Question about AEG Washing Machines
Code c3. I have drained the bottom, but the error repeats. It appears that during washing on a regular basis, water comes out of something that looks like an overflow pipe. aeg favorit 8080 i-b
  • 209 Answers
SOURCE: Water doesn't drain
simple one this, just clear out the waste pipe and the inside food filter and the outlet pump, also check the outlet where the pipe goes (under the sink?) its a simple blockage somewhere, if i have helped rate me, and work safe remove the plug etc
Posted on Sep 16, 2007
SOURCE: AEG Dishwasher FAVORIT 3A Error Message C3
If you open a sidepanel and look at the bottom of the machine you see a brown device with a piece of white foam,this is the leak prevention system.
Push foam down and the error code should be cleared.
Make sure you there's no water left on the bottom of machine
Posted on Mar 05, 2009
  • 3230 Answers
SOURCE: AEG Lavamat 88840 display C3
This means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
Good Luck!
Posted on May 06, 2009
  • 3230 Answers
SOURCE: AEG OKO Lavamat Update washing machine LAVALOGIC 1600
This error code (C3) means your water sensor has detected a leak. it will stop when the sensor is dry.
Good Luck!!
  • 3230 Answers
SOURCE: AEG Lavamat 86720 washing machine
post further comment for more help......
A lot of water stays at the bottom(in fact) of washed dishes(crockery) What do I have to make?
There is a drain screen on the bottom of the dishwasher that needs to be cleaned out on a regular basis, especially if you put in dishes that haven't been rinsed off. Food waste will plug up the screen and not let the water drain out fast enough
If that screen gets blocked, the water doesn't have enough time to be drained from the washer during the timer sequence and the water will remain at the bottom.
Mar 06, 2015 | Miele Incognito G858SCVi Built-in...
During a normal wash cycle, the error code FH occurs. The owners manual says inlet problem. All water pressure is good and inlet screens are clear. Drain function appears to work well. Repair guy came...
If the flow meter does not register 10 and 1/2 gallons of water in 8 minutes the FH code appears.
Could be a bad flow meter, sensor, wiring harness is loose or a bad CCU Central Control Unit.
At the RINSE cycle if water enters the machine you must time the water fill for 8 minutes or less.
If water does not enter the machine suspect the CCU as bad.
Jan 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
What does e20 mean? The display shows an error of e20. Looks like the water is not pumping out during the regular wash.
Hi
Error code e20 means a clogged drain pump. This might have happenned due to small clips, pins, coins, etc being stuck in the pump. Please note that error e20 can also occur when the drain pump is not pumping fast enough or when the pump fails. To fix the issue you'll need to check the drain pump.
Remove the 2 screws from the bottom of the front access panel, it will come off. Now check for the pump on the right side and remove hoses from it. Remove pump from machine then remove whatever is there in the pump.
Please post back for any further assistance.
Daniel
Jul 31, 2010 | Frigidaire ATF6000ES Front Load Washer
I have a maytag epic z and it suddenly stopped washing - I get an F-21 prompt. What does that mean?
F21 is a Long Drain error code. This indicates that you have an obstruction somewhere in the drainage system. In most cases, this means you probably have a clog in the drain pump. You may have something getting caught in the pump impeller and slowing it down. Or, you may have something clogging the drain lines. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris can commonly clog in this area as well causing the drain cycle to fail.
If this solution doesnt solve your problem, you may have to replace the drain pump.The error code will continue to appear until the pump is replaced.
Apr 09, 2010 | Maytag EPICz 3.7 cu. ft. Washer
Whirlpool Duet 9100 will not drain during regular wash cycle. Cleaned drain filter & ran diagnostic and then rinse & drain. Water drained from washer & clothes were damp and I thought the...
I would assume that you are using HE detergent if not the pump could go into a suds lock. You may have a bad drain pump. The other options could be possibly a bad central control unit. (however these are very expensive) or possibly a door lock issue but usually you will get a door lock error.
Jan 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Displays f 02
"F02" is a Long Drain error code. This is an indication that you have an obstruction somewhere in the drainage system. Most commonly, this means there is something lodged in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains:
http://www.fixya.com/support/r3608545-f02_error_code
Included is a follow-on link that explains how to access and check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris and small articles of clothing can commonly clog in this area as well causing the drain cycle to fail.
NOTE: The "SUD" error code can often occur in conjunction with the "F02" error code. This is due to air being detected in the drainage system, which can occur if the pump is not running, or if you have an obstruction BEFORE the pump. You need to remove the inlet hose from the pump to ensure it is also not blocked. Correct your drainage system fault, and the SUD error should go away.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
Dec 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Mildrew, stale water smell in laundry
Run a very hot wash on your machine with no load
Fill a bucket with a strong solution of soda crystals and pour it into the machine first
Add some more crystals to the soap dispenser
Use an old fashioned soap powder for a couple of washes as well and reduce the load slightly
Modern soap powders do not contain certain bleaches and soda and the 40 degree wash leaves body fats and oils inside which cause odours
Jul 03, 2009 | Frigidaire ATF6000ES Front Load Washer
Error Code EO6 - Bosch Front Loader WVT2850
Hi
I have have this same problem for 4 years now and engineers always told me it was becuase something may have been caught in the filter yet I clea my filter weekly and use the decaler they sold me on a monthly basis. Appartantly it is to do with the switch ??
Finally they have written my machine off yippee
Jun 25, 2009 | Bosch Exxcel WVT 2850 Front Load Washer /...
KENMORE ELITE HE3T CODE F-02
F02 is long drain.
Just because it came up doesn't mean there's a problem, it simply means there was a failure during the cycle, if it returns on a regular basis, you have a problem.
F02 error could be caused by the over use of soap, you need to make sure your using 2 tablespoons of HE soap, 1/4 cap at the most.
Over sudsing, could cause the water pump to run longer, the pump is designed for 15 min duty cycle which means, 15 minutes on to 45 minutes off. The computer may sense too much soap, and continue to pump. HE soap will cure that, along with SUD error, possible F09 (overflow condition), you may also notice the timing is wrong, HE soap works well in these machines and F/l washer go hand in hand
if the F02 returns the remove the 3 torx screws from the bottom kick panel, and remove the kick panel, right there in the middle you will see a big round handle, turn it and then slide it out, have some towels ready, there will be some water in there, and check to see if you have any thing in there that will slow water flow, tooth picks and other "floating" items may jam the impeller.
Apr 01, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Whirpool Duet front loader ghw9100lw error code F02
if your hearing clackling try and clean the pump and the hose leading into the pump for a coin ,,small ,,(dime),,,hair clip,,also its a must that you use he detergent,,or you sude up,,if you do use he your using to much,,now bleach the unit out on a normal cycle hot wash cold rinse with about a pint of bleach...and no you can purchase part of a pump..it comes as you see it in unit..onthejob
Jan 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Chris Hall
Chris Hall
shaun taylor
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
