Question about Viper Vehicle Parts & Accessories
Viper remote start starts car then shuts down and restarts
  • 26 Answers
SOURCE: viper remote starter-
The start/stop 3x thing could be one of a few main issues. You need a bypass module or it needs to be reset. You need to program the tach if you're using it. Make sure with the new models(5101, 5301) it's programmed for auto transmission. The come default for manual transmissions.
Posted on Jan 16, 2009
  • 24 Answers
SOURCE: Replaced the battery in my car need to reset my viper alarm
Alarms are not supposed to shut down the engine while you are driving if it was installed properly. Could be another installed accessory or the car itself has a problem. If it was in anti-hijack mode, you would receive a warning like honking horn. You may have to visit a repair shop and maybe your local Viper dealer to have them take a look. DC
Posted on Nov 04, 2009
deadrock69
SOURCE: Viper 5901 Starting issues
i need to adjust the time that it waits to start for my glow plugs in my 2001 ford excursion diesel 7.3. I need it to wait another 10 - 12 sec.
Posted on Jan 07, 2010
  • 171 Answers
SOURCE: disable viper alarm
Yes the best way is disarm the alarm and put in a Valet Mode
To activate the Valet Mode do the following:
There is a push button or toggle switch to disable the alarm (to engage the valet mode). Without knowing where this
switch is you won't be able to disconnect the alarm.
1. Put the key in the ignition and turn it to the "on" position.
2. Flip the toggle or hold the push button for at least 5 seconds.
3. The LED. light will stay solid on.
4. Turn the ignition off
5. Release the push button. If you have a toggle leave it alone in step 2
Posted on Jan 08, 2010
MECP Guy
  • 344 Answers
SOURCE: viper remote car starter 479V
press and hold the ( P ) button until one long beep is heard, you now have 5sec to push the lock button to turn on or off the vibrate, wait another 5sec and it will automaticaly exit programming
Posted on Jan 28, 2010
Testimonial: "One word,AWSOME!"
Car with viper remote starter starts but shuts off when the door opens?
That's a theft deterrent feature. Sounds like the programming needs adjusted. It's assuming that the car is still armed or perhaps it is? If the car is unarmed it will not shut the vehicle down when the door is opened.
Dec 03, 2017 | Viper Vehicle Parts & Accessories
Viper 7153v remote start. I had some work done to my 2005 Ford F250 and not when I use the remote start, the truck will start,shut off in about 15-20 seconds, then restart and continue the cycle.
Just had the same issue with my remote start. 2006 f-350 with a 6.0 powerstroke. Remote start module was in virtual tach mode and that does not work with diesel engines. Just had to have the remote start reprogrammed and put back into tach sense mode. Hope this helps.
Oct 07, 2016 | Remote Start System
My battery died recently and now the remote start will start the vehicle but shut it down within seconds.
You need to re-program the TACH wire.. open the door start the car with the key, between 5 seconds press the valet switch 1 time and press it again and hold it until the led flashes and the car will beep and then turn it off and start the car with the remote and it should be programed now. if that doesn't work take it to a authorized viper dealer to have it fixed.
Mar 30, 2015 | Remote Start System
My viper remote worked perfect, until now. the unlock/lock and function button work perfectly, except now the car wont start. the start button works and the car tries to start but shuts down. all the...
The issue is not with the remote as you have stated the vehicle attempts to start. The issue may be with an immobilizer bypass module but, I can't say for sure because you mention the year/make/model of the vehicle. Usually the vehicle will give you visual reason for the failed attempt( the lights will flash a set number of times). But, in any event, the issue is not with the remote and more information is required to assist you.
Apr 26, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Will not unlock doors. Battery is good and flashes all lights on transmitter and LED inside vehicle. Remote start will start up and shut down vehicle fine. Just does not lock or unlock doors. Locks work...
Have you changed the battery recently? My remote has a bad habot of slightly misaligning the cel switches if I don't close it exactly right. For my Chrysler van the sliding door switch is affected that way. All else works, though. I end up opening the remote again and ensuring it snaps shut all the way around with just one compression. If an edge doesn't close it's try again. The good news is it's virtually always the remote at issue and nothing expensive in the vehicle.
Jun 06, 2017 | 7900 RB 7900 2Way Color LCD Remote Start...
Car starts for two seconds shuts down trys to restart three times with same results
code program wire (pink) was left unpluged after programing code.At restart it would lose code. Reset code pluged in wire,runs fine
Feb 06, 2010 | Viper Security and Remote Start System...
'98 Audi A4, Viper 5501. Car auto-starts and runs
You will be best to connect the real tach wire. You will need to programme the alarm to recognise the speed of the engine, this way it will know where the idle position is.
Nov 20, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Nov 04, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Vehicle Parts & Accessories Logo
216 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
jason
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
