Cool Tech 34700Z Recovery,...
I HAVE A 34700Z UNIT AND I WAS RECOVERING AND AFTER A BIT IT STOPPED AND SAID HIGH PRESSURE UNIT DISABLED WHAT COULD BE THE PROBLEM.
This is a common problem of Robinair 34700Z / 347002k & 347112k series machine.so don't worry just check the following :- 1# Verify the ISV tank is not overfilled.if full,remove some refrigerant manually from tank. 2# Purge excess air from the tank manually.( Open air purge hose from the tank,then press tank valve as needed to purge air from the tank) 3#Check the air purge solenoid & High pressure switch for proper operation.Hope this will solve your problem, Best of luck & vote for my solution
Aug 21, 2010 | Robinair Cool Tech 34700Z Recovery,...
Jul 08, 2010 | Robinair Cool Tech 34700Z Recovery,...
My machine says high pressure unit disabled and will not let me advance
May 27, 2010 | Robinair Cool Tech 34700Z Recovery,...
When unit is turned on a message appears that says "high pressure, unit disabled" how do you fix this problem? the machine doesn't let you do anything.
Aug 17, 2009 | Robinair Cool Tech 34700Z Recovery,...
High presure rest on robinair 34788
Aug 09, 2009 | Robinair Cool Tech 34700Z Recovery,...
Error Message: High Pressure Reset/Low Pressure Reset
Your machine may need to Calibrate pressure transducer or replace new one.switch ON the machine (FOR MODEL 34700Z) & follow on screen message.You can also try the following:1# Check recovery solenoid (S1) coil & make sure it's not burne or it's may need to rebuild.if so,replace new coil/rebuild solenoid flunger.2# Check inlet low & high side solenoids (small solenoids S10-S11-S13-S14) is receiveng power & opening properly.Hope this will solve your problem
Jul 24, 2009 | Robinair Cool Tech 34700Z Recovery,...
My robinair isn't working and shows high pressure
This is a common problrm of Robinair 34700Z series machine.so don't worry just do the following :- 1# Verify the ISV tank is not overfilled.if full,remove refrigerant from tank. 2# Verify if there is high pressure in the tank.Purge excess air from the tank manually.( Open air purge hose from the tank,then press tank valve as needed) 3#Check the high pressure switch for proper operation,if not then replace high pressure switch.Hope this will solve your problem.
Jul 12, 2009 | Heating & Cooling
Measuring Tools & Sensors Logo
126 people viewed this question
Top Robinair Measuring Tools & Sensors Experts
Mike
Jay Finke
Jay Finke
Are you a Robinair Measuring Tool and Sensor Expert? Answer questions, earn points and help others
