Question about Ricoh Office Equipment & Supplies
I have ricoh aficio gx3050 I see warming reset collector ink
3 Suggested Answers
newport74
  • 58 Answers
SOURCE: Ricoh Aficio GX3050 Gel sprinter - error999
BULLETIN NUMBER: J001/J003/J006/J007/J010/J011 – 021 07/02/2008
APPLICABLE MODEL:
GESTETNER – GX3000/GX3050n/GX5050n
LANIER – GX3000/GX3050n/GX5050n
RICOH – GX3000/GX3050n/GX5050n
SAVIN – GX3000/GX3050n/GX5050n
SUBJECT: SC999 OCCURS
SYMPTOM:
An SC999 (Maintenance Stepper Motor Home Position Error) occurs.
CAUSE:
Some of the ink in the machine has dried, and as a result the maintenance stopper motor cannot rotate or
the levers come loose.
NOTE: The following conditions make it easy for the ink to dry up (See Appendix 3 for more details):
- Low humidity
- Long intervals between machine usage
- Total period of usage is long
- Low Print Volume
 COPY QUALITY
Fixed ink Stepper Motor
Right Flushing Gate
Levers
Tech Service Bulletin No. J001/J003/J006/J007/J010/J011 – 021
Page 2 of 5
SOLUTION:
Production Countermeasure:
The shapes of some parts in the Maintenance Unit have been changed in two steps ("Step 1" and "Step 2"
below).
NOTE:
See Appendix 1 for the details of the Step 1 and Step 2 modifications.
See Appendix 2 for the visual differences among the unmodified unit, the Step 1-modified unit, and
Step 2-modified unit.
See UNITS AFFECTED for the Serial Number cut-in of Steps 1 and 2.
Field Countermeasure:
1. Cycle power OFF/ON.
2. Install one of the modified Maintenance Units ("Step 1" or "Step 2").
NOTE: For customers experiencing a SC999, have them contact 1-800 Ricoh38 for replacement.
Posted on Feb 27, 2010
fanaudi
  • 1381 Answers
SOURCE: purchased Ricoh Aficio GX3050 sfn.
Hi pil3 ,
Delete current driver/software . Download and install latest driver from here ( select first your OS ) :
http://www.ricoh-support.com/enduser/downloads/downloads.asp?fileid=16947&ricohmodelid=6433&url=http%3A%2F%2Fsupport%2Ericoh%2Ecom%2Fbb%2Fhtml%2Fdr%5Fut%5Fe%2Fre%2Fmodel%2Fgx305sf%2Fgx305sfen%2Ehtm
Best regards ,
fanaudi .
Posted on Aug 27, 2011
How to refill ricoh gelsprinter gx2500 ink cartridges
I using gelprinter recoh gx 3050, how i can refill this cartage
any branch in India give me gel ink & refillable cartage
pl. give advice abou
sujitgajre@gmail.com
Nov 08, 2011 | Ricoh Aficio GX3050 GelSprinter
How do i reset the counter when i have replaced a ink collector unit on my richo gx7000.
Push the menu key.
Push enter key three times.
Turn printer off then on
See my video at www.condetv.com
Search for waste ink.
Mar 13, 2011 | Ricoh Aficio GX3050 GelSprinter
GX5050N. Printer turns on. Then 5 seconds later, green light flashes and printer turns off.
I am trying to solve this problem right now. Ricoh says it is mostlikely a short in the print head which unfortunately means trash the printer. If your printer has a full ink collector you can reset it. go to www.conde.com and look at tech tips it is very simple.
Sep 06, 2010 | Ricoh Aficio GX3050 GelSprinter
I need to reset the cartridge chip gx3000
how to reset the chip in ricoh gx3000colour printer
Jun 16, 2010 | Ricoh Aficio GX3050 GelSprinter
APPLICABLE MODEL:
SYMPTOM:
CAUSE:
- Low humidity
- Low Print Volume
 COPY QUALITY
Right Flushing Gate
Levers
Page 2 of 5
SOLUTION:
below).
NOTE:
Feb 02, 2010 | Ricoh Aficio GX3050 GelSprinter
I have same problem - if I find a solution I will post it
this is a problem caused by the gel that is not supplied anymore in the printer. certainly the waste ink collector behing the machine is full. by replacing it i solved the problem sometimes, sometimes it is more serious ans the sparepart of the supply must be replaced by crafted man.
hope it can help !
Aug 21, 2009 | Ricoh Aficio GX3050 GelSprinter
I get a message that says ink collector almost full. I cleaned it and i replace it. But i got always the message :"inkcollector is not set. replace inkcollector". What have to do ?
After you replace the ink collector there is a counter you have to reset it to tell the printer that you are inserting a new collector
Jun 09, 2009 | Ricoh Aficio GX3050 GelSprinter
My ricoh 305on is displaying error 990. I have
change the ink collector located in the rear of the machine
Mar 11, 2009 | Ricoh Aficio GX3050 GelSprinter
Ink collector almost full
100% agreed with rrrdddrrrddd. In addition:
Go to Menu->System->INK CU Replace. You will get a warning that overflow may occur(and it's really a messy job), reset the counter and everything should be OK.
Oct 06, 2008 | Ricoh Aficio GX3050 GelSprinter
22 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
