What is the Model # for the Trane 4TTR6030B1000A?
Trane model number thh150. how much it costs?
That model is for an RV/Motorhome. Trane no longer makes it. A replacement unit is about 700 USD
Jul 31, 2017 | Heating & Cooling
I have a American standard ac model 7A0018-60A100A and would like to know the model no. of the condenser fan motor so I can replace it
All you need to know is that it is a 1/4 hp, 825 rpm. 1/2 inch shaft. That is if you are going to buy an after market motor. I have had to make new mounting holes when using after market motors on trane systems (just the way trane is) but not a problem. If you're getting it from trane you would only need the model number of the condenser.
Jul 14, 2017 | American Standard Heating & Cooling
What voltage required for trane ac with model # bwc060d400h0
Should be 240volts. Trane in a "secret" company that don't like to share any of their info with the public. I tried to look up the model # (great job to you for including make & model!) and found nothing. But.... If you look at the tag on the unit or some of its components it should give you a voltage rating
May 29, 2015 | Heating & Cooling
What is the age of the following Carrier RTU - Model # YCDO6OC460BF & Serial # R28105287D I have been told 1982, 2000 & 2007. The unit does not look that old, so do not believe it was a 1982,...
YCD060 is a Trane unit number not a carrier. Trane has a large guide for looking up approximate age of equipment. There is no date coded in the serial number, Trane does include a mfg date on most of the labels on later equipment, look for it on top or bottom corner of label if you can still read it otherwise I have the cuide at the office and will look it up this week. FYI our company is a TCS Trane dealer.
Aug 24, 2011 | Heating & Cooling
New Trane XV95 furnace runs and stops nine
if it is a mechanical thermostat the heat ant. does that on cheaper digital tstats it is set by span and on better stats like honeywell model 5000,6000,8000 series you set the cycle rate. what kind and model number is tstat
Dec 19, 2009 | Goodman GDS80904BNA Open Flame Heater
Need wire diagram for GE electric furnace
Usually the older GE's are straight forward and any generic wire diagram will help you out. If its newer and a Trane made unit try A Trane dealer.
Mar 27, 2009 | GE Heating & Cooling
Need a schematic diagram on a trane furnace model blu080k0942b0
Have you checked on the inside of both front panels?
Mar 05, 2009 | Heating & Cooling
Heating & Cooling Logo
22 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
