The stamped number on the pad in front is V0720ZZZ and the number on the back of the block is 14093638.
SOURCE: NUMBERS ON BLOCK
Hello there:
Casting dates are usually expressed this way, “C 18 4.” In this example, the “C” means the month of
March, “18” is the day of the month, and “4” is the last digit of the year. This last digit may mean ’64, ’
74, ’84 or ’94, so you must also check the other characteristics of the block to determine in which
decade and year it was made. Some parts have the decade and year cast on them; these identifiers
look like this: “C 18 84.” GM introduced new model years in September or October of each year, so
when you see a casting date of “L 16 7” for example, this indicates a casting date used in the 1968
model year because it translates into December 16, 1967. A 1968 model Camaro assembled on
January 6, 1968, might contain a number of parts that were cast in December, 1967. Casting dates
should precede hand-stamped engine assembly dates.
SOURCE: Small block stamped number in front of block F112DB what is it ?
F = Flint factory
112 = January 12
DB = 3 choices
a 1958 model 283 with powerglide
a 1965 model 283 with manual trans
or a 1968 model 307 with manual trans
Hi Ffreddybear, Check your registration paper mate........CHEERS..
Testimonial: "I don't understand, check what registration papers? Are you making this into a riddle of some sort?"
SOURCE: What motor do I have and what year and anything else
Hello Joe...please check the data pad...I'm finding
V Flint (Engine)
07 July
20 20th
ZZZ No Such Suffix Code Exists
Is this engine installed in a vehicle or laying in the ground?
Try the link for more info..
NastyZ28 com Chevrolet Decoding Guide
Testimonial: "It is in a 74 Corvette. I was told it is a first generation GM Crate engine"
