Question about Refrigerators
Found water insid - Refrigerators
Water pouring under passenger side dash. I found the plug end in the engine area. Where is the plug located inside the dash inside the car?
The water you are getting is from the air conditioner - need to unplug the drain hose that appears under the car.
When you have a clog the water collects in the drip tran and eventually over flows into car.
Sep 13, 2015 | 2003 Saturn ION
Found water inside spark plug well
Water in spark hole will cause the missing Blow this out and try again. The main concern is how did water get there. Have you been thru a car wash latly or had your engine degreased after a service ? If none of these then things could be more serious
Nov 27, 2012 | 2006 Mazda 3
Whirlpool water cooler #whkm-D40 cold push-button broken, does not release water
First, check its button properly. Second, check the circuit board properly.
Chevy Silverado Parts
Aug 27, 2012 | Refrigerators
Water on the bottom inside the Freezer
the water usually comes from the evaporator defrosting and the drain being plugged with ice or frozen water. try a hair dryer and defrost the frozen water and clean the drain plug and hose
Mar 18, 2010 | Frigidaire Model: PHSC39EHSS
Were water inlet hose connects to housing on washers left side, water is leaking seems to be a washer or valve that mounts on the inside of washer might be missing but have not found any such object inside...
Hi, There is some lime build up inside the inlet. Remove the hose and push a wire or a small screw driver into the hole and reem it out. That should yake care of the water leaking.
Please let me know if this helps you.
Vic
Jul 03, 2009 | Dishwashers
Air Conditioner 3 in 1 danby SPAC12030 leaking water on the floor. No water in right side compartiment also no water in the back reservoir. Water leak from right side of the machine. From the right side...
I had that problem last year. When I took it apart I found that the drainage hoses that lead to the reservoirs were plugged with dust build up. I clean out the hoses as well as the rest of the insides. I have since placed the entire unit inside a shallow (under bed) style rubermaid tote and have not had any more water leaking. Hope that helps you.
Aug 04, 2008 | Danby Heating & Cooling
Water accumulates inside the washer
i guess you have washer drain pipe plumbed into a spigot on the sink trap. if so, when you empty sink, some of the water goes down the washer drain pipe and ends up filling your machine.
to cure, take the drain pipe as high up as possible under the sink in a swan neck and that should cure it. its a common problem
Jul 22, 2008 | LG 4.0 Cu. Ft. 7-Cycle Front-Load Washer -...
Refrigerators Logo
19 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
