Question about Ford Garden
Have a 1955 ford tractor 600; someone else converted it from 6v to 12v..was running fine, now starts but doesnt stay running???
    Master:
  • Ford Master
  • 923 Answers
Kicks out immediately? Kicks you off the tractor? The wheels kick out sideways? The transmission kicks out of gear?
Posted on Apr 20, 2017
Testimonial: "Not looking for wise-a## comments, but thanks for looking"
  • 1 more comment
  • solver2010 Apr 20, 2017
    You need to SAY what you MEAN if you want any real HELP. People are not mind readers!
    You changed your original explanation. Now we're getting somewhere. The ignition coils on those were powered two ways. One way while cranking, the other way while running. There was a resistance wire that fed the coil while running, which was "shorted across" (bypassed) while cranking. There are two terminals on the ignition coil. One is connected through the resistance wire, with the key or switch in the run position. the other goes to the ignition points (contacts to ground, controlled by the distributor cam). Put a meter or test light from ground to one side, then the other side of the coil (not counting the large high voltage terminal). Is there any voltage on either terminal, as measured to ground, with the key (or switch) in the run position? If not, you have found your problem!
  • JOHN BREZINA
    JOHN BREZINA Apr 20, 2017
    thanks
How do I replace a generator with an alternator?
here is a short video, where the guy replaced a 6v generator with a 12v alternator, if you click on more under video there are instructions listed.
if you are going from 12v to 12v it will be easier.
if you are going from 6v to 12v there are other modifications that need to be done, so as not to fry to light bulbs, ect...
also keep in mind that some of your older cars have a positive ground ( I've run into this on some of the fords), if this is the case , the vehicle will have to be converted to negative ground.
Generator to Alternator Coversion
this video explains things in more detail.
Video Generator to Alternator Conversion
Mar 09, 2015 | Cars & Trucks
Alternator wiring
Goggle diagram wiring 6v to 12v tractor
Dec 31, 2013 | Ford 555 backhoe
Need wiring diagram for 1955 ford
1955 ford what ?? a E93A 6v system or a ford zephyr ,ford pilot thames van or thames trader truck
Aug 01, 2012 | Mercury Montclair Cars & Trucks
Will not stay running after it runs for about 30 to 45 minutes i changed rotor, points, condencer, and a new coil nothing helped.
Is it a no spark problem? or fuel problem?
If it is a no spark problem....check for voltage to the coil when it stops.
You do/should have a resistor before the coil which could be bad ( no voltage when hot) or missing (removed) overheating the coil.
If no fuel.....check for flow to/at carb when it stops.
Is the gas cap vented?
Aug 06, 2009 | Ford 8N Tractor
Farmall Cub 1955, runs fine for about 20- minutes
I have cub that done same thing, there was crud in orfice between tank and sediment bulb, cleaned orfice, runs fine.
May 30, 2009 | Farmall Cub Tractor Radiator
Power Requirement for Delphi Roady 2 XM Radio
Radio shack has a unit that plugs into a 110 socket and will accept the 12V plug that is standard with the radio. I use my unit in the house, car and on my motorcycle. The part number is 22-505 for the Radio Shack part.
Dec 02, 2008 | Delphi Roady2 SA10085 XM Radio Receiver...
Tractor stalls after approx. 15-20 of run time (1957 farmall cub)
try the 12volt coil. and remember the positive verses ground . you might have to order one from whitenys.com search that web site , i hope i spelled it right ,dang it sucks being 50 years old and cant remember things. but any ways check that website out okay .
Nov 26, 2008 | Farmall Toys
Garden Logo
50 people viewed this question
Top Ford Garden Experts
Dennis Key
Dennis Key
donald boissonneault
fordexpert
Are you a Ford Garden Expert? Answer questions, earn points and help others
