Question about Smartpool Dolphin Robo - Kleen Above Ground Robotic Pool Cleaner
Robo-kleen workes but only for short distance
Robo kleen will go 3 to 4 feet and then reverse. the robo kleen never goes more than that distance backward or forward.
    Top Expert:
  • Smartpool Master
  • 8,163 Answers
Possible back up valve or board bad
Posted on Dec 09, 2017
2 Suggested Answers
jharwell668
  • 640 Answers
SOURCE: My Robo-Kleen, when I first turn on goes forward a
It sounds like your gear box has gone out. If that is the case, the pool cleaners not going to work until you replace the gear box. Unfortunately, this is something that only a professional can do. Just to make sure that this is the problem, you should first check the wheels for any debris or damage. Then make sure that you don't have any clogs or jammed/cracked hoses.
Posted on Apr 12, 2011
WHEN I START IT UP IT WILL ONLY GO ABOUT 3 FEET AND THEN IT BACKS UP THAT IS ALL IT WILL DO?? SO IN THE 3 HOURS IT IS ON IT WILL ONLY CLEAN A SMALL AREA OF THE POOL
After reading the instructions (looking at the pictures..the directions stink), I found that there was a rod that could be adjusted to change the pattern of the cleaner.
It definitely helped with cleaning much more of the pool.
Jun 19, 2015 | Smartpool Dolphin Robo - Kleen Above...
I have not used my Robo Kleen for several years. It was in storage in the basement. I put it in the pool and at first only moved a couple of inches. I manually rotated the wheels and they are very...
try keep working the wheels, it might free up. should be a easy fix. good luck and vote if'n I was of help.. jay the pool pump motor repair guy longwood florida
Aug 11, 2013 | Smartpool Dolphin Robo - Kleen Above...
When I place my Robo-Kleen in the pool, it now only travels about two feet, rocking back and forth. Occasionally, it will go a few additional feet, but then stops. I also don't seem to be getting the...
I would first check for obstructions in the front and back wheel axles. Then, take the top grill off and make sure that the impeller is not jammed. It sounds more likely to me that you are having a problem with the pool cleaners gear box or drive system. If it is still under warranty, send it back to the manufacturer. If its not, you will need to have it repaired by an experienced pool repair person.
Jul 20, 2011 | Smartpool Dolphin Robo - Kleen Above...
Is there any way I can get a replacement wire for my Robo Kleen? Plug broke off end of wire that goes into power box.
You can try MaytronicsUS to get an answer straight from the manufacturer. If they offer the part you seek they can also refer you to a stocking parts dealer to purchase it.
John
Aug 15, 2010 | Smartpool Dolphin Robo - Kleen Above...
My Robo-Kleen, when I first turn on goes forward a couple of feet, then goes in reverse for a couple of feet then stops altogether. Fan is still working while the wheels are turning however when the wheels...
Aug 10, 2010 | Smartpool Dolphin Robo - Kleen Above...
My Robo Kleen motor is running but the wheels do not move. Please let me know what I can do?
There is a plastic gear in the drive motor that has a pin that goes through it and the drive shaft, this pin actually wears a slot in it from going back and forth and stops driving the unit.
You can probably hear the driver motor cycling forward and reverse.
i have photos of a modification to fix this
Jul 06, 2010 | Smartpool Dolphin Robo - Kleen Above...
What is the output amps on robo kleen transformer
Here is the users manual for these pool cleaners. You might be able to locate the information you are looking for there in the parts specification manual.
http://www.backyardcitypools.com/Pool-Cleaners-Automatic.htm
Jul 03, 2010 | Smartpool Dolphin Robo - Kleen Above...
ROBOT GOES BACK AND FORTH 2 FEET ONLY
There are several things to check for with these pool cleaners. First, make sure that there are not kinks or knots in the cable that would restrict movement. Make sure that there is not hair, fabric, or other debris in the impeller. This can also cause the back and forth movement. Check for debris or leaves caught in the axle bearings.
Aug 02, 2009 | Smartpool Dolphin Robo - Kleen Above...
Transformer turns on but robot in water don't turn on no movemen t or water flow
I had same problem unplug unit wait for 30 seconds and try it again I had to do this 3 times this a.m. I am having problems with it only going 2 or 3 feet.
May 25, 2009 | Smartpool Dolphin Robo - Kleen Above...
Smartpool Dolphin Robo - Kleen Above Ground Robotic Pool Cleaner Logo
59 people viewed this question
Top Smartpool Pool & Spa Experts
Craig Butler
Craig Butler
Robert Plante
Are you a Smartpool Pool and Spa Expert? Answer questions, earn points and help others
