Question about The Video Game Consoles & Games
It showed where friends have played but when I opened the game to play I could not do so. Problem just happened as I play every day. What can I do to correct this
SOURCE: wont play playstation 2 games
This can occur if the Playstation has been knocked or dropped. On the slim version if you remove the screws underneath and remove the top cover you may find the the small drive shaft has been dislodged from the motor. Push it back into place refit cover and screws. This fixed my PS2 with this fault.
Posted on May 05, 2008
  • 16 Answers
SOURCE: my ps3 won't play my disk-based games
This sounds a similar problem what I had. My PS3 did not start the disk based games. Those disk based games were not visible in the game menu.
I did not have problems with the normal movie DVDs or Movie Blu Rays. Those were working fine. Also downloaded games were working ok.
In case you have the similar problem, you should try the following steps;
The PS3 has a special Recovery Menu, which you can access in the following way;:
1. Turn off Playstation 3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION 3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION 3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION 3 System
Select option "Rebuild Database".
After PS3 has executed the DB rebuilding operation, the disc games will be visible again in the menu and are starting automatically when inserted to PS3.
Posted on Jun 18, 2009
  • 3 Answers
SOURCE: xbox 360 will play movies but not games
everyone i have the solution!!!! all you have to do is take apart the the original drive and unplug the circuit board, there are 4 ribbon cables be careful not to bend or tear them, then do the same to the new drive and switch the boards so the new drive has the security key and firmware of the old drive and voila youre back in business
Posted on Jul 05, 2009
SOURCE: after i open farmtown its loading but cannot play
why i cant open my farm town?
Posted on Oct 20, 2009
benwabnick
  • 2404 Answers
SOURCE: PS3 wont play game but will play DVD's
The laser in the dvd drive requires different strengths to read different discs. If its reading movies and not games then the laser is starting to go bad in it. You can either replace the laser if your tech save to open up the ps3 and opening up the dvd drive, or you can just get another drive to put in there. Either one you can get from Ebay fairly cheap.
Posted on Nov 30, 2009
Testimonial: "thanks....iwas going crazy not being able to play...i think ill just send it in for repairs...thanks again"
Wont show friends in pet rescue saga
can not play pet rescuse, can't get friends to help me because there are no friends name list. sick and tired of not being able to play the game. can someone help? i have no solution.to fix it. that's pet rescues job. alot of my friends are having the same trouble and are think of not playing the game anymore.
Jan 20, 2014 | Facebook Apps
Noticed a brightness in my screen play while playing xbox what could this be?
Check to see if the issue is only while playing a certain game or if it is with all of your games, check to see if there is a brightness setting in the games you play, there are in most games. If it is unnaturally bright in every game you play and only happens while playing xbox and not while watching tv, there may be an issue with your video cables, try using a friends video cables if any of your friends have the same console to see if that fixes the problem, if so, you may need to replace your video cables.
Dec 16, 2010 | Microsoft Xbox Console
Nov 30, 2009 | Sony Playstation 3 (PS3) Console
Cant play campaign or solo mode even when friend invites
check the game for dirt or scratchs or any kind of problem it might be the game it happened to me once so it is most likely the game
May 29, 2009 | Microsoft Halo 3 for Xbox 360
Rome Total War!‏
That is your problem. If the game is not compatible with Windows Vista, It won't play it, or play it normally. What I mean is that the game is pretty old (in date created), and the software used to create it was not meant for Vista. Because Vista came afterwards (I think). And Vista has to downgrade while running the game. But it could only downgrade so much. And when it downgrades, it's actually working harder to play the game than having a whole bunch of stuff open at the same time. Vista playes it, but only for a while, because it's not going to downgrade any more.
Hope this helps.
P.S. If you want to play the game, I recomend you get a computer with XP.
Apr 30, 2009 | Sega Genesis Console
Playing online!
What Game is This on Cuz this Happens to Me on Modern Warfare nd i Reset My Internet Box and Now We Play 2getha All tha Time
Jan 29, 2009 | Sony PlayStation 3 40GB System
I can't play the Agility Trial on my Lab and Friends game
your clock must have been altered or ur on a different ds wait a day and it'll work
Dec 14, 2008 | Nintendogs: Labrador & Friends for DS
Psp
If you want to play mutiplayer both should have the copy of the same game(in u r came Juiced 2) on the PSP. or else it wont work.
Oct 22, 2008 | Sony PlayStation Portable (PSP) Console
Video Game Consoles & Games Logo
24 people viewed this question
Top The Video Game Consoles & Games Experts
 David Duggan
David Duggan
Level 1 Expert
AliennoisE
Dustin
Dustin
Are you a The Video Game Console and Game Expert? Answer questions, earn points and help others
