Question about Refrigerators
OGYJ1103 micro has burn thermostat on the one onopposite side form control panel. What is power and temp rating and where can i get this part ?
5 Suggested Answers
billyvangogh
  • 108 Answers
SOURCE: No power to the thermostat control panel
Check for and replace batteries in the thermostat , Check the furnace Fuse or breaker , and also most newer furnaces have a circuit board typically in the lower fan compartment , which will have a 3amp fuse which looks identical to a Car Fuse plugged in , make sure the furnace switch is on...if all these prove to be ok the thermostat itself or the wiring is defective
Posted on Oct 25, 2009
  • 185 Answers
SOURCE: rs265...both sides will cool down/freeze
Thats sounds right. These digital frigs are very nice except when you are trying to fix it!!! Expensive!!! Call Samsung and ***** like you never ***** before!!! this is unacceptabullshit!!! Tell them (even if it is out of warranty) that Consumers Report we love the negitive review you will give them if they dont come out and fix it!!! There should be many peolpe complaining about the same problem They can even send you a voucher check for a new one. Why not they have billions!!! You have to be pissed and demanding.
Posted on Mar 27, 2010
baraquielnar
  • 247 Answers
SOURCE: Have GE sxs LSS25XSTB that condensor fan burned up
try to replace the original main pcb board maybe your board that u install have lack connection on temp. board.
Posted on Jan 23, 2011
freetek
  • 5568 Answers
SOURCE: Whirlpool gold side-by-side refrigerator. When I open the fridge side, the lights blink one and off several times (slowly, in a steady pattern) then goes off. The temp control readout is also off.
It may be a low temperature warning. I would at least ignore it overnight.
Posted on Oct 06, 2014
I have a built in wall oven whirlpool gold mod.gbs309pvsoo controls turn on but no heat from element
Could be element could be Hi limit thermostat could be control. In that order. First step is turn breaker off and remove element to make sure the wires are still connected to back of element. Visually inspect element very good for burns or a white powder residue signally the element burned up. Next step is harder, need to remove the oven and take off back panel, there you will find the hi temp thermostat. Check for continuity, if none replace.
Feb 02, 2015 | Whirlpool GSC309PVB 30" Built-in Microwave...
My hotpoint oven is burning everything so need to know what to replace
If your oven is burning everything, it is getting too hot. Therefore the heater is working but the thing that measures the temperature is not. This is called the thermostat and there will be two types, one for each oven.
Google search for Hotpoint UY46 thermostat, there are plenty of suppliers. Make sure you get the correct one for the oven that is burning.
They are about 20-30 pounds to buy and generally easy to change. Just make sure the power is turned off before working on the oven and be careful of sharp edges as it is easy to get cut when removing panels.
Good luck.
Sep 01, 2014 | Hotpoint UY46 Style Line Stainless Steel...
GET 0E CODE SHOWING ON MY LG DISHWASHER
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
if that doesnt help you.....
the problem IS NOT necessarily a blocked drain hose or the drain pump it could be the thermostat micro switch!!! the thermostat is located at the rear of the right bottom side of the dishwasher(held by oval nylon plastic housing). Turn the machine off. remove the right side panel.(remove top {2screws in lid at back}, remove right panel screws {2 behind door, 3 bottom back panel, 2 behind panel below door {pull panel out from top [no screws pushes in & out of place]}. Locate oval nylon/plastic shape located as above - micro-switch is in the middle (3 wire connectors in 1 block) thermostat is 2 connectors ( 1 each side of micro-switch). use screwdriver to push thermostat back into the nylon housing on both sides (it has worked its way out a bit over time and stops the micro-switch working). Reassemble and dishwasher starts to work again!!!!
Aug 28, 2010 | Dishwashers
The coils in the freezer compartment keep freezing over causing the refridgerator temp to rise
Most times the defrost heater and defrost thermostat need replaced. manually defrosting, removing rear panel in freezer, unplugging power from wall and using a hair dryer to remove the ice allows you to visually see th defrost heater burned out. I will get some photos and links and return soon, Thanks Sea Breeze
Apr 19, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Describe your Frigidaire FSC23R5DSB Side by Side Refrigerator Problem the refrigerator is not cooling
That is the first sign of not defrosting. Look into the rear panel in back of freezer and see if frost is forming on that back panel. If yes then you will need to unplug and remove that panel to inspect the defrost heater and defrost thermostat. If they check out then we need to inspect both sides of the mother control board for burn marks or signs of heat damage. The 1467835 Control Board is located on the back and enclosed inside a plastic housing. The same circuit board also list as part number 241511101 Check the freezer first to see if the defrost heater may be bad. Need an OHM meter and take one wire off of one end to test. I will walk you through this if you want, Sea Breeze
Aug 21, 2009 | Frigidaire FRS26H5AS Side by Side...
We had a power outage and top half will not work
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 08, 2009 | Refrigerators
Whirlpool side by side Model ED22DQXAB11 Lights are on that's it. What should I change in the control area. Can the PC board go bad?
Check your thermostat assembly.
That is the off/on and temp control in the control panel.
It controls power to the entire machine except the door lights.
Mar 04, 2009 | Refrigerators
My GSS22SGRE Side by Side freezer & Refrig temp is too warm
Possible the defrost thermostat is bad and need to be replaced. Not allowing the evaporator coil ice buildup to melt , which acts like an insulation and restricts the air flow in the freezer compartment.
Jul 31, 2017 | GE (PSS26MSRSS) Side by Side Refrigerator
Gh5184xp no power
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our site, we have a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
The fuse and magnetron thermostat can be checked without pulling the oven form the wall.
But if you need to check the cavity thermostat, the oven will need to be removed from the wall, and it helps if you still have the installation instructions.
Whirlpool customer service is here and you can also enter your model number on that page to download your owner's manual, installation instructions, etc..
Oct 21, 2008 | Whirlpool MH7140XF Microwave Oven
Refrigerators Logo
22 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
