Question about Internet Computers & Internet
My ip address fails on and doesnt connect to internet
    Habit-Forming:
    New Friend:
  • Internet Expert
  • 171 Answers
Hello, I do not what O.S. you have, but on Windows 10 to reset the TCP/IP address, you need go to
from the taskbar , click Star icon/ in the search field enter CMD and then press enter / The Command Prompt window displays
- to view you IP Address, enter ipconfig and then press Enter; the numbers and dots represent you address / display represent your address.
  • To release your IP address, enter ipconfig/release and press Enter.
  • To renew your IP address, enter ipconfig/renew and press
  • Enter
    When you finish close the CMD windows
    Posted on Apr 21, 2017
    jasonkoe
    • 64 Answers
    SOURCE: ip address failed
    If you are behind a router.. try hooking it up directly to your cable modem or DSL modem. If that fixes the problem then you need to open ports on the router to allow the connect to get routed to your xbox.
    http://support.microsoft.com/kb/908874
    Posted on Jan 18, 2008
    SOURCE: Internet connection failed but IP address obtained.
    OK IF YOU HAVE PS3, and you get the ERROR DNS while trying to login into PSN, all u need to do is, shutdown the console, then restart it by holding down the ON button on the PS# not the controller till you hear 2 beeps, then try to login again, should work.
    Posted on Jun 07, 2008
    SOURCE: Connecting Brother MFC 7420 thru Dlink DP301P Print Server to home network with ONLY dynamic addressing
    do you know how to network a 7420 fax ?
    Posted on Jul 11, 2008
    SOURCE: Hi, my ps3 is connected
    I am having the exact same problem and no idea how to fix it
    Posted on Jul 27, 2008
    cpenzes
    • 1102 Answers
    SOURCE: dns error # 80710102 ip
    in network connections right click your connection click to repair this
    should renew ip address and fix any dns errors
    please let me know
    Posted on Feb 22, 2009
    Can't connect bluray to WBR1310
    If the IP address is fixed in the BlueRay player, I would reboot the router or modem, which will reassign IP addresses. If one is in use, such as the Blue-Ray, whichever device is currently using it will get assigned a new IP address, assuming it too is not a fixed IP address.
    Oct 27, 2017 | D-Link WBR1310 Wireless Router
    Cant connect to my wireless router and the 192.168.01 url entered doesnt help none
    Windows XP
    1. Verify Ethernet adapter in device manger.
      1. Click Start > Search > Type in ncpa.cpl and press Enter.
      2. Click System>Hardware > Device Manager
      3. Click Network Adapters
      4. Verify adapter present, enabled, and no error messages.
      5. If error reported refer to OEM regarding error receiving
    2. Open the Network Connections window.
      1. Click on Start > Run > Type in ncpa.cpl and click OK.
    3. Double-click on the Local Area Connection icon.
    4. Click the Support tab.
      1. Ensure that Address Type: says "Assigned by DHCP."
      2. Ensure that the IP address is valid.
      3. If both are correct, click the Repair button and then skip to Step 9.
    5. If it does not say "Assigned by DHCP" click the General tab and then click Properties.
    6. Select "Internet Protocol TCP/IP" and then click on the Properties button.
    7. Ensure that the radio buttons are marked as "Obtain an IP Address automatically" and "Obtain a DNS Server address automatically" and click OK.
    8. Click OK again to close out of the Local Area Connection properties.
      1. Restart the system if any changes were made to the configurations.
    9. Right-click on Local Area Connection and select Repair.
    10. If the repair fails because the system is unable to flush the ARP Cache, the Routing and Remote Access service will need to be stopped and set to disabled.
      1. Click Start>Run>Type services.msc >Click OK.
      2. Double-click on Routing and Remote Access.
      3. Click the Stop button.
      4. Set Startup Type to Disabled and click Apply, then OK.
      5. Restart system.
    11. If the Repair fails to renew the IP address, ensure that all firewalls are disabled and try again.
    12. If it still fails, reset the networking protocols.
      1. Click Start>Run>Type CMD and click OK.
      2. Type netsh int ip reset reset.log and press Enter.
      3. Type netsh int ip delete arpcache and press Enter.
      4. Type netsh winsock reset and press Enter. (SP 2 or later)
      5. Type ipconfig /flushdns and press Enter.
      6. Restart the system.
    Windows Vista
      2. Click Hardware and Sound > Device Manager
    2. Open the manage Network Connections window.
    3. Right-click on Local Area Connection and select Properties.
    4. Uncheck Internet Protocol Version 6 (TCP/IPv6).
    5. Select "Internet Protocol Version 4 (TCP/IPv4)" and then click on the Properties button. (Do Not Uncheck Version 4).
    6. Ensure that the radio buttons are marked as "Obtain an IP Address automatically" and "Obtain a DNS Server address automatically" and click OK.
