Question about Moen Plumbing
I have a Moen bathroom sink faucet which just today isn't letting water through, or at a very low rate. Good pressure throughout the house elsewhere. It is a single control faucet, one year old
    Top Expert:
  • 12,744 Answers
To valve is failing [need to replace the valve ]]or debris is stuck in valve either way would need to remove the valve body to inspect
Posted on Apr 20, 2017
Just bought 4 moen Oxbridge bathroom sink faucets. Water pressure is very low compared to old faucets. Checked the aerator but no adjustment is available. New shower head is the same issue.
These days, you may find a disk with a small hole intended to restrict flow. It may be installed above the aerator. Check the flow with aerator removed.
Aug 13, 2017 | Moen Plumbing
When I turn on the cold or hot water sink faucet water leaks out from the top of the cold water faucet . I took the outer casking off and can not figure how to remove the stem. I removed the ring but...
if you have the ring removed, screw the handle back on and pull up on it,, your leak is probably due to a worn , torn , "O" ring,, and Moen parts are found at most hardware stores ,, ( including Home depot , and Lowes) On Moen faucets , Look for the dent in the flange that squares off,, where that square is on the ring, is where the retainer ring is that holds the faucet in place ..its a "C" clip with a head on it, remove this ring and the assembly should come out , be sure and use plumbers grease when replacing the O rings,, they last much longer that way
May 03, 2011 | Moen Bathroom Sink Faucet - 4-inch...
We live in a house built in early 60's. Re; Plumbing to kitchen sink and dishwasher. On vary rare occasion the sink faucet will have decent water pressure. We have changed the water faucet with a Moen. As...
if this is the only place in the home where water pressure is a problem then the lines may very well be the issue. if you have low pressure throughout the home then there may be a problem with the main water supply in the home. if the lines are galvanized pipe then they may be restricted due to rust or other deposits forming on the inside of the pipe. unless you are good at plumbing then i would suggest having a professional come out and assess the condition of the lines.
Feb 25, 2011 | Microwave Ovens
My classmate
Moen Monticello 4-inch centerset bath faucets can be repair easily with only a screwdriver and adjustable wrench. Turn the water off to the both sides of the faucets under the sink. Open both the hot and cold-water valves to alleviate any remaining pressure. Remove the handles by grasping the base of the handle and turning it counterclockwise.( This works for both lever and cross handles). Loosen the Moen faucet cartridge bonnet nut with an adjustable wrench by turning it counterclockwise to the left. Pull the stem from the faucet by hand and replace. Reinstall the bonnet nuts and handles. Turn the water back on and test the faucet for leaks. The Moen Monticello faucet comes with a limited lifetime warranty. Try calling Moen to get your replacement parts free.
Dec 09, 2010 | Moen Bathroom Sink Faucet - 4-inch...
How do i get at the valve on a moen monticello bath faucet
In the link below second to last page will tell you how to remove the valve.
http://www.moen.com/shared/pdf/instruction_sheets/ins060b.pdf
Good Luck please rate 4 thumbs up and please leave a testimonial
Oct 31, 2010 | Moen Bathroom Sink Faucet - 4-inch...
No hot water on Moen single handle shower faucet. cold ok and shut off is fine
do you have hot water elsewhere? if not, might be that your water heater is not heating.
if you do have hot water elsewhere, did you let the faucet run for a minute or 2.
did you have hot water before? is this a new house? new valve?
need a little more detail.
on posi temp valves, if there were no water coming out of the hot side of the valve, the valve will not operate.
Aug 12, 2010 | Moen 1 Handle Lever Shower Faucet With...
Why did my moen faucet stop working? I have water flow throughout the house but the flow at the kitchen faucet just suddenly stopped!
Rubber gasket on the water shut off valve under the sink has come off and traveled up into the faucet. It's pretty difficult to get it out. If you have access to an air compressor you may get lucky by taking the faucet completely off the sink and blowing air back from the faucet outlet back into the internal piping to dislodge the rubber piece. If that doesn't work, or you can't use the air compressor method, then it's a trip to the hardware store for a new faucet.
Jan 11, 2010 | Moen 87530 Touch Control Single Handle...
I have a Moen Monticello bathroom faucet. I am
Moving left to right: I am not an expert, but I have installed a fair number of faucets. Seems like a basic issue of just getting under the sink and tightening up. Make sure someone is topside to assure the faucet stays straight and does not move as you tighten up below. It is never easy to get a wrench and your hands in the proper position to tighten up the nut, but don't give up try a smaller Channel lock wrench if necessary.
Sink Stopper: http://www.lowes.com/lowes/lkn?action=howTo&p=Improve/PopUpStop.html
Jan 02, 2010 | Moen Bathroom Sink Faucet - 4-inch...
Low hot water pressure in kitchen faucet
I have moen kitchen faucet # 7560 and water pressure very low. What should I do? We check water flow in pipe it is ok. I changed cartridge as well as pipe nothing help. Please let me know. thanks
Oct 14, 2009 | Moen & Replacement Cartridge
HOW TO DISMENTLE OR REPLACE A MOEN SINGLE LEVER
shut water off at stops under sink. Unscrew water supply lines from directly below handles. Above them you will find plastic nuts, remove them. Disconnect pop/up lever and you should be able to lift faucet from sink.
Sep 24, 2009 | Moen & One Handle Tub & Shower Faucet
Plumbing Logo
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
