Question about Health & Beauty
How to remove back to replace battery? - Health & Beauty
  • yadayada
    yadayada Apr 20, 2017
    Back of what?
How to replace battery on a black and decker cordless trimmer
  • Remove battery pack
  • Unscrew screws with Philips #2 to remove cover plate
  • Suggest you take picture with smartphone / digital camera of layout before removing battery, so you can easily pit back correct
  • Remove battery - you can easily get a replacement at Batteries & Bulbs or online.
  • Replace battery
  • Reassemble per picture
  • Put cover back on
  • You should be good to go
Jun 04, 2014 | Black & Decker Cst2000 12 - Volt Cordless...
How do I replace the battery on a 2001 Suzuki Volusia Intruder?
To replace the battery:
1- remove the rear (passenger) seat by removing the single bolt behind it. Remove the seat by lifting it up and back
2- Remove the front (driver's) seat). Remove the two bolts behind it and remove the seat by lifting it up and back.
3- Removing the seats will give you access to the battery under the driver's seat.
4- Carefully remove the positive and negative battery cables from the battery, then lift the battery straight up.
5- Place the new battery in the bike
6- Replace the cables, red is positive (+), black is negative (-)
7- replace the seats, and you should be good to go!
Apr 19, 2011 | 2001 Suzuki VL 800 Volusia
Calculator will not turn on. How do you replace the battery? it is a TI30xa
The TI-30Xa uses two A-76 lithium batteries. Comparable battery model numbers include:
Duracell® D357
Eveready® 357
Maxell® LR44
Varta® V13GA
To replace the batteries:
• Remove slide cover. Place calculator face down.
• Using a small Phillips screwdriver, remove screws from back case.
• Remove back case.
• Remove discharged batteries.
• Install new batteries positive side up, as shown on diagram inside case.
• Run a coin across the reset pad on the upper right hand corner of the printed circuit board.
• Replace back case, and then replace screws.
• Press [OFF], [ON/C], [ON/C].
Note: The calculator cannot hold data in memory when batteries are removed or become discharged.
Feb 16, 2011 | Texas Instruments TI-30XA Calculator
Change batteries
1. Remove slide cover. Place calculator face down.
2. Using a small Phillips screwdriver, remove screws
from back case.
3. Remove back case.
4. Remove discharged batteries.
Caution: Avoid contact with other calculator
components while changing batteries.
5. Install new batteries positive side up, as shown on
6. Replace back case, and then replace screws.
7. Press OFF ON ON.
Caution: Dispose of old batteries properly. Do not
incinerate batteries or leave where a child can find
them.
Your calculator cannot hold data in memory when
Feb 02, 2011 | Texas Instruments TI-30XA Calculator
Rechargeable batterys need replacing
You will find the compatible replacement battery at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/batteries/shaver-battery-pack-for-most-shavers-p-211.html
Remove back of shaver by taking out 2 screws on the back near the bottom. With back removed, you can access battery. For easier replacement, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Dec 01, 2010 | Philips Philishave HQ5812 Electric Shaver
Directions for changing battery
2. Using a small Phillips screwdriver, remove screws from back case.
Caution: Avoid contact with other calculator components while changing batteries.
5. Install new batteries positive side up, as shown on diagram inside case.
7. Press: [OFF] [ON] [ON].
Caution: Dispose of old batteries properly. Do not incinerate batteries or leave where a child can find them.
Your calculator cannot hold data in memory when batteries are removed or become discharged.
Nov 27, 2010 | Texas Instruments TI-30XA Calculator
How to replace a battery on a TI-30XA calculator
7. Press off on on.
Nov 16, 2010 | Texas Instruments TI-30XA Calculator
How do you open a TI-30Xa in order to replace the battery?
• Remove back case.
Oct 07, 2010 | Texas Instruments TI-30XA Calculator
The batteries aren't working anymore, how do you replace them?
  • Remove back case.
The TI-30Xa uses two A-76 lithium batteries. Comparable battery model numbers include: Duracell® D357 and Eveready® 357
Aug 12, 2010 | Texas Instruments TI-30XA Calculator
I need to change the battery on the tI30-xa calculator. I need to know the size and how to change it.
Remove slide cover. Place calculator face down. Using a small Phillips screwdriver, remove screws from back case. Remove back case. Remove discharged batteries. Caution: Avoid contact with other calculator
components while changing batteries. Install new batteries positive side up, as shown on diagram inside case. Replace back case, and then replace screws.
May 19, 2010 | Texas Instruments TI-30XA Calculator
Health & Beauty Logo
24 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
