Question about Saturn Vehicle Parts & Accessories
2008 saturn aura viper remote starter. Remote started the car it starts and cycles to start again.
  • 22 Answers
SOURCE: Viper remote starter sets off alarm.
Whoever hooked up your system did not hook up the factory alarm disarm and arm wires. Your car thinks it is being stolen as a result of this. You need to get a wire diagram of your car and hook up the proper wires.
Posted on Dec 04, 2008
  • 344 Answers
SOURCE: Ive installed a Bulldog RS82 remote starter on a
there is no solution to this, it is factory setup to prevent you from locking your keys in the car when it's running and so the trunk can not be opened by accident
Posted on Jan 04, 2010
  • 160 Answers
SOURCE: Viper 5101 Manual Transmission - can't start
First off, is it in neutral? It can't engage the starter motor if it's in gear. Secondly, If it was professionally installed, why not just take it back and demand that they fix it?
Your wiring should somewhat match this.
Posted on Jan 13, 2010
  • 170 Answers
SOURCE: 2007 Saturn Aura; when trying remote start horn
press the lock button on the remote then press the remote start button. if this does not work check remote start status using steering wheel buttons
Posted on Jan 18, 2010
  • 344 Answers
SOURCE: viper remote car starter 479V
press and hold the ( P ) button until one long beep is heard, you now have 5sec to push the lock button to turn on or off the vibrate, wait another 5sec and it will automaticaly exit programming
Posted on Jan 28, 2010
Testimonial: "One word,AWSOME!"
Remote starter only allows my starter to turn over twice; needs at least 3 with my key. How to adjust to have it starter run longer on remote?
I know you are looking to have the remote starter run a third time but I would say you need to look at your Fuel Pressure Regulator on the Scion. Sounds like it is not holding fuel pressure at the fuel rail and that is why it requires a third Crank
Jan 05, 2016 | 2006 Scion xB
2008 toyota tundra 5.7L Truck's electrical system drained drastically. I replaced the battery, and after one start, it went dead again with in 10 minutes. show very little light. on dash board. Voltage of...
is the alternator charging ok is the first thing to check when you've got the engine running if thats ok i'd disconnect the Viper remote as from your description it could be draining the battery/not working properly put back to original factory spec and run like that for a while then you'll know if its the Viper or not keep me updated
May 04, 2014 | Cars & Trucks
Remote start for 08 saturn aura will not work
hood switches are quite common issues for all remote starts, if you have a visible switch under your hood, a lot of times you can bend the switch mounting upward slightly causing the hood to press the switch down further making the connection to enable the remote start. if there is a visible hood switch, you should be able to press the switch all the way down with you finger , then with your other hand press the remote start button to see if it starts. if it does then you know that's the problem. if there is no visible switch then obviously my solution will not help. the certain number of flashes will let you know if is reconizes an open door or not. check with a local shop that installs remote start systems and they may be able to help you for no charge to let you know what the flashes are telling you
Apr 24, 2014 | 2008 Saturn Aura
How do i know if my wifes car is equipped with a remote start system?
Key FOB is to unlock the doors & set the security system,
nothing to do with a remote start
Feb 05, 2013 | 2008 Saturn Aura XE
I need instructions on how to use my viper 5101 remorte starter
go to this is the manufacturer of the viper remote starters, there you should be able to download instructions.
Here is how you program the viper 5101 remote.
Programming the Viper Remote Starter 5101
Unlock the doors before starting
Push and hold f button for 8-10 seconds until amber light is on solid
Push Remote start button for about 4 seconds till amber light flashes 3 times
Put key in IGN to the on position but don
Dec 30, 2010 | 5101 LE 1 Way Car Remote Starter System
Viper 5701 remote issue
sounds like the remots have lost two way communication. try to disconnect the windsheild antenna.try remotes again after pluging antenna back in.
Feb 07, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
2007 Saturn Aura; when trying remote start horn beeps three times but doesn't start. I've replaced battery. Other functions work fine - door locks, trunk opens, alarm arms. Other key fob works fine.
Jan 03, 2010 | 2007 Saturn Aura XR Sedan
2008 Aura XR, Key FOB will unlock all the doors but the drivers, and will only remote start the car if the Fob is in the car.
Interesting. My best guess is that there is problem with driver's door lock actuator or switch. The remote start won't work because the car has to confirm that the doors are locked before initiating the starting sequence.
Oct 23, 2009 | 2009 Saturn Aura
Vehicle Parts & Accessories Logo
55 people viewed this question
Top Saturn Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Tim Garcia
Tim Garcia
Lawrence Oravetz
Are you a Saturn Vehicle Part and Accessory Expert? Answer questions, earn points and help others
