Question about Vacuums
Kenmore central vacuum has great suction however dust and dirt bypassing the canister and ending up all over the garage
    President:
  • 1,486 Answers
Change the caister seal
Posted on Jul 24, 2009
  • 58 Answers
Is it a bagless/ filterless system? if so the unfiltered air goes through the motor and is ehausted out. All of the older systems from kenmore i have seen worked like this and must be ehausted outside. I will say that this is a terrable design because the dust going through the motor is **** on it. I would replace the entire tank with a bagged or at least filtered system. Nutone or Hayden would be my first choice. You can always vent it outside to help, but that isn't going to make your motor last.
Posted on Jul 26, 2009
My Dyson DC40 Animal sounds like it's running on half power. I've only had it one day and it seemed great considering it was sucking up an incredible amount of half/dirt. I took the canister to empty it,...
I would recommend you check the gaskets and make sure they are all connected properly so the vacuum doesn't lose suction. Also, check the filters. If they get too dirty the vacuum will lose suction.
You could check out Dyson's site: dyson.com/support.aspx
Hope that helps.
Greeley Epoxy Garage Floors
Aug 24, 2013 | Dyson DC40 Animal Upright Vacuum -...
Nothing going into dirt canister
Is there suction at the hose? If not it is either blocked or the suction fan is broken. If there is, then there is a blockage in the pickup section, something is lodged across the channel after the brushes and before the place where the hose plugs in.
I think there is a safety switch to prevent it from running with the canister out so hard to check for suction at the top of the motor/suction fan. Make sure nothing is over that part under the canister too! If you can figure out how to bypass the safety switch (if there is one), you should have good suction where the canister sets on top of the motor base.
Oct 06, 2012 | Dirt Devil UD40270RM Quick Power Compact...
Hi! My central vacuum has worked perfectly until just a couple months ago. I went to plug the vacuum in and it didn't automatically start the suction. When I clicked the switch to the right on the...
It sounds like you may have a bad hose. Plug the hose into the wall but rotate it 90 degrees from the normal position. This will bypass the switch on the hose. If you look at the wall end of your hose, you will see a metal band around it. That metal band is split into two sections. You are trying to plug in the hose so that the separation of the two pieces of metal is not lining up at the top of your inlet. If your vacuum turns on then you have a bad hose. It is possible that you have a bad switch in the hose, but it is more likely that you have a bad hose.
If your vacuum does not turn on, then you may have a break in your low voltage wire somewhere. You can check to make sure it didn't get disconnected at the unit. If the wire is connected then try to cross the low voltage wire from the relay at the unit with a small screw driver. If the unit does not turn on you have a bad relay.
If it is the relay, AirVac does not provide them. You would need to consider buying a new unit.
Jul 17, 2011 | M&S Systems AirVac AVP1200 Platinum Series...
I have a Sears Kenmore canister sweeper with the power mate, but it no longer has sufficient suction to pick up dirt. I took the machine apart and cleaned it, but it is still not sucking, does this model...
When cleaning the machine, did you do a good job of cleaning the beater brush and making sure it turned freely in the holders on each end? Perhaps a bit of WD40? Also, a new set of belts might help a bit.
Sep 18, 2010 | Kenmore 22812 Bagged Canister Vacuum
My kenmore quick clean vacuum cleaner has no suction. Just seems to blow the dirt out and away from the cleaner. The canister is empty and the filter is clean, so what's going on?
The hose or hoses are plugged...take all the hoses apart and stretch them out... run a stiff wire through them or something like a broom handle...you will find that they are full of dust and dirt inside...
heatman101
Apr 24, 2010 | Kenmore Quick Clean 30012 Vacuum
Canister turns on but no suction in house
sounds like there could be a clog in the lines, Check the pipes running through your attic/basement, and see if there's something blocking the piping.
If you can't seem to find the problem, I'd suggest looking into having someone who services central vacuums come and take a look. They'd have the proper tools and knowledge to help you in person
Apr 19, 2010 | Eureka 1810 Central System Vacuum
Dirt is being trapped in the filter area instead of canister.
The canister has a filter as well. It needs to be replaced or cleaned. A damaged canister filter will feed dirt into the HEPA filter. (and the motor)
An improperly installed filter can allow dirt to bypass the canister filter and collect in the HEPA filter.
I suggest a new canister filter and then clean it carefully every week.
Here is a list of the filters for your vacuum.
Apr 16, 2010 | Eureka 5893AVZ Bagless Upright Cyclonic...
Have suction, new bag, brush moving but does not
Solved!!!
I went to my local Sears store and the salesman there looked at my vacuum and was able to resolve the issue. There was a piece of wire that had been sucked into the machine that then blocked anything else from being vacuumed up.
Thanks for your help.
Jun 18, 2009 | Kenmore 22313 Bagged Canister Vacuum
No suction
If the motor is running and is not full of dirt, and the hose is not plugged, the canister must be cracked or open somehow.
May 08, 2009 | Kenmore 22812 Bagged Canister Vacuum
No suction in the walls for our Beam Heavy Duty Vacuum.
Do you have any open valves? Sometimes when vacpans are installed they are left open. Check those and then the other inlets to make sure they are not open.
Also, if this unit is not newly installed, then you need to check for blockages. If the motor in the garage is winding up and running faster/harder than usual, then there is likely a blockage between the main unit and the inlet nearest the unit.
Dec 08, 2008 | Vacuums
Vacuums Logo
200 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
