Question about Water Water Heaters
I have a afwood water heater model g6a-8e.I turn on switch. The waterheater fires up but then the sparker keeps firing then the heater shuts off.Can you help me? Thanks Bob
  • Water Master
  • 2,342 Answers
Bad thermocouple
Posted on Apr 21, 2017
Atwood g6a 8e
The yellow is caused because the flame does not have enough oxygen. Per your explanation that is being caused because the exaust is not working. Fix the exaust problem and it probably will begin opperating properly.
Mar 23, 2014 | Water Heaters
I have an Atwood waterheater model # G6A-8E. I am having issues with no spark from the ignitor , I have used a long stem lighter to light the burner. It lights and burns well for a couple second seconds...
When you turn it on and hear the ignitor clicking, test for 12 volts at power wire to gas valve. If your not getting 12 VDC to gas valve when ignitor is sparking, replace module.
Jul 10, 2011 | RTO Atwood Water Heater - 6 Gal LP
Water heater fires and runs for 2 or 3 minutes and then cuts off.It tries to refire 2 or three times but wont .Red light inside comes on as if it is out of gas.I changed the T-stat and ECO and it still...
First of all, lets see if water is hot already by releasing pressure relief valve slightly and seeing if water is already hot.BE CAREFUL NOT TO SCALD YOURSELF! Shut water pressure off, first, but be aware it will still be under pressure at first.. Just hold a cup, or something under it and open it up slightly, or at least feel pressure relief valve to see if it feels warm/hot to touch. May just be by-pass not set properly in back of water heater. Let me know if hot from pressure relief at outside on heater.
Dec 23, 2010 | RTO Atwood Water Heater - 6 Gal LP
Brand new unit model G6A-8E. when i first hit the switch it comes on fine and heats water. at a later point (and it seems to be intermittant), when it goes to re-ignite to reheat the water it will not...
Check and adjust igniter probe(s) so that they are in front of the flame good. When you say it goes to re-ignite, can you hear, or see spark happening at igniter, but burner just won't catch?
Nov 01, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
I have an Atwood water heater model G6A-8E. When
If this model has a thremo couple you might want to check it. It sounds like that is the problem.
Jun 07, 2010 | RTO Atwood Water Heater - 6 Gal LP
Have an G6A-8E Atwood water heater. It Starts fine and shuts down after a couple of seconds. I can see the diode in the control board continue to spark after ignition I replaced the igniter.
If it has the little thermal cut-off in power wire to thermostat (has a little plastic jacket over it) try removing it, and connect female spade from power wire, directly to male spade on thermostat, and see what happens. Also, make sure electrode is positioned in flame good for flame sensing properly.
May 21, 2010 | RTO Atwood Water Heater - 6 Gal LP
Need the removal procedure for the G6A-8E RV water heater.
SHUT OFF ALL ENERGY SOURCES TO HEATER. REMOVE ELECTICAL SUPPLY LINES AND TAPE THEM OFF. DRAIN WATER FROM HEATER. REMOVE AND CAP WATER LINES. TURN OFF LP. REMOVE AND PLUG LP LINE. REMOVE SCREWS FROM OUTSIDE CIRCUMFERENCE OF HEATER. PULL HEATER OUT.
Aug 27, 2009 | RTO Atwood Water Heater - 6 Gal LP
Water Heaters Logo
60 people viewed this question
Top Water Heaters Experts
vince
80stech
D. E. Hev
Are you a Water Heater Expert? Answer questions, earn points and help others
