Question about ASUS A8V-E Deluxe Motherboard
Asus A8V-E not start
Ho una MB asus A8V-E.
ad qualche giorno, non avvia il sistema
test:
ram: 1GB test=ok
HD: 500 GB test=ok
SVideo: radeon test=ok
Alimentatore: ATX 400W test=ok
connettori: speaker reset, ecc... OK
no test: CPU + MB.
cosa accadere?
quando avvio il computer, si accende il led rosso ed il led verde; si accende la ventola della CPU; riscalda poco la CPU;
Ma il computer rimane come bloccato !
non procede con il POST (Power On Self Test);
lo speaker, non emettere suono!
come posso intervenire?
ho sempre avuto problemi di blocco immagine; errore di sistema; impossibile avvio; ma adesso non ripara più!
Grazie per aiuto
I have a asus MB A8V-E.
for a few days, do not start the system
test:
RAM: 1GB test = ok
HD: 500 GB test = ok
SVideo: radeon test = ok
Power Supply: 400W ATX test = ok
Connectors: speaker reset, etc. ... OK
no test: CPU + MB.
what happen?
when I start the computer, turns on the red and green led.
you turn the CPU fan.
heats just the CPU.
But as the computer is locked!
not proceed with the POST (Power On Self Test);
the speaker does not emit sound!
how can I help?
I have always had problems blocking image, system error, not start, but now no more repairs!
Thanks for help
  • Anonymous Mar 24, 2014
    nella fase iniziale ho toccato i cerchietti apparsi sulla prima schermata ed ora non ricordo la progressione
    ho bisogno di ripartire da capo e riprogrammare il blocco iniziale
    Problem Solver:
  • 7 Answers
Looking at this post, I think your Motherboard is bad.
Have you tried a different Video Card?
My other thought is the CPU is overheating due to incorrect seating of the FAN and heat sink.
Try cleaning the CPU off, and put new paste on the CPU, then re-seat the heat sink.
Be careful to make sure the anchors are pushed all the way down by slightly twisting or wiggling the heat sink.
Check for looseness.
Push down on all memory sticks to ensure they are seated all the way in.
They should click on both sides.
If it still gives you a red light, then contact the website of the manufacturer, and get an RMA number for a replacement.
Posted on Jul 24, 2009
Buon giorno, la mia macchina Saeco Magic de Luxe e' appena stata in assistenza ed hanno dovuto cambiare la scheda. ora non riesco piuu' a far girare acqua nel circuito. accendo la macchina ma mi...
Anch'io ho lo stesso identico problema, l'ho smontata, ho dato un'occhiata e credo di aver capito che il problema sia la turbina (rotta) ma non ne sono sicuro..!! Ho dato un'occhiata in rete e una turbina costa circa 12 euro... credo convenga fare questo tentativo..!! Ciao Adriano
May 10, 2011 | Saeco Magic De Luxe Espresso Machine
SmartBase MP360 appena avviata per qualche secondo fa rumore di pettine contro acciaio e non funziona
Questo rumore clunking / rettifica di solito ? un ingranaggio inceppato o una barra di controllo provocando qualcosa da cedere il passo (di solito l'elastico con i denti su di essa dietro la testa). Ho risolto i problemi simili su HP e Epson e ogni volta che ha bisogno di una striscia gi? e un attento esame delle lavorazioni. con Epsons di solito era un ingranaggio che aveva saltato un dente e poi la tempistica era fuori causando un inceppamento. Con polipi iperplastici, di solito un frammento di carta nelle opere o inchiostro schizzato su uno dei tanti sensori ottici, facendo accadere le cose nell'ordine sbagliato. Il mio MP360 inceppata con i capi in sosta (ma senza clunking). Ci? ? stato causato da inchiostro secco mescolato con polvere di rendere il meccanismo di pulizia pigro e (in qualche modo) jamming la testa. Ho preso le coperte per spegnere la stampante (un lavoro lento) e pulito tutto, ri-ingrassate. problema scomparso. Attualmente ho le teste ammollo in una miscela di alcool, detersivo liquido e acqua per sbloccare le teste di nuovo.
Jan 19, 2011 | Canon Office Equipment & Supplies
Salve , possiedo un samsungHT-DS400 che quando vado ad accendere mi appare sul display la scritta on protection per qualche secondo...per la samsung il pezzo che andrebbe sostituito non è...
Ciao Massi.
Come saprai, protection indica un errore generale, e non dice dove sia il problema. Semplicemente indica che il tuo Samsung ha rilevato un voltaggio incorretto, e che il sistema viene temporaneamente forzato in stato di standby chiamato protection (i Massive Attack ci avevano fatto su una canzone).
