Question about Refrigerators
Water on the bottom inside the fridge - Refrigerators
  • Refrigerators Master
  • 3,054 Answers
Hello Simon Kaloussdian,
I dearly love refrigerators... if for nothing else... they sit
for decades working their hearts out... usually to never be given a second thought .
I'm looking at your 280 day old Daewoo top freezer
report... (only by researching your history)...
INFO: Country, features, history & model number?
So... no door service... water/ice service ELIMINATES
a lot of concerns... You are basically looking at
a DEFROST, drainage or air-leak problem...
From your previous issue...
you know the EVAPORATOR collects ice...
Your DEFROST circuit... routinely removes it...
Or should:
There are only 3 defrost elements:
- TIMER/Control (clock or Circuit board)
- Defrost thermostat (restrains EVAP heater)
- Defrost heater (warms.... only)
A clear drain to the DRAIN-PAN allows the moisture to be externally collected & removed (usually evaporative)...
ASSUMING all your door gaskets are good... you must have a blocked drain (I'm suspecting a clogged EVAPORATOR PAN).
Usually a dose of warm (only: not hot) soapy water
is enough to get the drain flushed out...
fit a soda straw (or flex tube) to the bottom of the
drain tube and blow up...
Working FANS and clean condensers are CRITICAL to satisfactory cooling.
FIND YOUR original parts list / owners manual
Comment me back if you want to discuss...
I'm here daily.
Carnac the Magnificent
Posted on Apr 21, 2017
Sea Breeze
  • 4655 Answers
SOURCE: Water dispenser inside fridge and ice maker in freezer part in bottom both quit working.
There can be many reasons for no water supply. Line feeding the refrigerator is clogged or blocked. The water control valve that turns water to ice maker and dispenser is defective or the water filter located inside your refrigerator is in need of change. I will be here to help you go through the steps. Let me know when you are ready, Thanks, Sea Breeze
Posted on Apr 28, 2009
  • 68 Answers
SOURCE: water leaking inside the fridge instead of in the recepticle
yep your drain is blocked up at the rear of the fridge
Posted on May 02, 2009
  • 268 Answers
SOURCE: water is leaking on the inside bottom draw of the
Clean the drain tube and drain pan under fridge.It may be clogged.
Hope this helps.
Posted on Aug 07, 2009
  • 572 Answers
SOURCE: water on the inside floor of the refridgerator,
remove back panel from freezer and unglog hole where it collects water. its glogged
Posted on Feb 11, 2010
Sea Breeze
  • 4655 Answers
SOURCE: leaking water inside bottom of fridge, fridge not keeping a cold
Sounds to me you are having a ice blockage and or defrost problem. When that happens water can not get outside of the refrigerator. If you look inside the rear of freezer you may see a frost line or layer building on rear panel. You may just need to begin manual defrost until we can get a look at the evaporator coils and condensate collection tray. Unplug and begin and let me know your model number. I can help if you like, Sea Breeze
Posted on Mar 19, 2010
Water leaking out from inside and running out under the fridge. Do I need to clean out the outlet pipe and if so where would it be??
Check the drain tube that leads to the defrost pan under the fridge. The drain tube maybe plugged. Do you have water standing in the bottom of the fridge and if so that is probably the problem. However, something must be defrosting inside the fridge to create that much water. Be sure your fans are running inside the fridge.
Jan 08, 2016 | Refrigerators
Water/ice build up in center column of fridge
clean the backside fins of the fridge..they get gummed up with dust and cannot cool the water effectively..clean inside and especially outside back and bottom..also..defrost it fully first..
Jan 08, 2014 | GE Refrigerators
I have water dripping down the back panel inside the fridge-it is constant. I wipe down the inside back wall, but hours later the water is back. The fridge appears to have a "channel" for this water
with out knowing name brand an model# i would say it sounds like there is a drain tube missing from the upper patr or freezwr area to the drain hole at the rear bottom . there is a drain pan under the refridge which catches this water then it evarperates. it also cab that the proper drain is pluged or blocked with algie which is comon try a little bleach to clean out the drain area
Nov 15, 2012 | Liebherr Refrigerators
Water build up at bottom of Kenmore Compact Fridge
Problem on your Refrigerator bypass plastic water sypply pipe.May be it was block dust,so you can clean it then water thorough the tank.
Mar 15, 2010 | Kenmore 4.9 cu. ft. Compact Refrigerator
Water on the inside floor of the refridgerator,
Feb 11, 2010 | Maytag MSD2756G Side by Side Refrigerator
Fridge constantly dripping wet
water inside, too much condensation from humid air entering fridge from bad seals. replace the seals. could also be that the condensate drain is clogged. if it's leaking from the bottom of the fridge, make sure the tubing is still inside the condensate pan underneath the fridge.
Aug 24, 2009 | Whirlpool Freezers
Water buildup inside of refrigerator
It may be the fact that your evaporater pan is not working. The freezer and fridge have drains inside them. The water inside and condensation go down tube that you see on backside of your fridge. This tube goes into a drainpan in the bottom and than evaporates.
You should also check to make sure your fridge and freezer are cold enough.
May 20, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Spilled milk inside the fridge ends in the catch tray
The pan is for holding the defrost water for it to evaporate. If the milk creates an odor, you can acces the pan by removing the front panel under the door (usually). The pan will probably come out so you can clean it.
May 06, 2009 | KitchenAid KBFA25ER Bottom Freezer French...
Puddles of water in Fridge
you may want to check your door seal, air leaking thru the door seal causes condesation,also make sure that the drain tube is clear under the defrost element in your freezer.
Dec 18, 2008 | Refrigerators
GE Refrigerator, Model TBX22ZA
the drain hole is blocked in the bottom of the fridge. if the water is not able to drain down the hole it will overflow into the fridge base. check any holes at the inside back of the fridge.
Jun 11, 2007 | Kenmore 26.0 cu. ft. Side-By-Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
