That's exactly what is happening causing blue exhaust. Bad head gasket, valves. Ck coolant to see if oil is mixing - head gasket- Compression test will answer other questions
Causes can be:Worn piston rings or a score in the cylinder wall or a defective PCV valve (excessive crankcase pressure) or the crankcase is overfilled, check all of them.
