Roper rtw4340sq0 top loader sicks in rinse mode.
Roper rtw4340sq0 top loader.
Washer sticks in rinse mode on all cycles.
Doesn't spin just fills and drains over and over.
Timer does not advance.
    President:
  • 1,564 Answers
The drive gear for the functioning unit sounds like it has gone south. Unless you are familiar with changing devices like this, I would call your local appliance guy!
Posted on Jul 24, 2009
How do I fix washer that will not start after I opened door and manually advance to next cycle?
Unplug the machine and replug it - also remove the washing and go through the process again
Jul 23, 2014 | Roper Washing Machines
Roper washer new will not fill with warm water on rinse cycle it fills and spins
if its only a new machine make sure transport bolts have been removed
Apr 09, 2014 | Roper Washing Machines
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
My washer only runs until it's time for the rinse cycle and then it stops completely. It doesn't rinse or spin. What's going on?
hello, it sounds like a failed lid switch part #3949247 it wont rinse or spin with a bad lid switch. it also wont rinse or spin if there is no cold water to the unit.
Jun 08, 2011 | Roper RAS8445KQ Top Load Washer
My Roper washer will not spin on the spin cycle.
IF ITS A TOP LOADER YOU MAY HAVE A BROKEN LID SWITCH. LOOK DON THE HOLE IN THE TOP WHERE THE LID PIN GOES CAN YOU SEE THE LID SWITCH ARM? IF ITS NOT FLUSH WITH THE HOLE ITS BROKEN. SOMETIMES YOU CAN STICK SOMETHING THROUGH THE HOLE TO ACTIVATE IT
Jan 15, 2010 | Washing Machines
I have a Roper brand top loader washer and it fills up but it won't drain or spin.
If the motor doesnt run during the spin cycle and the tub stays full of water. You need to replace the lid switch. This is very common problem. The part should be around 35 bucks. Easy fix.
Jan 30, 2009 | Roper RAK2751WWH Top Load Washer
Roper (Whirlpool) Washer
ohm out the lid switch, with the switch closed it should read contunity if it does not then the lid switch is the issue
Apr 19, 2008 | Roper RAB2121KW Top Load Washer
ROPER RAS6233KQO T.L.W.-Won't fill/rinse with cold water
Most washers have a small screen at the water inlet valve. They can be accessed simply by revoving the hose from the back side of the washer, using a small screw driver you can carefully remove the screens and clean them out under a faucet.That may be all that is wrong.
Oct 27, 2007 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
268 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