Il supporto tecnico Samsung non sa quale parte non funziona, semplicemente sospetta che il problema sia la PSU (circuito di alimentazione), la quale e' probabilmente il guasto piu comune in questi apparati.
Siccome le parti per questa unita' non sono piu distribuite (solo il telecomando e' disponibile), il supporto tecnico ha giustamente consigliato di sostituire il sistema.
Qui lista parti, le poche parti elencate non sono in stock.
Tutto quello che puoi fare e' assicurarti che le connessioni alle casse ed al sub siano intatte. Se un cavo fa corto, allora l'unita centrale segnala Protection.
Se il problema non e' un cavo balordo, l'unita centrale, il Sub, e qualcke volta ancke le casse (connessione ai coni in corto) devono essere aperti e testati da un tecnico.
Un lavoro del genere puo richiedere svariate ore, e generalmente non vale il prezzo dell'originale in un unita di questo tipo.
La riparazione e' fatta testando i punti di saldatura e i componenti, e richiede conoscenza tecnica.
Controlla i cavi, se non trovi niente, la riparazione puo essere fatta da un tecnico locale, il prezzo in Italia e' probabilmente tra i cento ed i duecento euro. Sono piu di dieci anni che io non lavoro piu in Italia e non saprei dire. Quando lavoravo li' la tua fattura sarebbe stata intorno alle 80/100mila lire un po meno se il problema si trova immediatamente (a volte puoi proprio vedere che un componente e' esploso, accade frequentemente con i condensatori dell'alimentatore, altre parti, come I chip del finale dell'amp, non mostranon alcun segno quando vanno male, nel tuo caso il problema non deve essere facile da identificare a prima vista perche il sistema ancora funziona, con un condensatore esploso il sistema rimane in protezione ).
Buona fortuna.
Ginko.
Sep 29, 2010 | Samsung HT-DS400 System
Il mio Acer T180 non da più segni di vita nel senso che, collegando il cavo di alimentazione, non si gira nessuna ventola e non si accende nessuna spia L'unica prova che ho fatto è...
Sembra che il vostro alimentatore pu? essere morto, perdona il mio italiano, anche la if alimentazione non si accende non mean it effettivamente funziona, prima di cambiare la tensione, provare questo, scollegare il system, rimuovere la scheda madre battery, tenere premuto il potere pulsante per 30 secondi, rilasciare,, sostituire la batteria, plug-in e si accende,,, se quello non riesce, individuare i pin sulla scheda madre che il pulsante dell'alimentazione si collega anche, ci dovrebbe essere qualche altra cosa l? come bene, come reset, LED di alimentazione e HD LED, assicurarsi che il sistema ? collegato a sua volta e lo ob utilizzando un cacciavite tipo di lama e bridiging entrambi i perni di alimentazione con esso. I apoligise ma non sono molto bravo a itallian Quindi, se ho mescolato tutto mi perdoni ..
Sep 16, 2010 | Acer Aspire™ T180 PC Desktop
Acerw-1.scr
Acer w-1.scr è uno screen saver. Problema è che il risparmiatore dello schermo ha smesso di funzionare. Questo è un problema comune con Acer computer. Cerca questo file ed eliminarlo!
Jul 12, 2009 | Acer Aspire™ T180 PC Desktop
Problemi con explorist 500
Ciao, mandami una email a casa1111@libero.it altrimenti tramite questa via ci mettiamo fino all'anno prossimo. hai messo una basemap europea sulla SD card? nella directory "Backgroud maps"? se hai fatto così avrebbe dovuto sentirtela. Se in ogni caso metti la basemap europea nella directory USBTRANS della SD card dovrebbe caricartela nella memoria interna del GPS (dopo il caricamento non è più presente nella SD card, per cui se devi ripetere l'operazione devi rimettercela).
Ciao
Alberto
Oct 04, 2008 | Magellan eXplorist 500 GPS Receiver
Lettore cd/dvd acer aspire 5630
Ciao,
Allora, ho il tuo stesso pc e mi è già capitato il prob. Mi sè risolto formatando il pc ma non è minca finita qui..
dopo un mesetto mi si ripresentato. La coluzione defintiva è stato quella di sfruttare la mia garanzia per farmene spedire uno nouve di zecca. Ovviamente solo il pezzo guasto.
Se no puoi provare a smontarlo e pulire il lettore dvd con l'alcol (xkè evapora).
Tienimi al corrente per eventuali sviluppi.
Ciao
Jul 18, 2008 | Acer Aspire 5630 Notebook
ASUS A8V-E Deluxe Motherboard Logo
259 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
