Is there a fuse inside the back my unit WC 601 isn't cooling
3 Suggested Answers
  • 2468 Answers
SOURCE: My Avanti WC 601 is not cooling.
replace the rtc overload contactor located on the compressors body the relay is weak and not holding anymore,remove the spring wire that holds the overload and capacitor unplug the overload from the compressor and reverse procedure to install
Posted on Jan 17, 2010
cbrtechso88011
  • 260 Answers
SOURCE: xerox WC 7132 printer error code 016-601 error and
  1. Click on the "Configuration" tab
  2. Choose the account mode to "User"
  3. Click on "Detailed User Settings"
  4. Change the password details as per instructions from your printer administrator
cFor more help visit cbrtechsolutions
Posted on Nov 08, 2015
My inside and outside unit turn on fine, out side fan and compressor running good,inside blowing cool air, about four minutes after that, out side unit shutoff, no humming, nothing.
Are you heating or cooling? When the outdoor unit shuts off how does it come back on. Or are you saying that the outdoor unit is short cycling off and on
Jan 17, 2018 | Ruud Heating & Cooling
Ceramic heater only blow cool air
Unplug the unit and look on the bottom or the back, there may be a circuit breaker reset switch.
If not, it's probably a fuse that's blown inside the unit and isn't made to be replaced.
Sep 24, 2012 | Lasko 6405 Designer Series Osc. Ceramic...
HOW TO UNCLOG DRAIN PAIN IN AC WINDOW UNIT
There technically isn't a drain pan in AC units. Some have a little hole in the back, some do not. If they do not, then the evaporator fan "slings" up the water accumulated from the condensation in the air, unto the coil to help cool the inside of the unit. If there is no hole, do not drill into the machine. You are likely to hit a sealed system component and damage the unit entirely.
Jul 29, 2012 | Frigidaire Heating & Cooling
Furnice air blows, but my ac unit outside want cut on
if the inside unit is running but the outside unit isn't - I would check the fuses or breaker. I suspect you have a blown fuse or a tripped breaker.
What is also possible is that the 'low voltage' thermostat wire (coming from the thermostat inside the house) has been cut - possibly by a lawn mower or weed eater - or chewed into by a dog.
If this is the case - you easily splice (with all power off) the wires back together using the color of the individual wires.
Jun 06, 2011 | Heating & Cooling
Air conditioner comes on but is not cooling the house....new house, new unit
Try going outside and locate your outdoor unit. If the thermostat is on, and the fan is running inside, the outdoor unit should be on as well. If it isn't, locate the circuit breakers in your breaker box. There will be two. Trip them back and all the way forward.
If the unit is running outside, sometimes the air cond contractor forgets to come back and charge the unit with refrigerant. In this case be sure to contact the air cond contractor that installed the unit.
May 22, 2011 | Heating & Cooling
My outdoor AC unit is not coming on. Air is blowing out of my vents inside but the snowflake symbol on my thermostat is blinking and the air isn't cold. The fan on the unit isn't even running. Any...
check power to outside unit, check if it has a fused disconnect, if you have power and no blown fuses it could be a blown capicator that starts the fan and compressor...............
May 09, 2011 | Heating & Cooling
My Avanti WC 601 is not cooling. The compressor is not on, however I was able to knock it and it did go on for a few minutes.
Jan 16, 2010 | Avanti WC601CL Wine Cooler
Roof AC on 5th wheeler is not working
CHECK FOR ELECTRICAL POWER @ l1 CONNECTION,IF YOU HAVE NO POWER CHCK THE FUSE,AND INSURE THE THERMOSTAT IS SET FOR COOLING OPERATION. IF THE UNIT HAS LEAKED FREON, A LOW PRESSURE SWITCH HAS OPENED, PREVENTING THE UNIT FROM OPERATING TO PREVENT DAMAGE TO THE COMPRESSOR. DO YOU HAVE A MANIFOLD GAUGE, AND ARE YOU CERTIFIED TO WORK WITH REFRIGERANTS? IF YOU ARE IN COMPLIANCE,HAVE TOOLS AND TEST EQUIPMENT WE CAN PROCEED FURTHER.
Sep 18, 2009 | Dometic Rooftop RV Air Conditioner
No cooling after power out, indicator lights pattern not in manual
The Mitsubishi units have to be reset by turning off the indoor units by switching the remote or thermostat to off. Then turn off the breaker to the outside unit(s). After 30 seconds,turn on the breaker and then you can turn on the remote for cool. If no lights come on on the inside units, most likely you have blown a fuse soldered on the main PC board. At this point, call your technician. A goos tech will be able to wire in an in-line fuse holder so if it should happen again, you can easily replace the fuse. If you do see a light or two come on at the indoor unit but the outdoor unit does not start after 3 or 4 minutes, sounds like you will need to call a technician. Most likely you have a blown fuse on the main PC board of the outside unit. It is not an easy one to replace. Good Luck!
Aug 31, 2007 | Mitsubishi MSH09TW Air Conditioner
Heating & Cooling Logo
21 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
