Question about Kitchen Ranges
What is the price of kwikot 600 dual element - Kitchen Ranges
    Top Expert:
  • Kitchen Ranges Master
  • 78,010 Answers
Sorry we have no pricing information here nor do we sell parts of any kind.
Posted on Apr 20, 2017
My kwikot geyser trips when I turn it on its 7 year old
If breaker trips check
- elements being to high in ohms resistance (worn out)
- shorted elements
- short to ground
- improper wiring or voltage per nameplate
May 19, 2017 | Water Heaters
How do I drain the Kwikot 600 dual geyser to replace the element
If the design is typical, there should be a drain valve at the bottom. There could be simply a plug that has to be removed for draining.
Jun 27, 2016 | Water Heaters
Kenmore dual fuel oven model 79075503201. bottom element in oven will not heat. element has a resistance of about 22 ohms. 110v on each leg while off. 110v on each leg during bake cycle. I suspect the...
It seems that the control board is faulty. You would need to get the board repaired since it is no longer available for purchase from the manufacturer. You get the board fixed from at the lowest price compare to the rest of competitors online.
Here is the direct llink to the control board:
Frigidaire Range Control Board Repair Service 318010102
Mar 15, 2011 | Kenmore Elite Stainless Steel 40" Dual...
Water heater appears to override thermostats. Water gets scalding hot. This has happened twice. First time I replaced both thermostats. Set both at 120degrees. Model 640DORS Sereal# CO5A035030Thank you
1) There is a water heater condition called 'stacking'
2) Dual element tanks are 240Volt.
Thermostats turn off 1 leg of 240Volt circuit.
If element is shorted to ground through center of element, it might not trip the breaker.
In this case, the bad element would continue heating with 120V through ground wire.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 01, 2011 | Reliance & 40 Gal Electric Mobile Home...
No heatinh - Westinghouse SB925SJ*00 - suspect dual water sensor (Water presence and temperature). Require price and availability. Thanks.
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 30, 2010 | Westinghouse Dishwashers
Looking for grill element for belling 924
Im selling a grill element for 100 dollars very very cheap!
email me at
Nov 01, 2009 | Belling 924 Dual Fuel (Electric and Gas)...
The dual output burner does not work. I measured the resistance across the terminals for each element and it appears that there is a break on the common side of the elements. Are there replacement elements...
Those "Dual Heat Range" burners are available. Go to, click on "Parts Direct", enter model number, press enter, when next screen pops up look on diagram for your burner, then scroll down to find part number & price. Then search the internet for cheapest price and delivery. Those burners average 150.00 - 300.00.
Sep 23, 2009 | Maytag Admiral LER3330AAW / LER3330AAZ /...
Kitchen Ranges Logo
32 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
