Question about GE Washing Machines
Ge tl1103pbzn leaking water from under the tub onto the motor what can I do to stop it
    Top Expert:
  • GE Master
  • 75,797 Answers
The tube seal is leaking and this means the tub bearing may be worn out, this is a huge job to replace and requires lots of hand tools and a good amount of mechanical skill.. If you are up to the job contact a website called the repairclinic for tech help and parts if you prefer.
Posted on Apr 20, 2017
LG twintub- water leaking at the spinner onto motor
This is due to failure of the seal on the tub and also if the spindle/bearing seal is also faulty. you need to remove and reset the assembly once again.
Click for tips: Bearings
Feb 01, 2013 | LG Washing Machines
I have a GE Top Poad WasherWJRE5550H1WW that intermittantly leaks
There seems to be an overflow drain from the top of the tub to the bottom (inside the cabinet). I don't know why this was designed to dump water onto your floor.
May 13, 2010 | GE Washing Machines
GE Profile washer...model: WPRE6150HOWT sesr:
i'd check the drain pump-there is a seal where it attaches to the motor-leaks often there, also could be a leak in your tub seal between the tub and transmission, also sometimes the outter plastic tub gets a crack in it and leaks
Feb 15, 2010 | Washing Machines
GE Nautilus dishwasher. Doesnt seem like motor is working
Dishwasher (Nautilus) not draining into sink but leaks onto floor.
Nov 10, 2009 | GE Nautilus 24" Built-in Dishwasher
My ge dishwasher will drain but after a few hours
Could be a crack in the tub, bad seal at the pump if water is leaking out onto the floor. If water is pooling inside the DW then a bad water control valve allowing water to leak back into the tub from the source.
Jul 07, 2009 | Dishwashers
Ge washer leaks when you let it fill to top
feel in the back of your outter tub towards the top and chances are you will find a hole ge's love doing this if it is not under warranty you can repair with some JB weld with out replacing the tub
Oct 09, 2008 | GE WBSE2090A Top Load Washer
GE Top load washer.
Hello rschneeweis
Welcome,
Sounds like a seal or drain hose is leaking or the clamp on a hose has vibrated loose.
Water leaking out the bottom of the machine when washing machine begins agitation cycle. If the machine is turned off the water stops leaking even with the tub full of water.
Let me know if you found it and how you do.
Huuum
Please remember to leave a rating
Oct 04, 2008 | GE WBSR3140D Top Load Washer
Water leaking where motor goes into the drum
there is a tub seal under the spin tub that proab needs replacing open the front panel then raise the top then grab the agitator and **** up on it hard it should snap out then unsnap the splash ring around the outer tub take the little bolt out of the agitator drive loosen the nut on the spin tub and remove it keep going down till you get to the tub seal replace it then reassemble
May 22, 2008 | GE WHRE5260E Top Load Washer
Water leaking onto floor when filling
OPEN WASHER panel and look inside while having the washer taking water , if water leaks under the tub , then its a broken seal , needs to be replaced , if not , check the around the DRAIN MOTOR PUMP , got 2 hoses connected to it , check if it broken or loose , hope this helps AJ
May 17, 2008 | Washing Machines
GE top load washer leaks on floor
Check your hoses mostly the small hose going from the side of the tub to the water switch these come off a lot. you need to look and see if the seal is leaking from the center of the tub you do this by putting water in the tub and just looking around the bottom of the tub and transmission
Dec 29, 2007 | Washing Machines
Washing Machines Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
