Question about Baby Lock Sewing Machines
Baby lock elegante2, presser foot is going up and down constantly and will not stop
Was sewing great, stopped to refill bobbin and when retreaded and new bobbin stalled, it started this!
  • 27 Answers
SOURCE: Model 6230- presser foot lifter won't move presser foot
That's the problem seized up use a penetrating oil from the top and work it up and down and it should free up
Posted on Jan 14, 2009
  • 186 Answers
SOURCE: MC 11000 janome stops reading presser foot "p"
This is a relatively easy adjustment as I just did one last week but I'm not sure I can explain it. Anyway, open up the lamp cover and look at the top of the presser bar. There is a sensor that is easily adjusted. It has a small phillips screw that you need to loosen. Then move the black 'L' shaped piece either up or down a little (I can't remember which way) and re-tighten the screw, you may need to experiment. The 'L' shaped piece is a flag that goes between two sensors when the foot is raised and can be rotated left and right about 10 degrees. I hope that helps.
Posted on Feb 08, 2009
  • 69 Answers
SOURCE: Machine slows down,stops, starts again. Foot control problem?
Yes it does sound like a faulty foot control. The power cord is probably fine, you just need the controller. Ebay is a good source for parts.
Posted on Feb 09, 2009
  • 1788 Answers
SOURCE: presser foot stopped working I turned
Did you connect your machine then press the foot control before you lowered you presser foot? I have a CS6000 and that is what E1 means on my machine. You did not put your model number in so I don't know. You can look in your manual or go online to and look it up for your machine. Try unplugging and plugging it in again, but put your presser foot down then step on your foot pedal.
Posted on Oct 04, 2010
  • 86 Answers
SOURCE: Kenmore sewing machine Model 1602:
Sound like you need to take it out of bobbin winder mode. Suggest looking for a way to engage the clutch. Turn the center knob on hand wheel and or move the bobbin winding post back to postion.
The center hand wheel should move about 1/3 turn towards you to look it back into place.
Posted on Feb 11, 2011
Won't catch the bobbin thread everytime. skips. I have retreaded everything several times, reajusted tension, and even the presser foot tension.
Install a brand new needle.
Check the upper tension: Remove the thread. RAISE the presser foot and rethread from the beginning. This ensures the thread is seated properly in the tension disk. Make sure the bobbin case is threaded properly.
If still missing the bobbin thread, it probably has a needle/hook timing issue.
Feb 10, 2016 | Sewing Machines
Needle hits bobbin case
The bobbin case has to be positioned properly in the race. When the stitch plate is removed the bobbin case can be inserted in the wrong orientation to the stop finger. So if I can the presser foot location 12 o'clock, the tension screw for the bobbin case should be at 6:15 and the stop, which I think looks like a little nose, should be at 5:45. This little nose like projection should nuzzle up against the stop. If the needle hits the bobbin case when the bobbin case is inserted correctly, go see a dealer, your machine is broken.
Dec 06, 2013 | Baby Lock Sewing Machines
Walking Foot Trouble
sounds to me like you are getting what I call "flagging" of the material... where a tiny bur or something catches the material and pulls it up. If possible increase the presser a bit on the presser foot. You might also have the wrong foot for the machine or simply a defective one.
Also when it does this... do you notice any bobbin thread on top of the seam?
Feb 25, 2013 | Baby Lock Sewing Machines
Bobbin thread shows on embroidery machine
Did you remember to put down the presser foot?
Nov 13, 2012 | Baby Lock Sewing Machines
I have a brand new Janome 200e and when I try to use it it stops and tells me to retread. The thread isn't broken and I have tried new thread and new bobbin. And have made sure the bobbin holder was free...
Remove all the thread from the machine.
Verify the bobbin is loaded and turning the correct direction in the bobbin case.
ALWAYS RAISE the presser foot and rethread the top thread. Verify the thread path is correct.
Set the top tension to the midpoint and then tweak as needed so the two threads meet in the middle of the fabric when stitching.
Dec 08, 2017 | Sewing Machines
Feeddog won't move with pressure foot down. I have a Baby Lock BL4-428. I haven't used it in a while. I cleaned it up and oiled it. The feeddog moves when the pressure foot is up but as so
it sound like the feed dog & the presser foot need to be adjusted
so they work togeather,,it's very possible they need to be timed
a sewing machine repair shop can tell you for sure
Sep 05, 2012 | Baby Lock Sewing Machines
We have a Touch & Sew 640 that we ARE trying to get running, and we need a manual, and specifically how do w thread the bobbin.
To wind the bobbin, select straight stitch, thread the machine up as normal making sure the presser foot is up, open the slide plate, push the little button over to raise the winder, take the thread and wind it round the presser foot screw a few times, press on the foot control slowly and the bobbin will wind, when you have enough, stop, close the slide plate to drop the winder down, pull the threads to the back and start sewing. for manuals try
Jun 24, 2010 | Singer Touch Sew 7462 Mechanical Sewing...
I reloaded my bobin and began to sew. The thread
Sometimes it may look like the bobbin is the problem, when it is actually the machine was threaded with the presser foot down.
Refer to the manual for your machine and recheck the direction the thread is be feeding from the bobbin and that it is going through the proper guide(s).
Always thread a sewing machine with the presser foot up.
When threaded with the foot down, the tension is closed and the thread cannot enter. When you sew, the stitches are loose and loopy.
Feb 24, 2010 | Baby Lock Sewing Machines
Top thread will not move when presser foot is down
This machine has a tension roller system that meters out thread when the machine is running. When stopped it is locked up so you won't be able to pull thread thru with the foot down.
Hope this helps.
Nov 14, 2008 | Baby Lock Esante
Sewing Machines Logo
14 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Jon Piercy
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