    7. Click OK again to close out of the Local Area Connection properties.
      1. Restart the system if any changes were made to the configurations, including unchecking TCP/IPv6.
    8. Right-click on Local Area Connection and select Diagnose.
    9. If Diagnose fails to renew the IP address, ensure that all firewalls are disabled and try again.
    10. If it fails again, choose to "Reset the Network Adapter."
    11. If it still fails, reset the networking protocols.
      1. Click Start>All Programs>Accessories.
      2. Right-click on Command Prompt and select "Run As Administrator"
      3. Type netsh int ip reset reset.log and press Enter.
      4. Type netsh int ip delete arpcache and press Enter.
      5. Type netsh winsock reset and press Enter.
      6. Type ipconfig /flushdns and press Enter.
      7. Restart the system.
    Windows 7
    I hope this helps
    Oct 01, 2010 | Computers & Internet
    Hi. i cant connect to print server d-link dp301p+ IP to configure it?! who knows what IP by default it have? 192.168.0.10 doesnt work... Thanks, Mike
    First find out the IP address , Subnet mask,and Gateway addresses of your ISP ( Internet Service Provider ). According to above addresses, you have to complete the network settings of your printer by mentioning the different IP address .
    To find out the above mentioned addresses, first open the control panel -> network connections -> local area connction -> properties -> Internet Protocol Version 4(TCP/IPV4) OR Internet Protocol Version 6 (TCP/IPV6)according to your ISP -> Properties
    By the systematic selection as mentioned above you will get the IP address, subnet mask and Gateway addresses.
    Suppose your IP address is 192.168.0.10 , the gateway may be 192.168.0.1 Or any number. And the subnet mask may be XYY.XYY.XYY.0.
    According to your ISP addresses you have to complete the network settings of your printer. First press the additional functions -> system settings -> network settings -> TCP/IP settings -> fill up the addresses as follows.
    IP address : 192.168.0.16 OR any number .
    subnet mask : XYY.XYY.XYY.0.
    Gateway : 192.168.0.1
    Hurray ! the problem about your network connection with the printer to your computer will be automatically solved.
    Sep 28, 2010 | Computers & Internet
    This sucks
    try to check the right ip address by connecting it first to your computer, check the ip address on your command prompt ( if you are using windows platform ) then type ipconfig /all
    take note of your gateway, dns server, ip address ( so that your in the same network ) and the subnet mask.
    Aug 18, 2009 | Sony Playstation 3 (PS3) Console
    Billionton USB : Class 1 USB Bluetooth adapter
    before you try any step i tell you please disable your antivirus and firewall.
    well!! I have an answer for you.your comp is loosing the IP address. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
    Jul 01, 2009 | Billionton Long Range Bluetooth USB...
    Failed Ip adress for xbox live
    First i want to know how is your xbox 360 connected to the internet? For example ( Modem Connection?, Router Connection?, Or Wireless Connection?
    Here are some steps that you need to try:
    1. Turn off your cosole wait for 20 seconds and then turn it back on, then test your xbox live connection
    2. Go to your network settings
    3. Select restore to factory defaults and test your xbox live connection
    Apr 03, 2009 | Microsoft Xbox 360 Console
    Failed ip address
    your ip address should be activated by your isp
    and then manually put it in the smart phone
    Mar 04, 2009 | Microsoft Xbox 360 Console
    I went and got static IP addresses from internet provider...Must of caught them on a good day
    Apr 24, 2008 | Brother MFC 7420 All-In-One Laser Printer
    Wireless connection of xbox 360
    you can find your I.P adress on the PC you use at home that is connected to the wireless modem.
    if not theres an option on the xbox 360 to find the I.P automaticly try that!
    hope this helps please rate me
    Regards Grant
    Nov 25, 2007 | Microsoft Xbox 360 Console
    My router doesnt seem to be Broadcasting the wireless connecition!
    it may be that the router is not assigning ip addreses properly, and is duplicating the ip address on all pc's. or you have done the windows diagnose and repair or detect problems. Go to the properties of each wireless card in control panel>network connections and on the TCP/IP line click propertes again and ensure obtain ip address automatically is checked. Also go into the routers settings and ensure DHCP is enabled to give all pc's an automatic ip address. Restart all pc's and your router (not Reset) and you should get renewed ip addresses and be able to connect.
    Sep 13, 2007 | SMC Barricade g SMC2804WBRP-G Wireless...
    Computers & Internet Logo
    67 people viewed this question
    Tejodhar Atreya...
    Tejodhar Atreya...
    vojvodabudva
