Question about Panasonic Televison & Video
Panasonic LCD television Model no. TC-32LX14 power light turns on but no picture, no display
  • 8617 Answers
SOURCE: television power light flashes on panasonic television
3 flashes is the error code for convergence failure. You will need to change both of your convergence ICs they are STK392-110 you can get replacement ICs at the following link with free instalation instructions with pictures so you can do the repair your self. Heres the link.
Posted on Jun 22, 2008
  • 718 Answers
SOURCE: Panasonic 32 inch LCD TV will not turn on-red light flashing
The number of flashes is an error code. Count the number of flash. It looks like one of the boards in your set is failing intermittently. Panasonic codes for a guide as a starting point. Exact board STILL has to be verified;
One Blink: One blink of the power LED indicates a problem in the inverter circuit located on the LCD panel. The inverter board is not to be repaired in the field. Therefore a replacement is required.
Three Blinks: Three blinks of the power LED indicates an over-current or over-voltage condition in one of the DC supplies of the AP board. The AP board is repairable. Therefore the use of an ohmmeter and peak-hold-voltmeter is required to determine the cause of the shutdown. An over-voltage condition is definitely a defect of the AP board. An over-current condition may be due to a short circuit located in the AP board, A board, or the LCD panel.
Five, Seven, or Eight Blinks: The A board is responsible for five, seven or eight blinks of the power LED. The MAIN +3.3V, MAIN +5V, and MAIN +9V sources are all produced on the A board. The detection input pins of the MPU, IC1100, monitor for their presence.
Four or Six Blinks: The AP board is responsible for four or six blinks of the power LED. The DTV9V, and SUB_5V sources are produced on the AP board. The MPU IC1100 monitors for their presence when the unit is connected to AC Power. A short or open circuit on the A board may also be responsible for their absence.
Nine Blinks: Nine blinks of the power LED is due a short circuit in the audio output circuit (s) of the unit. The audio output circuit is located on the A board. Confirm the status of the speakers. If defective, perform a replacement. If ok, replace the A board.
Ten Blinks: Ten blinks of the power LED indicates a malfunction of IC4200, the frame converter. This IC resides on the A board. Therefore ten blinks of the power LED requires the replacement of the A board.
Posted on Feb 11, 2009
  • 8457 Answers
SOURCE: Power Issue
Now,u plug in the tv u get a solid red standby power red LED light in the front of the LCD panel right?When u push the power button on the remote u hear a clicking sound?Only one clicking sound,not the power supply board problems.It the Tuner board problems.But u can make sure it the power board problems or not.By taking the tv aparts check the power board,that board where the a/c power cord goes into it.Look all around the power supply board check for these leakage capacitors,they alway bulges up it top or puff up it top.No bad leakage capacitors,then it not the power supply board problems.
Posted on May 14, 2010
Testimonial: "Thanks for your immediate reply. It could be an issue with the TV's tuner. At times, I did noticed the sound wasn't clear after turning on the TV. I had to turn the TV off, then turn it back on to get a clear sound. Now, the stand-by red light immediately clicks off when plugging into the wall socket. The television is now in a TV repair shop. "
  • 15 Answers
SOURCE: I have a Sony KDL52S4100
When you say the power light is on but it is not powering up, what do you mean by that (just that there is no picture)?
Sounds like the inverter has died or the backlight bulb. Either way, it needs a techy to fix.
Posted on Oct 07, 2010
  • 8617 Answers
SOURCE: panasonic tc-p50g10 No picture/sound just a flashing light.
the flashing light is an error code count the falsh sequence and let me know how many times its blinking and I will assist
Posted on Sep 24, 2012
Panasonic TC-P50S30 has no picture was working fine then picture went out solid red power light no blinking doesn't turn off w remote no more for a while whites would have purple specs before warm
If you wish to get some details; check the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jun 29, 2016 | Panasonic Televison & Video
Panasonic TC-L47DT50 no picture no sound front lights com on
No picture or sound in my Panasonic TH-P42UT30A plasma ...
iFixitAug 1, 2014 - Hi Ifixit,. I've got a Panasonic th-p42ut30a plasma tv that has a fault with it. The standby light is on (red) but it doesn't come out of standby.Missing: l47dt50
Panasonic Product Support - TC-L47DT50 > Get Support
PanasonicSMART VIERA® 47" Class DT50 Series Full HD 3D LED HDTV (46.9" Diag.) ... Issues Addressed: Solves issue where the Emergency Alert System is displayed on the TVhours after the termination of the message. Solves issue where the Emergency Alert System is displayed on the TV hours after ...
Panasonic TX-P42X50B No Picture Or Sound ' Dead ...
? 9:00
Nov 6, 2014 - Uploaded by Electronic Workshop
Panasonic TX-P42X50B No Picture Or Sound This plasma television ... TV repair, clicking and will not power on, loud snap,no picture, etc.
Jan 27, 2016 | Panasonic Televison & Video
Panasonic Viera TC-37LZ85 powers on with a solid red light that does not blink, the screen slightly illuminates but no picture. Blown fuse?
T'Con board fault. In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Apr 10, 2015 | Panasonic Viera TC-37LZ85 LCD TV
Model: TC-19LX50, Panasonic Viera, MH5550524, when I power on the tv, there's no image, after a couple sec. it turn off, and red light is flashing 2 times every 5 sec above R-Standby/G PowerON
These blinks of light are fault indications; and are called 'blinking codes'. If you wish to get its details,check this link. Selecting the view option, either to Mosaic / Flip card, can be selected by the drop-down list, by the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window.
Nov 01, 2013 | Panasonic TC-19LX50 19 in. HD-Ready LCD...
TC-L26x1 Just stopped working
Try this no power troubleshooting chart.bcfb6b69-bb30-46a3-9e19-c00f112105b4.jpg
Apr 23, 2013 | Panasonic TC-L26X1 26 in. HDTV LCD
Model TC-32LX700 Power indicator light on from is
Problem is caused by voltage irregularity. Pulled plug for an hour and then plugged it back in. TV reset and it works fine. If this does not work it needs a TV technician.
Sep 14, 2009 | Panasonic TC-32LX700 Television
Picture will not come on but sound will.
My Panasonic TC-26LX60 Lcd tv powers on and there is sound but no picture (video)
Aug 26, 2009 | Panasonic TC-26LX60 26 in. LCD Television
sounds like a hardware failure, let me know which model # it is and i will run through service manual.
Oct 23, 2008 | Panasonic TC-32LX60 32 in. LCD Television
Televison & Video Logo
73 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
