Question about Garden
Ventral loss of speed rpms meet spec any adjustments//
While mowing particularly in rougher terrain there was considerable jarring but now it seems slower and must less jarring on same terrain
5 Suggested Answers
InMrFixIt
  • 121 Answers
SOURCE: 5.2 losses power backfires at
Need more information on this situation. If possible find a vacuum gage and connect to the the intake manifold. What is the vacuum reading when the engine is running sell then 1800 rpm. What is the year and mileage on this pickup.
Posted on Aug 09, 2008
czaa
  • 4536 Answers
SOURCE: rpms fluctuate 300 to 400 rpms when driving
hav u done your needed maintenance like checking oil level-itz done with engine going in park also shift cable needs ajusting or solenoids on the electronic models if alot of miles then a rebilt is posible am tired and its late-try testing the tps sensor 1st has to with shifting***
Posted on Aug 07, 2009
mcdevito75
  • 1970 Answers
SOURCE: Slower engine speed in 4wd mode, 1st or 2nd gear (auto trans)
mcdevito75 here, I would figure yes, if your shifting while in motion, definetly yes, when you shift your changeing gear ratios in the 4 wheel drive or the transmission, this will cause the engine to slow but also make the gas pedal moe responsive.If you feel or hear this slowing down of the engine while standing still (at a red light) it"s most likely the computer contolled sensor in the tranny. I woulkd still check with my local shop for their advice too.
Posted on Jul 13, 2010
skychief2001
  • 21873 Answers
SOURCE: 2002 suburban overheating while towing
Could be a long list of things that would affect the cooling ability of the engine, or things that produce heat.
A restriction in the exhaust, a restriction in the coolant flow thru the engine or radiator, even air flow thru the radiator.
Posted on Sep 25, 2012
The float valve sometimes sticks or stays open and the carb floods and then the engine I've had carb off checked float and valve seems ok but still floods CAN ANYONE HELP v-h-b cheshunt...
The needle valve has a very fine neoprene tip which especially with newer gas (they sneak a lot of alcohol in) deteriorates and leaks.
Replace the needle and seat, check your float and be sure it's not leaked(if metal, give it a shake next to your ear, listen for gas sloshing) or the float saturated (composite float, take it off put it in a jar of gasoline, if it sinks its bad).
If you really want to be sure, check the float height according to specs and adjust as necessary by bending the tang where the float and needle meet. Best of luck to you
Sep 09, 2013 | Motorcycles
Sep 25, 2012 | 2002 Chevrolet Suburban 2500
Where can I buy tent stakes?
Walmart have tent stakes that are reasonably priced and you can buy them individually which is really helpful. We lost just one of ours and I didn't want to replace the whole set. http://www.walmart.com/ip/COLEMAN-TENT-STAKES-10/13848624
Sep 10, 2012 | Camping, Backpacking & Hiking
Hi, I have an older toro snowblower w/ tecumseh 7 hp. When idling it is fine,but with full throttle the engine seems to over rev. I've adjusted the 2 carb settings to specs and it seemed to run well, but...
The carburetor settings should be to make the engine run correctly, not meet some specification. The upper jet is for idle adjustment and the lower adjustment is for high speed running. It the lower jet is too far CW, the engine will be running lean and tend to miss. Too far CCW and the engine will run 'muddy' and tend to blow black smoke from the exhaust. Throttle speed is determined by a balancing act between two springs, the governor, and the throttle position. Generally, there are several options for spring placement--a series of holes drilled in the throttle arm and the governor arm set this balance. Have the springs been replaced? Have you tried a fresh spark plug? You may require professional assistance on the throttle adjustment. Hope this helps!
Jan 27, 2011 | Garden
2nd gear drops hard
Dear Madam or Sir,
this is a well known problem with the Audi-transmissions, we do have a lot of failures with them over here in Germany. ;)
There are some software updates available, in many cases this fixed the problem.
Another possibility is a faulty transmission speed sensor, this is causing the hard shift behaviour.
First you should see the dealer to check the transmission control module´s trouble code memory and to check if there is a software update available for your car.
Jun 25, 2010 | 2004 Audi S4
Loss of Power at Freeway Speeds
Sounds like itr is not getting enough fuel. Try or check the fuel filter for dirt or water, and also check the fuel pump pressure to see if it meet factory specs.
Good Luck Jerry
jerry1938@hotmail.com
Dec 13, 2008 | 2004 GMC Envoy
5.2 losses power backfires at idol speeds 1800 rpms or less. Increasing rpms regains power. Air/engine temp and humidity seem to play a role.
Aug 09, 2008 | Dodge Ram 1500 Cars & Trucks
I HAVE A 2006 FORD RANGER LEVEL 2 4X4....when giving it gas in neutral or park the motor jars around 3,000 rpms and won't go higher? when driving it works fine and passing gear works fine too...just when i...
Funny....thats a safety feature ford now uses. Keeps you from blowing the engine and no you cant by pass it. So yes its natural. But nice to know that someone still trys to feed some speed.....
Jul 31, 2008 | 2000 Ford Focus
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
